Question about Samsung SCX-4100 All-In-One Laser Printer
Samsung scx 4100 Manual feed starts printing halfway down page
Manual feed paper pulls halfway before starting print job. Prints first part of document on last part of page.
early1234
  • 871 Answers
SOURCE: samsung scx 4100 cleaning the roller
one way to clean those rollers is to take the printer apart. this would provide you with enough room to fix it and clean it.
however, if the suggestion of taking it apart does not sound good, you can still actually have that cleaned while it is turned on. as what you mentioned, you are asking how would it turn while cleaning it. i suggest that you try using the qtip and tune the printer to turned on. so that you can actually see what your doing with the roller.
Posted on Jun 03, 2008
SOURCE: Samsung ML-1610 Does not print after a paper jam
after checking no paper left on rollers etc, turn printer of for a while and then turn back on and press the paper release button
Posted on Oct 27, 2008
asish_shrm
  • 121 Answers
SOURCE: Samsung SCX-4200 manual feed prints crooked
You need to change the pick up rollers for your printer if it pulling the paper unevenly... but first check to see that the paper size adjuster on the tray i self is set to your paper likeness.....adjust to the correct paper size if not...
Please don't forget to vote!
Cheers!
Posted on Nov 13, 2008
CompuFirm
  • 89 Answers
SOURCE: Samsung CLP-315 prints half a page and then stops
It sounds like your fuser is causing the jame,.
when you remove the paper can you wipe the toner off the page or does it adhear to the paper ?
If it does not the fuser is causing the jam, if the toner does not wipe off the paper then the feed tires would be the cause of your jam
The fuser is at the back of the printer and will be very hot, so be careful.
Posted on May 26, 2009
  • 220 Answers
SOURCE: samsung ml-1710 printer continues to jam paper;
pickup roller and seperaion pad req changing
Posted on Jun 22, 2009
Print tow side on Canon LBP 800 Laser Printer
Hi
I have found both a Getting Started Guide here:
http://dl.owneriq.net/6/6b8eae44-71d6-4f7d-a01c-369b4426c2f6.pdf
and a User Manual (more comprehensive) here:
http://www.printerrecharge.com.au/manuals/Canon%20LBP-800%20User%20Manual.pdf
I've also looked through them and there is no mention of duplex printing capability, nor does the paper path shown in the manual show it as possible. The only way to double-sided printing is therefore manually. To do this
Print the odd numbered pages of the document (in properties box).
Remove the paper from the outlet and turn it over .
Replace it in the paper feed tray with the blank side facing you.
Print the even numbered pages of the document.
Please be careful to make sure that page 2 prints on the other side of page 1 and so on through the document, as it is very easy to put the one side printed pages in the feed tray with the last page, in the position to be printed first causing a complete waste of paper. Also leave the one side printed paper for a few minutes before refeeding as doing this too quickly can result in a paper jam.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 28, 2014 | Canon LBP 800 Laser Printer
My HP P2015DN only prints one page at a time. If I have a 5 page document, the first page prints and then I must print the go button for each page to print.
Is the paper feeding from the manual tray or tray 2. If you are printing from tray 2 and have this problem then it is likely that your driver or software is looking for different paper types than you have loaded in the printer. For example, if you have plain paper in tray 2 and your software wants to print on letterhead, then the printer will stop after each page and by pressing the button you are telling the printer that it is ok to print on different paper. If you have the paper in the manual feed tray (tray 1) then I would check to make sure you are telling the pirnter to print to tray 1 and not manual feed when you send a print job.
May 02, 2011 | HP LaserJet P2015dn Printer
My HP 4ML has been printing fine until recently. Every print job, big or small, the first couple of pages print the pages mostly black, then start to fade the more pages I print in the same print job. ...
You didn't say that you swapped out the toner.
Let's come back to that point later.
Put paper in the manual feed tray.
Print something.
As soon as the paper feeds halfway into the printer, open the top cover.
Pull out the toner, look down at the paper. Is it mostly black?
If the answer is yes....replace the toner.
Vacuum out the inside of the printer and print again.
I think you have a bad toner cartridge
Feb 01, 2011 | HP LaserJet 4ML Printer
Samsung CLP-315 prints half a page and then stops & jams. Interior is clean. Our CLP-315 is doing the same thing. Only had it 6 months. The paper stops printing half way through and you have to open the...
May 26, 2009 | Samsung CLP-315W Laser Color Printer
Printer does not fully pull paper...
You probably need to clean the rollers that feed the paper. Check your manual or go to Cannon web site.
Jan 13, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Page prints half page then jams
I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed throught the printer. The reason for this, in some cases I have been able to clear the paper track of debris that was deposited there over time. Worth a try. I have fixed a number of printers this way saving costly repairs. Bud
Dec 04, 2008 | Office Equipment & Supplies
Paper jam error after last page prints
Hi Natoli3,
This could be a mis-match of paper sizes. Example, computer could be sending an A4 page to the printer. The paper size in the could be set to Letter. Ensure the 4 paper sizes match, in the computer - the document and printer driver; in the printer (change in control panel) and paper tray (adjust the physical side and length).
S88
Oct 23, 2008 | HP LaserJet 4100 Printer
The Paper light keeps flashing when theres paper in the printer
A few things could be happening here.
1. Clear the print queue, and if there are jobs that won't delete, reboot the computer.
2. Now clear the jobs on the printer (cancel job button) until the status light turns green.
3. Put a piece of paper in the manual feed tray on the front.
4. Print a test page.
If the test page prints to the paper in the manual feed tray, then it is set as the default tray. Go into the printer settings and change it to "auto" or tray 1. If the test page prints to tray 1, but the original document you tried to print (when it got stuck) still won't print, cancel the job. Now, again, put paper in the manual feed tray. Try to print the document again and if it pulls from there, go into page setup of your document and change the setting from "manual" to "auto" or tray 1. Clear the job again (if it's stuck) and you should be able to print again. Hope this helps. This is one of the most common solutions - it happens a lot, especially with documents that are emailed from other people and once they get stuck in the queue, nothing will print (except the test pages directly from the printer, like you describe).
Jun 25, 2008 | Brother HL 5250DN Laser Printer
HP IIIp prints extra blank pages
HI there make sure that the paper tray guides are fully against the paper also try sending the job through the manual feed to see if you get the same problem. If you do not then it maybe that the paper cassette separation pad is worn and will need replacing. If your model has no rubber pad at the front of the cassette then you will have a metal hold over one corner of the paper make sure that when the paper lifts that the paper sits under the silver (Dog Ear) as this acts as a separator.
Hope this helps
Thanks J
Jan 28, 2008 | HP LaserJet IIIp Printer
Auto feeds crooked
Are we talking about a paper feed problem from the paper cassette tray or the Auto Document feeder on the top. Either way, check the the paper width guides, or if it is the paper cassette tray, remove it and check the paper pick up roller locking clips.
Jun 08, 2007 | Brother IntelliFax-2820 Laser Fax
Samsung SCX-4100 All-In-One Laser Printer Logo
65 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
