Question about Nordic Track Nordictrack Viewpoint 2800 Treadmill Drive Motor For Model Number:
Nordictrack treadmill starts for a few seconds and then stops
Treadmill starts and stops
  • 103 Answers
SOURCE: I NEED THE NORDICTRACK 9600 INCLINE TRAINER TREADMILL SCHEMATIC
contact me @ swflafitnessrepair@yahoo.com I will send this to you.
Posted on Nov 13, 2009
maxtreadmill
  • 832 Answers
SOURCE: My treadmill is stuck in the max incline position
If the incline moves but only just a bit, it could be a problem as simple as the gearbox on the motor being jammed. We remove the motor from the treadmill, reconnect the wiring, and then try to run the incline motor outside the treadmill. Many times, this will unjam it if that is the problem and then reinstalling it in the treadmill will get it to work. If you have the same problem or it doesn’t run outside the machine and you can hear it try to work, you need to replace the incline motor.
Posted on Jun 11, 2010
  • 218 Answers
SOURCE: NordicTrack 2500 R Treadmill
# get a 12-18 volt dc battery fully charged(like one from a cordless drill)
# Make sure it is fully charged, because it won't work if not
# attach the + and - to the motor red is + and black is -
# If the motor turns slightly your motor is ok, if not the motor is bad and would need replaced
# if the motor is ok then your motor controller(the board with the metal) is malfunctioning and would need replaced.
Posted on Aug 11, 2010
ercupa190
  • 12223 Answers
SOURCE: NordicTrack Treadmill A2050, Will not work or turn on.
1) test the outlet wall , put a desklamp and see if work, if work the problem will be in the machine,
2) test the fuse inside for blown and replace with the same capacity
3) reset the circuit breaker inside.
4) test the power cord for open or defective.
Try again, if the machine NOT work, the problem will be in the power supply see the block atached.
God bless you
Posted on Sep 20, 2012
ercupa190
  • 12223 Answers
SOURCE: NordicTrack Treadmill A2050, Will not work at all, with key in place.
1) test the receptacle wall, plug a desklamp for to see if work if is working go
2( testing the power cord for open or defective.
3) reset the machine
4) test the fuse for blown and replace
5) test the c.breaker for tripped and reset again.
6) test the key, the key is small magnet, you can test with your magnet refrigerator with atraction or repulse, if doesnot replace the magnet from home depot.
God bless you
Keeps stopping. I turn off power and restart but it stops again after a few seconds. How can I reset it to quit stopping after a few seconds.
Hope the speed sensor have some problem may dust on it or the treadmill need lubrication. Most of the treadmill stop after some kilometres reading indicating that its time to lubricate it. After lubrication you have to reset the counter.
check the link bellow using the search tab find out details of NORDICTRACK A2350. and follow those instruction.
www.electro-medical.blogspot.com
Nov 01, 2015 | Nordic Track NordicTrack A2350 Pro...
Treadmill incline not working
The incline system may need to be calibrated. To initiate the calibration routine follow the steps below.
Step 1
Place the key into the machine. The key's slot is located on the bottom of the console, below the start and stop buttons.
Step 2
Press any of the incline buttons and then remove the key from the machine while the incline is changing. Pause for a few seconds and then put the key back into the slot.
Step 3
Wait as the treadmill automatically shifts to the highest possible incline and then descends to the lowest level. The treadmill should now be recalibrated.
May 30, 2014 | Nordic Track NordicTrack Treadmill, A2550
Incline stuck at 12
please follow this steps and fix it. Merry Christmas
1 )Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill. ·2
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
·3
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset
Dec 18, 2013 | Nordic Track NordicTrack - E 7.5
Nordic track A2350 treadmill, I found this unit with lights blinking this afternoon, so I unplugged for 1hr and when plugged back in the only thing that happens is the red iFit logo comes on. What can I...
reset the treadmills, follow the steps and fix it.
God bless you
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Oct 18, 2013 | Nordic Track NordicTrack COMMERCIAL 1750...
Norditrack a2550 model stopped working while I was on it. The control panel will beep then light up like a Christmas tree but just goes into a nonperforming demo mode. Treadmill wont work! Help
follow this steps and fix it. God bless you
1.
    • 1
    • 3
    • 4
    • 2
Oct 06, 2013 | Nordic Track NordicTrack Treadmill, A2550
Contiually beeping, when started it stops a few seconds later
LUBE the deck belt+ roller bearing too. see the video and proceed according. If the problem persist after you lube , time to change the deck belt board complete.
God bless you
Jan 08, 2013 | Nordic Track NordicTrack T7 si Treadmill
My t7 si is beeping continually and starts for a few seconds and stops
lube the deck belt+rollers bearing . If the problem persist, time to change the deck belt board complete.
God bless you
Nordictrack apex4100i level incline will not work
Try this calibration procedure.
Turn the power switch on. Remove the safety key. Hold the Stop and Speed Up or Speed Plus buttons down then insert the safety key.
The display should show some numbers.
Press the stop key one time and the display should show some other numbers and some 00's. Press the Incline Up button and see if the Incline begins to move, if it does let it go all the way up and then all the way down, wait a few seconds after it stops, then hit the stop key 4 times. It should be calibrated. If it didn't move then the board or the incline motor is bad.
May 31, 2009 | Nordic Track Nordictrack Apex 4100i...
Nordic Track Nordictrack Viewpoint 2800 Treadmill Drive Motor For Model Number: Logo
91 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Paul Sikkema
Paul Sikkema
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
