Question about Drills
Not getting power
The drill is brand new but it was a display model. its not the battery, i already checked it with my other black and decker drill and charger... battery holds charge, and works in other drill. but doesnt in the new drill nor does the battery from my other drill (same 20v lithium battery) work in the new drill. im wondering if because it was a display model if there was something inside of it taken loose so that people couldnt actually use it in the store and if so can i fix it
    Habit-Forming:
    New Friend:
  • 160 Answers
Return right away. Your diagnostics tell me unit is bad.
Posted on Jun 05, 2017
HELP2DIY
  • 12 Answers
SOURCE: Drill battery charger doesn't work
Hi Firemedic13; Most chargers like yours have a fuse inside them. Remove the screws that hold the charger together. The fuse will be on the low voltage side of the transformer. Un-solder and replace it with one of the same value. If the charger is not held together with screws (doubtfull) you will have to carefully cut along the seam where they were glued together. A dremmel tool works good for this. After repairing use some ABS pipe glue to re-seal them together. If the fuse is not blown then the unit will require testing by someone that is proficient with a multimeter. Most times it is the transformer that has fried a wire. If the sides of the transformer have any burnt spots on it then it will be the culprit. Hope this has helped. Best regards; HELP2DIY Please dont forget to rate my answer.
Posted on Jul 10, 2007
rowdy45176
  • 2176 Answers
SOURCE: Can't get the keyless chuck off cordless Makita 6095D drill.
If this is a newer tool it is probably a Torx drive screw usually a T20. The screw is LH thread and after removing it you will need to put some screws back in tool to remove the chuck. First shift the gear selector to the low setting and the clutch to the drill only. Next get a bent handle allen wrench about the capacity of the chuck install the short end of wrench in chuck and tighten. Put the chuck on a block or wood or a workbench to support is and turn the wrench to about a 30 degree angle in the counterclockwise position. The chuck has standard threads so you want to hit the wrench with a hammer to loosen it. This might take a few tries but it will work. Good luck
Posted on Dec 31, 2008
  • 3 Answers
SOURCE: fixing a cordless drill battery charger
usually transistors have three legs, diodes have two arms all very confusing isn't it? resistors have two arms as well but not three legs or only two legs and no arms its all about arms and legs isn't it do not attempt this repair if you live at home
Posted on Aug 27, 2009
SOURCE: Compatability issues with new Ryobi Lithium Ion Batteries
i have the same problem and have returned once for replacement charger and battery, still no working well help andykrin@yahoo.com
thanks
Posted on Mar 26, 2010
  • 2448 Answers
SOURCE: Ryobi Two 18V Lithium-Ion Batteries + Lithium-Ion
You are the thrid person in the last couple of days with this same problem and i check who was posting the problems all differant people all RYOBI 18V lithium-ion batterys and they all got them for christmas. SOMETHING is not right there is now warranty on the batterys but there is one on faulty workmenship there must be a problem with this type of battery good luck
Posted on Jan 16, 2011
I have a black and decker rotary hammer drill i can only read 3 numbers of the model it is 045 but its the last three sn number 0481121 under pat 3309541 need parts manuel for
Your one sounds like this one
http://www.ereplacementparts.com/black-and-decker-5045-type-100-rotary-hammer-parts-c-4167_7879_17406.html
However there are three variants on this page.
http://www.ereplacementparts.com/black-and-decker-hammer-drill-parts-c-4167_7879.html
Black and Decker Hammer Drill Parts ' Great Selection ' Great Prices ...
  1. Cached
  2. Similar
Black and Decker 22738 Type 1 1/2-Inch Hammer Drill Parts. 22738 Type 1 Black ... Black and Decker 27106 Type 1 3/4 Rotary Hammer Parts. 27106 Type 1 ...
Black and Decker 5045 Type 100 Rotary Hammer Parts
www.ereplacementparts.com/black-and-decker-5045-type-100-rotary-hammer-parts-...
  1. Cached
  2. Similar
Black and Decker 5045 Type 100 Rotary Hammer Parts .... Drill Parts Hammer Drill Parts Rotary Hammer Parts. Search within model. SEARCH. Discuss ' Repair ...
Black and Decker Hammer Drill Parts & Repair Help ' Fix.com
https://www.fix.com/parts/power-tool/drill/hammer-drill/black-and-decker/
  1. Cached
Shop for Black and Decker Hammer Drill parts today. Find genuine replacement ... (Type 100). Variable Speed Reversible Rotary Hammer · 5014. (Type 100).
Black and Decker Parts - Tool Replacement Parts ' Tool Parts Direct
www.toolpartsdirect.com/brands/blackdecker.html
  1. Cached
  2. Similar
Black and Decker Drill & Driver-Drill Parts · Black and Decker Hammer Drill Parts ... Black and Decker Rotary Hammer Parts Model Schematics and Tool Parts ...
