Question about Brinks Locks & Locksmithing
Can open padlock with key the barrell wont move
By mistake I have locked my american tourister luggage bag and now I can not open it I forget the 3 digit combinations. How I can unlock it
Few standard combination locks are machined to such a high degreee of precision that when the lock is put under strain one or more of the numbered rotating dials is not left a little loose while the other(s) become tight.
It is a matter of slowly turning the tight dial or barrel until it becomes loose. At this point the lock will move a little as long as it is kept under strain and one of the other numbered barrels that was previously a little loose will become tighter and so it is time to slowly turn this barrel and repeat until the lock releases.
Practice on something like a cheap cycle lock and you will discover the trick that is increasingly difficult as the quality of the lock improves.
It takes a light touch and lots of patience. So far I have even opened a quite expensive combination padlock this way but it relies on imperfect manufacture. It would be quite impossible to use the technique on a perfectly made combination lock.
Oct 02, 2016 | Locks & Locksmithing
I have a Brinks padlock model TSA007 it has a keyhole but it didnt come with a key, can i purchase a key just for backup?
That key wont do anyting but allow TSA to open that lock. You cannot get that key because it is a master key that opens all those locks and it is restricted.
Jan 22, 2014 | Brinks TSA Resettable Padlock
I have a mazda 323 1994. i put a ignition in it but now the key wont turn. ?????
If you put a new ignition switch in it is possible that the pins in the barrel are sticking and are not moving as they should.. take the key out and put powered graphite in the key hole and move the key in and out a few times and that lubricates the pins.. If it still will not turn then best check that the key is correct for the barrel .
Oct 01, 2013 | 1994 Mazda 323
95 Polo 1.6 GLX ignition problem
sounds like the electronic part if the ignition is going bad
Dec 16, 2012 | Cars & Trucks
Unlock scooter seat
Try some lock cleaner\ lubricant, use liberally, press down gently on the seat locking latch. If that doesn't work try shocking the mechanism with my favorite tool, a rubber mallet. If the key turns that part of the mechanism works. Put the key in to the release position. Go to where the latch is, use a bright light, see if the latch is engaged, Usually this kind of lock uses a hook latch. The hook is literally apart of the key barrel so if the barrel moves the latch hast to be moving too. Check the chair itself that its not stuck. WARNING Lubricate with pure silicon spray only it wont stain your chair. Lub all rotating joints and see if you can move it.
Hope this helps
Jun 21, 2012 | Health & Beauty
Keyboard has a padlock image on a key. what is that?
press FN (function key) button plus closed padlock -- it will lock keyboard -- to unlock press FN key + open padlock
Oct 23, 2011 | Compaq Presario CQ62-215DX Laptop
My van is showing an picture of the van with a padlock thru it, and wont run?
Immobiliser fault.
Try putting silicone grease on the wiring loom connector to the pick up ring on the barrel assembly
Dec 01, 2010 | 2001 Pontiac Montana
Unlocked padlock showing and machine wont stop
It thinks the door is still open
So either it is or the door interlock switch is broken
Jan 17, 2010 | Washing Machines
Just purchased a verbatim 4gb usb drive in a plastic case with a little red and green padlock on the side of the case, how do you open it??
From what I have seen on Google images there should be a plastic slider down the middle that needs to be moved to the Green padlock. The Red padlock will mean data locked the Green open.
Jan 02, 2010 | Computers & Internet
Car wont lock
spray excess WD 40 or similar onto the key whilst moving it in & out of the lock or dribble it down a toothpick/cocktail stick in to the lock or hold the lock open with the stick and spray into the lock barrel
Sep 02, 2009 | 2006 Peugeot 604
Locks & Locksmithing Logo
29 people viewed this question
Top Brinks Locks & Locksmithing Experts
john h
andrewcahoon
Are you a Brinks Lock and Locksmithing Expert? Answer questions, earn points and help others
