Question about Horizon Fitness Horizon T102 12 Program Treadmill
Treo T102 Belt runs and no noise but the speed does not pick up to match the speed on the monitor. Please can someone help explain how I fix this. Thank you
I have bought a Treo T102. The belt runs and no noise but the speed does not pick up to match the speed on the monitor. Everything else seems fine. Please can someone help explain how I fix this. Thank you
2 Suggested Answers
roadtech7
  • 293 Answers
SOURCE: The running belt motor does not work, everthing
You need to pull the motor hood off to see if the belt is still on the motor. If it is and the motor is not turning, check the controler ( located on the otherside of treadmill) and you should see a red light on. When you tell the treadill to go.... the red light should start to flash, if it does then you need a new motor. If it just stays lit, you have lost communication from the console ( the upper controls ), and need to find out if something came dissconnected.
Hope this helps
Posted on Nov 10, 2010
How long does it take for someone to help me, on this site.
How fast you get answers depends on many factors. I just picked up your question but have spent time finding and reading the manual. I am by no means a treadmill expert, but my first thought was treadmill belt tension was too loose to keep the movement sensor happy.
Moving the belt manually would be irrelevant as the electronics would not be monitoring to throw up the E1 Error..
The manual tells you to check all these things.
E1
Loss of Feedback Speed Sensor disconnected Check Speed Sensor
Connection
Speed Sensor Misaligned Check Sensor position
Faulty Speed Sensor Replace Speed Sensor
Loose Display Connection Check Display Cable
Connection
Faulty MCB (D2 LED on) Replace MCB
Faulty Drive Motor Replace Drive Motor
If BH Fitness are being no help, I would be asking them to take the machine away or get it fixed on-site.
So does the belt turn when you switch it on? Is the belt centrally aligned when it spins?
Page 35 shows belt adjustment and I would guess tension although not specifically mentioned.
http://www.bhfitnessusa.com/manuals/final/ts2.pdf
Jan 05, 2016 | Bh Fitness TS2 Folding Treadmill
THE MACHINE RUNS VERY WELL QUIET UNTIL THE FINAL SPIN CYCLE THEN FROM THE BACK OF THE MACHINE THERE IS A SQUEAL THAT GETS LOADER AS THE SPEED PICKS UP
This may well be the drum drive belt in the back of the washing machine. This belt transfers drive from the motor to the drum for both wash cycles and spinning. If the belt is slipping slightly on the pulley then a squeal may well be heard on the spin cycle and will change in pitch as the speed of the drum increases. At lower speeds (wash cycles) the belt probably won't slip. I don't personally know of this model but there is usually a tension adjustment nut/bolt near the motor to tighten the belt and stop it slipping.
Dec 26, 2013 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Can i change the model T101P3 timer from 110 to 220?
1) Yes. Change clock motor from WG1570 to WG1573
Wiring is same as T102 timer:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T102
http://waterheatertimer.org/How-to-replace-Intermatic-clock-motor.html
2) If new pump motor is 2-speed, then converted T101P3 cannot handle 2-speed pump.
Use T106 timer, or T1906 timer:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#2-speed
http://waterheatertimer.org/How-to-wire-T1906-Intermatic-timer.html#pool
3) New T106 or T1906 timer mechanism will snap into T103P enclosure without changing boxes.
Any intermatic timer will snap into Intermatic enclosure.
Other brands of timer can adapt to Intermatic enclosure using Tork IAP adapter bracket.
Mar 10, 2013 | Hardware & Accessories
Speeds up and slows down
Dear Sir:
Please adjust the sensor speed for the main motor. Of course I am recommending Very Strong to RUN the software calibration for easy diagnose and troubleshooting.
Otherwise see my personal TIPS, for diagnosee
Trouble.
sincerely. God bless you
ernesto cuadra
managua, nicaragua. c.a
Mar 06, 2012 | Nordic Track NordicTrack A2550 PRO...
A high pitched whining noise in the engine.
This Noise Description sounds Indicative of the Sounds that come from the Serpentine Belt Or Related parts such as Belt Idler Pulley or Belt Tentioner witch also has a Pulley, but if Tensioner itself is Literally BROKE I've replaced a number like this it will cause a Whining noise . Best case scenario its just the Belt, and if any of the other Problems turn out to be the Culprit the Belt MUST be Replaced Anyhow as Damage is Being caused By the Very Whining you hear.
PLEASE Spend the Extras $ for the BEST BELT as this Drives your Water pump, Alternator, A/C Compressor, Power Steering Pump All Crucial to Control of, easy Steering ,All Electrical-Power Distribution, The COOLING of Engine << VERY CRITICAL Component
The Pulleys usually have a more Hum type Whining. So I would say at Best The BELT , And WORST Belt Tentioner is Broke
Jan 14, 2009 | 2002 Dodge Caravan
Palm treo HELP!!
I have the programming to get in but it'll be easier to explain over phone with the instructions... just let me know...
Jul 24, 2008 | Palm Treo 600 Handheld
CPU fan races
turn up the task manager to monitor the cpu load. use ctrl shift esc to bring it up. now open up an application. see as the cpu meter goes from low to full green (high).. then check if the fan also speeds up. i guess you have a cmos setup on the motherboard that monitors cpu load and speeds up the fan.
as for the usb -speaker, please explain further..
May 20, 2008 | Car Audio & Video
Noise problems
This is a common problem, the solution is actually called the "Treo Buzz Fix".
Earlier models of the Treo 600 had an unshielded cable that connects the battery to the main board. This cable causes loud buzzing and interference on the Treo.
If your treo is under warranty (unlikely probably...) then send it back to Palm for replacement.
If not, try the fix. The fix involves disassembling your Treo and wrapping aluminum foil around the offending cable. Here is a guide:
http://mytreo.net/treofaq/BuzzFix
And here is a forum on MyTreo with high resolution pictures of the process, to help you:
http://mytreo.net/forum/index.php/topic,54886.msg429525.html#msg429525
This is a somewhat dangerous procedure. It is possible to damage your treo if you aren't careful. Follow all instructions EXTREMELY carefully.
Good luck! And don't break your Treo!
Nov 20, 2007 | Palm Treo 600 Handheld
Horizon Fitness Horizon T102 12 Program Treadmill Logo
Top Horizon Fitness Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
L Pfaff
L Pfaff
Are you a Horizon Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
