Question about HP Compaq Presario SR1930NX PC Desktop
How do i connect to wi-fi with the presario sr1930nx?
My grandmother has a modem, but we cannot figure out how to connect the pc to the internet without the extra cables. It's a secondary computer, because she already has her laptop connected to the modem directly.
    Master:
  • HP Master
  • 630 Answers
I share a wifi connected link please see and step by step follow instruction.
http://digitalunite.com/guides/using-internet-0/connecting-internet/how-connect-wifi
Thanks.
Technical Support
Posted on Feb 20, 2014
3 Suggested Answers
MediaMan85
  • 163 Answers
SOURCE: Internet Connection Issues
Very well could have toasted you network card. If everything else works, try installing a different one (and drivers) that is known to work. MM85
Posted on Jul 26, 2008
  • 76 Answers
SOURCE: desktop wont connect to internet but laptop will
Is your cable modem also a wireless router?
From my search on it, it is not a wireless router.
This means you need to attach a hub or a wireless router to your cable modem so that more than one computer can connect to the internet simultaneously.
Go out and buy a wireless router. Connect the wireless router to your cable modem.
Connect your desktop to the wireless router with an ethernet cable.
Then you should have internet on your desktop.
Let me know if this helps. Give me a good rating and vote for me please.
Posted on Mar 24, 2010
Is it possible to connect a standard DSL modem - without Wi-Fi (with 1 Ethernet port) and a DSL modem - Wi-Fi (with 4 Ethernet port) to broadcast Wi-Fi singles
Does the non wifi modem give out DHCP addresses?
Can the wifi modem be set up to receive it's IP address from DHCP?
If the answer to both these questions is Yes then that's what to do as a first step. Make sure the wifi modem DHCP service is disabled as it must NOT give out DHCP addresses.
Connect the ethernet port of the non wifi modem to one of the LAN ports of the wifi modem and NOT the DSL/WAN port. The wifi modem is not participating in any DSL connectivity at all so it's DSL light will remain off. The non wifi modem is doing the DSL duty so it's DSL light should be correctly illuminated.
May 01, 2015 | Computers & Internet
Connect motorola modemsbSB6121 to Belink N600 wireless router with out losing internet signal
Step one turn on PC directly connected to ModemsbSB6121 without Wi FI router being involved.
Step two go to Command prompt type in ipconfig (press enter)
Step three note IP address of default gateway and ip address issued to P.C.
Step four type in default gateway address into browser and log into Modem.
Step five look for DHCP Server and allocate IP addresses from at least 50 for example 192.168.0.50 starting ip lease ending ip lease 192.168.0.254
Step six connect Wi Router to P.C. via ethernet cable only - remove ModemSB6121
Step Seven shutdown and restart p.c
Step Eight go to Command prompt type in ipconfig (press enter)
Step Nine note IP address of default gateway and ip address issued to P.C.
Step Ten type in default gateway address into browser and log into Wi Fi Router
Step Eleven Change IP address on Router to 2 as example 192.168.0.2. (it has to match in that modem device would have been 192,168.0.1)
(if it was 10.0.0.1 make wi fi 10.0.0.2 make sure subnet mask is the same like 255.255.255.0)
Step twelve Change DHCP Server to off
Step Thirteen may need to set default gateway to MODEM IP address for example 192.168.0.1
Step Fourteen plug modem router into Wi Fi router may need to plug into WAN port on WI FI router .
Step Fifteen shutdown and Restart Computer
Step Sixteen go to Command prompt type in ipconfig (press enter)
Step Seventeen type in PING 192.168.0.1 (if this is modem IP address and default gateway IP addess)
All this above is to avoid IP address conflicts or mismatching
Subnet mask should be 255.255.255.0
either it uses 192.168.0.1 or it uses 10.0.0.1 make sure Wi FI router is set to different address to Modem Router.
I suspect either a clash occurs or your P.C gets a different IP range from ther WI FI DHCP server.
Happy troubleshooting !
Sep 16, 2014 | Arris Sb6141 Surfboard Cable Modem Sb 6141...
I downloaded windows and can't figure out how to enable wifi. It's like the only options are for dial-up and dsl/cable.
