Question about Fisher and Paykel GWL11 Top Load Washer
Mw512 won't rinse properly - Fisher and Paykel GWL11 Top Load Washer
Hi my MW512 Fisher Paykel doesn't spin properly washing still comes out with water still on
could be something stopping the pump from working,, the water control is leaking allowing water to come in while spinning, outlet hose from pump blocked/kinked
and not reaching full spinning speed ( overloaded wash)
May 06, 2016 | Fisher Washing Machines
Fisher and Paykel MW512. Error Code can't be determined. Light 8 flashes as does lid lock light
exactly which lights are flashing?
http://www.fisherpaykel.com/vault/pdfs//pdf_usecares/420983_Smartdrive_UC_UD1.pdf
Mar 22, 2014 | Fisher and Paykel Washing Machines
How to remove pump MW512 Fisher and Paykel Washer
Disconnect from power & Bail out all the water you can before removing pump.
Jul 15, 2012 | Fisher and Paykel Washing Machines
Hi My mw512 fisher paykel washer won't Drain,how do i remove the drain pipe at bottom of tub? it won't seem to just pull off, des it need to be turned? cheers Michelle
I have a model 11, but I believe they are the same. The end at he outlet of the pump actually has tabs on it. Just twist and pull. Make sure the tabs are ligned up with the slots before you pull too hard.
May 09, 2011 | Fisher and Paykel Fisher & Paykel Washer
Is a mw051-u the same as mw512 please?
looking at my service manual they are different models. do you need help on it? please reply 4 more help.
May 12, 2010 | Fisher and Paykel GWL11 Top Load Washer
No the mw512 is alot newer. While they are both smart drive washers and pretty much the same in concept but they have alot of differences. Electronics, valves, top deck and different motor resistances to name a few.
Mar 19, 2010 | Fisher and Paykel GWL11 Top Load Washer
MW512 filling in spurts then goes to error.
it nneds a new Outer blance switch , cheap nd easy to fix
Jan 23, 2010 | Fisher and Paykel Fisher & Paykel Washer
Cold water will not stop filling during rinse
while the unit is filling in the warm cycle. reach behind and shut off the hot water tap.I bet the water flow stops filling, if so, you would need to change the inlet valve on the machine. You see, in warm, if the cold is not filling, you still hear the hot filling and the unit will advance. The rinse cycles are mostly "cold" only. if the valve is not opening it will not allow it to advance from the rinse section on the board.
Feb 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
