Question about Samsung WF203ANW Front Load Washer
Door adjustment door needs adjustment its to low to close
I have a lift master garage door. the door close sometime but sometime will close but pop back up. I have tried to adjust it but it continue to do the same
There should be only 2 things that make it go back up.
First the pressure switch on the door itself. If it is set to low just the pressure from the door closing can set it off. See if you can close the door and use your hands to put some pressure on the door if it goes back up with little pressure then adjust the pressure switch. You might have to turn it a couple of rounds to see a difference.
The other is if you have it installed is the reflective proximity beam on the bottom. Check it and make sure everything is tight and lined up. If it is loose the vibration from the door closing can break the beam and reverse the door. Hope that helps.
Sep 30, 2017 | Building Materials
I have a Magic Chef refrigerator Model GT17A7V, Serial 11993269QS. It does have wheels, but we needed to adjust the wheels in order to make it easier to roll. Problem: The refrig & freezer doors now...
Unfortunately, when you adjusted the wheels to be able to roll it easier, you thru off the tilt required for your doors to swing the way they should.
You are going to have to adjust them again, to have a front (high) to back (low) tilt. If you have a right hinged model it should be adjusted very slightly higher than the left.
Aug 15, 2011 | Maytag Refrigerators
Garage door only goes one third of the way down and stops. It was about to hit the car and I hit the button a couple of times so that could have thrown it off. Any thoughts???? Thanks so much
hello sue... That activity must have thrown the door out of adjustment.. On the motor unit there are high limit and a low limit adjusting screws. The low limit screw needs to be adjusted to move the door down until it closes properly. Just adjust it 1/4 turn at a time and then test it to see where the door is at. Joe
Mar 28, 2011 | Electrical Supplies
Having trouble lighting a second hand efel oil stove what is the steps needed to take when igniting it
plug in, open bottom and clean line end by twisting and pulling pushrod, make sure valves are on, tank must be higher do to gravity feed, crack open door 1/2 in, turn timer dial (one that clicks) all the way it should glow at bottom of crown, turn on fuel to low setting (just counter clock of the click), once flame is burning across the bottom of the pan close door all the way. The door open is so that it keeps stove clean for lighting also open the door for closing. If smoke is coming out of the door close it a little more. the stove needs to be clean and will stay clean for a long time if you open the doors. if it floods you need to clean it out. there are fuel adjust screws and air adjust counter weight but have a professional set those. good luck its a great stove once you get to know it.
Sep 13, 2010 | Heating & Cooling
How do i adjust the doors on my 1995 suzuki swift? They are hanging too low. I have to lift the doors to close them without damaging the closing mechanism.
You need to go whole hog and get new hinges. When you have them in, then you adjust the doors. The hinges are so shot any adjustment is futile.
Aug 22, 2010 | 1995 Suzuki Swift
Door adjustment
Start by raising the front legs slightly to shift the directional pull of the door rearwards.
Feb 05, 2010 | KitchenAid KBFA25ER Bottom Freezer French...
My Wolrd Pool Double Oven Door will not close all
same problem, I tried to adjust the level and tip the oven back, but that didn't work either.
Two options exist, change the hinges, or close the door with a hammer handle between the door and oven. Place the handle down low by hinge, then push the door closed very firmly to pull the hinge outward a bit.
Jan 03, 2010 | Kenmore Ovens
Garage Door will not stay closed.
You need to check the adjustment for the travel of the door ... All automatic closers have a built in safety mechanism that prevents children, pets and even yourself from being crushed by the door ... so if the travel is set to low the door will hit the ground too hard and safety mechanism will activate opening the door again! Look at you documentation for how to adjust this for your particular model :)
Sep 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
No matter where the door is located on the track when i engage it to the pully and press the button it will go down about 1 a foot and then stops and comes back up about 1 a foot and the lights blink....
There is an adjustment for how much 'torque' the unit is using to lower the door, and if your door is jamming or if this setting is set too low, the door will reverse. There are 4 adjustments on this unit: one for all the way up, one for all the way down, and the one for 'jams'
First: make sure you have BOTH a yellow light on one sensor and a green light on the other sensor. 2nd: Go inside the gararge (keep kids and pets away) and press and HOLD down the close/open button and keep holding it - this is an override for the photoeyes and your door should go all the way down to the close position. IF if doesn't, then you need to adjust the white knob that will allow it to close. It is testing to see if you have a jam, and the setting might be too low, or your door is binding. If these don't help, you'll have to call a pro. Good luck my friend.
Johnny
Aug 21, 2009 | Kitchen Appliances - Others
The door reverses back to open position instead of closing
SOUNDS LIKE A SENSITIVITY ISSUE UNHOOK THE DOOR AND TRY IT MANUALLY TO BE SURE IT DOESN'T BIND OR IS TOO HARD TO OPEN OR CLOSE.
IF ALL IS WELL CHECK THE SENSITIVITY SETTINGS ON THE BACK OR SIDE OF THE OPENER.
YOU WANT THIS SET AS LOW AS POSSIBLE AND STILL OPERATE THE DOOR WITHOUT REVERSING.
NOTE: THE FULL RANGE OF ADJUSTMENT IS ONLY ABOUT 3/4 TURN SO MAKE A VERY SLIGHT ADJUSTMENT AND THEN TRY IT AGAIN.
HOPE THIS HELPS
Feb 20, 2009 | Sears Craftsman LiftMaster Chamberlain...
Samsung WF203ANW Front Load Washer Logo
21 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