Turn on your computer and locate the Wi-Fi icon. This could be located on the upper row on a laptop it will have the radiation look ((())) Make sure its pressed on. The internet connection is located in the system tray in the bottom-right corner of the screen. The icon looks like a series of rectangles that increase in from left to right. Right-click the Wi-Fi icon and select "Connect to a network." You will see a list of available wireless networks. Choose a Wi-Fi network you want to connect to and select "Connect." Enter the password into the password text box if a password is required. If a password is not required, you will automatically connect to the Wi-Fi network. Click "OK." Hope this helps.
Dec 13, 2012 | Compaq Presario CQ62-219WM Notebook
How to connect to the wifi with 3g iphone
Hello Jane,
When using a Wi-Fi network with your iPhone, you may occasionally encounter the following issues,Unable to locate or join a nearby Wi-Fi network,Weak or low Wi-Fi signal strength,Connected to Wi-Fi network, but unable to access the Internet.
Tap Settings > Wi-Fi and turn Wi-Fi off and then on again. Verify that you are in range of your Wi-Fi router or base station. Confirm that your Wi-Fi router and Cable/DSL modem are connected to power and turned on. Check whether other devices (portable computers, for example) are able to connect to the Wi-Fi network and access the Internet. Update your Wi-Fi router to the latest firmware.
Jun 03, 2011 | Lands Phones
My pc details-amd semprom 3200+,mmx,3DNOW,1.8GHZ. MY INTERNET SEVICE MODEM IS WI-FI ENABAL,BUT MY PC IS NOT WI-FI. HOW ITS WI-FI CAPABLE NOW
You must purchase a Wi-Fi adapter (possibly a USB Wi-Fi adapter) & follow the the adapter's installation instructions followed by inputting the modem's SSID & passphrase (if there is one). The SSID will probably show up in a list of available networks. Just follow the adapter's instructions. Refer to the modem's instructions for logon information (i.e., SSID, encryption type (if any), passphrase (if any), WPS PIN # (if any), etc.).
Apr 11, 2011 | Computers & Internet
I have a ASUS RT N10 Wi-Fi Router. I connected the wi-fi Router to my Desktop after-which I am not able to access the Internet. If I connect my desktop directly to my ADSL Modem, I am able to connect to ...
Check to see if you can plug the wan port to your adsl modem and then plug your pc to the router. on ADSL, some ISPs will record your mac address to avoid sharing. Just see I your router supports cloning your mac. All you do is login to your router from your pc, and it should be under your Wan settings. Use DHCP unless specified otherwise, and ensure to enter any pptp login info if your ISP provided any.
Dec 27, 2017 | ASUS EZ N Wireless Router up to 150Mbps...
I have 2 routers 1 host cpu and no connection to internet geek squad installed .. i lost connection after warrenty.... 30 days .... now have to pay 169.00 for geek to check it out... many thanks ...
check the configuration ro setting...
if the modem or broadband is working very well... check the laptops why not working may you put some proxy. or change some setting..
Jun 02, 2009 | HP Compaq Presario CQ60Z Notebook
I'm having compaq presario C785TU notebook pc... i'm not able to get the wi-fi driver
be sure that your wifi driver is correct if not or cannot connect of any wireless available.. try to remove then re install again or update from the internet.
thanks
Jun 02, 2009 | Compaq Presario Notebook
Will not connect to the internet
You can only get internet from an Internet service provider.
You need to connect wi-fi point to telephone line (ASDL connection) or to modem from cable company. Otherwise you can only get Internet from someone elses Internet service provider.
Jan 04, 2009 | Toshiba Satellite A100-S8111TD Notebook
Drivers for Wi-Fi (drivers for Ethernet Controller and Modem Device on high definition audio bus)
Not much offered at Compaq's driver site for XP. For the modem driver, try the link below, it says it's for Vista, but it should work. If it doesn't then you will need the make and model of the modem, then go to the manufacturer's site or driverguide.com for the drivers, and the same for the wireless, make and model, manufacturer's site or driver guide. To be honest with you, modems are just about obsolete, unless you have dial up at home, you'll probably never use it.
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&cc=us&lang=en&dlc=en&product=3739733
Jul 09, 2008 | Compaq Presario 700 470024-192 Notebook
HP Compaq Presario SR1930NX PC Desktop Logo
114 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