Black and Decker 5043K_TYPE_3 ROTARY HAMMER KIT Parts ' Tool ...
www.toolpartsdirect.com/blackdecker-5043k-type-3-rotary-hammer-kit.html
  1. Cached
Find the Black and Decker blackdecker_5043K_TYPE_3 ROTARY HAMMER KIT parts you need at Tool Parts Direct. Shop thousands of Black and Decker ...
Black and Decker Rotary Hammer Parts ' Tool Parts Direct
www.toolpartsdirect.com/hammer/rotary-hammer/blackdecker.html
  1. Cached
Replacement Black and Decker Rotary Hammer Parts online. Tool Parts Direct has thousands of Rotary Hammer Parts to fix Black and Decker tools. Shop by ...
www.toolpartsdirect.com/hammer/rotary-hammer.html
  1. Cached
  2. Similar
Tool Parts Direct carries the largest inventory of replacement Rotary Hammer Parts for thousands of make and models. Buy Rotary Hammer Parts online for all of ...
Black & Decker Replacement Parts - 1800ToolRepair.com
https://www.1800toolrepair.com/tool-repair-parts/black-decker
  1. Cached
Black & Decker replacement parts for all Black & Decker tools. ... Black & Decker Cordless Circular Saw Parts ... Black & Decker Electric Hammer Drill Parts.
Beyond Parts - Black & Decker ServiceNet
servicenet.blackanddecker.com/Parts/Detail/29096
  1. Cached
  2. Similar
Available, Add Parts to Cart ... Model #, Model Description, Parts Diagram. 5041K Type 1 · MACHO I ROT HAM KIT · 5042-09 Type 1 · HD ROTARY HAMMER.
black and decker rotary hammer drill Google Search
Dec 25, 2016 | Rotary Drills
I have a Black & Decker 12 volt cordless power/hammer drill. I think it needs a new battery & possibly changer. Can I purchase a new battery & charger or is the drill too old?
try this parts supplier
Black and Decker Cordless Drill Parts
see if your model has a parts list for battery and charger
if discontinued
look for tha same used drill in better condition
or toss in the bin
Oct 20, 2016 | Drills
My Black and Decker Drill and Hand Saw have brand new battery pack and brand new charger to BE SURE battery is fully charged but still don't work
it is probably the brushes on the motors are wore out or stuck and not making contact. pretty much junk unless you feel confident enough to attempt repair.
Dec 11, 2013 | Black & Decker Black and Decker 18V...
I have an 18V cordless drill/driver. When I tried to recharged the battery, the battery stayed dead. The red light was on while recharging. The charger stand has red and green LED indicators but only the...
Chargers will out last batteries by a long time.You will need to get a new battery. Black & Decker is a cheap household brand and does not hold up for long periods of time. I have better brands and buy several new batteries every year.
May 30, 2011 | Black & Decker 18V Cordless Drill/Driver
HI Can i still get a 1hour Ni-Cd battery charger Battery Model 5100235-09 if so where would i be able to find it . Thanks
if you could, i would check black and decker .com you can find parts and service centers close to you.or maybe at a battery depot
Sep 30, 2010 | Black & Decker Black and Decker FIRESTORM...
What is trick to changing the bits? i unlock it but cant get it out
I think it is an issue of having to pull real hard with that model. The hex bits stick a lot especially when new or using another brand of bit. Hope this helps a little:)
Farmerbear
Aug 30, 2010 | Black & Decker Black And Decker Pivot...
My old black & decker power screw driver will not accept a charge. I cannot get it charged up.
Black & Decker stopped doing battery packs for the older screwdrivers, like the 9018, some time ago so you cannot get them.
However you can still buy replacement NiCad, Sub C, 1.2v, tagged batteries that will do the job on the older 2.4v models as NiCad batteries for use in power tools are exempt under the European ban on importing NiCad batteries where used in power tools (Specific Exemption).
When you open up the screwdriver look at the positioning of the batteries and the tags/connectors and solder them together the same way.
So all you need is a soldering iron to join the centre tags together and then trim the end tags, top and bottom, to the width of the live/negative connectors and you have got a new battery pack.
It doesn't have to be pretty but after a small investment and a little effort it sure beats paying out £30 to £50 for a new screwdriver. I have done this for my older Black & Decker and Bosch screwdrivers which all work like new again.
Apr 08, 2010 | Black & Decker Pivot Plus Cordless...
I just wonder i can still get battery charger for black decker cordless drill mode is ps3600 because my old one is not working i need new one
Menards or Home Depot sell chargers for cordless power tools. Pricey, but obviously needed. The Black & Decker model battery you own should fit the newest chargers no problem.
Aug 22, 2009 | Drills
Drills Logo
321 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
