Question about Whirlpool Thin Twin Washer and Electric Dryer in White WET3300XQ
How do I remove the front panel of my Whirlpool Thin Twin washer/dryer?
Dryer in not turning
  • 15 Answers
SOURCE: whirlpool thin twin dryer starts and stops after 5 seconds
In the back of your thin twin dryer is a small white flat fuse attached with a screw, a clip, and two spade clips and wires. This is a thermal fuse and if tripped will cause your dryer to do nothing. Check with multimeter for continuity and replace if necessary. Also inside machine is a black tubular capacitor that will cause dryer to not run. Again, remove after properly discharging capacitor. Using multimeter check capacitor for continuity and potential. Obviously disconnect all power to machine before even thinking about repair. 240 volts will kill you dead.
Posted on Mar 19, 2008
jsrock516
  • 5911 Answers
SOURCE: How to remove the washer cycle selection/start-stop knob on a Whilpool Heavy Duty Thin Twin stacked washer dryer
I believe the selector knob on a Whirpool just has to be turned counter-clockwise with the selector pushed in. It will spin off the shaft and then the outer indicator dial will pull off. The shaft also has a keyed slot that will only allow the dial to be removed and installed one way, so there should be no question as to how it goes back on.
Was there a reason as to why you are removing the washer selector knob? If this is a simple matter of replacing a broken water temperature selector, you shouldn't have to remove any of the control knobs to gain access to the selector. The entire front panel comes off by removing the screws holding it in place. That way you can access the broken selector from behind the front panel much easier. Just remove the panel right above the washer top (under the dryer) and it should expose the front panel mounting screws. Remove these screws and the front panel comes off. Just make sure the unit is unplugged before you begin. I hope this helps you. Let me know if you need further assistance.
Posted on Apr 22, 2008
  • 1073 Answers
SOURCE: Replace belt on Whirlpool LE09508KQ1 Electricl Dryer
remove the lint fiter and remove the two phillips screws then lift the top up
you will find two screws on each side of the inside of the frount panel down about 4 inches , this when removed will allow you to swing the frount arround to gain access to the belt
Posted on Apr 30, 2008
IFIXALL
  • 868 Answers
SOURCE: HELP! My Whirlpool Thin Twin Dryer only works in Permanent Press sitting-buzzer goes off in all others
Replace the timer/control board
Posted on May 26, 2008
SOURCE: How do I remove the front bottom panel of my Whirlpool gas dryer
Yahoo! I figured it out on my own. There are two clips on top that are recessed. I had to use a regular screwdriver and push the clips down and pull the panel out at the same time. It was easy after I realized what needed to be done.
Posted on Sep 15, 2008
My dryer turns on and runs for only a minute. It then turns off and will not turn back on. It is like there is an element that gets too hot when turned turned on.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 16, 2011 | Kenmore 500 6952 Dryer
When I turn on dryer I hear a clicking sound and the dryer turns off.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Sep 08, 2010 | Kenmore 72062 Gas Dryer
My gas dryer will not turn the clothes drum the dryer turns on but the drum does not move
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jul 11, 2010 | Kenmore 62602 Electric Dryer
Dryer turns on does not turn
heatman101
Jul 06, 2010 | GE DWSR463EGWW Electric Dryer
My dryer won't turn on at all. It was working
heatman101
Jun 19, 2010 | Kenmore 66832 Dryer
Dryer will turn on but but the inside will not turn
heatman101
May 19, 2010 | Whirlpool GEW9250 Electric Dryer
REX4634KQ Electric Dryer: dryer heats up but won't turn...
heatman101
May 18, 2010 | Roper REX4634KQ Electric Dryer
Whirlpool gas dryer, the dryer turns on but will
heatman101
May 12, 2010 | Dryers
Dryer lights up but will not turn
heatman101
May 12, 2010 | Whirlpool WED8300S Dryer
Dryer does not turn and shuts breaker off when turning dryer on.It just makes a noise as if it's trying to turn.
heatman101
fsgs
Apr 06, 2009 | Estate EED4300TQ Electric Dryer
Whirlpool Thin Twin Washer and Electric Dryer in White WET3300XQ Logo
170 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
