Question about Danze Plumbing
Eurostream faucet repair
Single handle pulldown tpye leaks when shut off position in cold only
  • 9 Answers
SOURCE: Repair cartridge in Moen Monticello single handle lavatory faucet
After some additional experimenting, contrary to information I was previously able to gather, I discovered that the white plastic retainer doesn't (in this type of Moen faucet) actually screw off but rather is held in place by a spring clip inserted from the rear of the retainer (toward the wall side of the basing). Simply sticking a small screwdriver in the opening (approx. 45 degrees downward) and tipping the screwdriver toward the front of the faucet, snaps the spring clip out through the opening.
The plastic retainer than lifts off. Note: the flat sides on the retainer suggest that a wrench will be needed but such is not the case.
Posted on Nov 28, 2008
arealplumber
  • 33 Answers
SOURCE: low pressure and flow on hot water side of single handle faucet
It could be one of two problems, one simple, one serious.
  • Easy fix
  1. Turn off hot water angle stop under sink to faucet.
  2. Remove supply line from hot angle stop.
  3. Place end of supply line in a small bucket to catch some water.
  4. Turn on cold water for a couple of seconds and backflush debris from faucet.
  5. Reconnect supply line.
  6. Turn on angle stop and test
  • Complex fix
If you have steel pipes you may be experiencing reduced flow due to corrosion in your pipes. Reduced hot water pressure in the kitchen faucet is usually the first sign since this is the faucet that is most used in the home.
Repiping is a job for a professional. Another symptom you may need a repipe is orange colored or rusty water.
Posted on Dec 05, 2008
  • 3 Answers
SOURCE: price pfister faucet handle drops and turns off.
Re the 'falling handle' issue, I think you misunderstood the problem, jgwhomeequip. Unfortunately for me I bought *two* similar Price Pfister faucets and both had the same problem - the water wouldn't stay on and the handle just wouldn't stay up.
I took mine apart looking for something to adjust, fruitlessly. Put it back together and have lived with it like that for ~2 years.
Finally I decided to not be a knucklehead any longer and call the manufacturer. Once I got through to their rep (on a Saturday no less!) she helped me identify the model I had (a 533-50SS, just FYI), and asked me 'what finish'? I replied 'stainless steel' and she promptly replied, 'I'm going to mail you out new lighter handles to replace the ones you have'.
Brilliant! Gold star for PP for standing behind their product well past the warranty for what was apparently a common problem. Replacing the handle will take about 10 seconds per faucet.
I only wish I had got of my a$$ and called them 2 years ago.
1-800-PFAUCET (1-800-732-8238)
Consumer Service Department:
7:30am to 4:00pm PST, Mon-Sat
Fax: 1-800-713-7080
Hope that's helpful to somebody.
Posted on Apr 04, 2009
  • 129 Answers
SOURCE: Moen Single Handle Shower Faucet-turn on get cold, little hot
You can try to rotate the first plastic ring to the left of center a few teeth, this will let the handle advance alittle more to the hot side.
Posted on Oct 10, 2009
  • 3 Answers
SOURCE: Single lever kitchen faucet with pull out sprayer is leaking.
same here..some duct tape should do the trick or you can pay for a repairman
Posted on Jan 01, 2010
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    Getting hot water when shower valve is first opened.
    If I understand correctly, you have single handled shower faucet.
    Normally there is a wait for hot water to arrive at faucet.
    But now hot water is already at shower faucet.
    Single handled faucets have a mixing area inside valve where hot and cold come together before going into sink.
    This mixing valve can have crossover where the hot and cold can pass through to each other even when faucet handle is off. When single handle faucets get old, this can happen.
    How it happens:
    For example another faucet is turned on inside house, and pressure differential between hot and cold causes hot water at shower handle to pass through mixing area and into cold water line.
    So if another faucet has been run, then that lets hot flow to faulty single handled shower faucet.
    To confirm this is the problem: turn on other faucet and put ear against shower faucet to listen for moving water.
    This condition may also signal there is a water leak.
    The problem is not harmful, but will draw cold water into water heater each time, and is energy wasteful.
    Replace faucet or have plumber repair problem.
    Feb 19, 2011 | Price Pfister Single Lever Handle Faucet...
    Leaky eurostream kitchen faucet
    if its leaking under the handle, all you need to do is remove the blue and red cap on the handle under you will find a 1/8 allen screw, loosen screw and remove handle and tighten the brass nut a little which will seat the packing underneath.
    Jun 19, 2010 | Plumbing
    My faucet is leaking from the pulldown where the hose is conected to the spout ive tried to take it apart is there a special way to take it apart
    before you take it apart ,I want you to check,the pullout handle first,because most of the time ,all that is wrong is that little1/2-5/8 in washer between the handle and the hose,It usually runs down the hose ,and might apear to be something else leaking under the sink.If your correct,and it is leaking where you said.Some of the newer faucet have a clip that just pushes together.So you need it fing the clip,and push it in.
    Apr 12, 2010 | Price Pfister Ashfield Single Control...
    Faucet is leaking from the cold water line inside the faucet. it is a danze lazio pull out kitchen faucet
    Hello
    First shut off water to faucet.There should be a allen screw that holds the faucet together near the top back of the handle,lossen this and pull top off.
    Next take some pliers and tighten down the lock nuts to compress the washers,do this gently.
    Reassemble,water should stop leaking.
    Mar 30, 2010 | Danze D403412 Melrose Single Handle...
    No water flow. just stopped completely.
    Some times just jigle handle rapidly on and off detach pull down faucet from hose chec for clogs or debrie on screen, try for water with still detached. Turn valves to off position under the sink, then turn them on slowly to see if they are working. if so witch is very likely, try to blow back through the faucet hose with the handle on, to try and break up the clog.
    Oct 27, 2009 | Moen 87555C Trianna Single Handle Pulldown...
    Kitchen faucet Remove
    All faucets have a hot and cold line input. The single handle units have a mixing valve within the handle. Aside from removing the water lines there is usually some type of connecting bolts for the base plate as well that will need to be removed prior to removing the faucet. Do not forget to turn the shut off valves off at the wall before you remove the water lines.
    Good Luck
    Dec 03, 2008 | Plumbing
    Plumbing Logo
    18 people viewed this question
    Top Danze Plumbing Experts
    David Wiebe
    Level 1 Expert
    Donni Steen
    john h
    Are you a Danze Plumbing Expert? Answer questions, earn points and help others
