Question about Brother LS590 Sewing Machine
Ls-590 brother sewing machine stuck in reverse
5 Suggested Answers
Mimito7
  • 128 Answers
SOURCE: bobbin case on brother sewing machine
Well, from the picture I see that your bobbin is a front load as opposed to a top load.. if you tilt the front panel down, you will see where the bobbin and casing goes. Put the bobbin in the casing with the thread pulling from the right hand side of the casing making sure the thread in guided into the small **** on the top edge of the casing.. On the back of the casing the will be a small tab. Pull that away from the casing and enter the casing in to the opening for the bobbin. It should snap into place when you release the little tab.
Posted on May 29, 2009
  • 96 Answers
SOURCE: brother sewing machine sews in reverse only
you will need to have it serviced sounds like an internal issue with the dial
Posted on Dec 13, 2009
SOURCE: can't draw up the bobbin thread
I have the same problem...I have been sewing for many years, and I think I know how to thread a sewing machine! I'm with this person...IT JUST WON'T PICK-UP THE THREAD ...my machine was new, only used it a few times, then one day....it quit woking, it just will not load the bottom thread, I have tried everything, but to take it to a shop.
Posted on Dec 27, 2009
SOURCE: brother sewing machine ls-30 will
Check the needle to see if it's damaged
Make sure the bobbin has a 3-5 inch thread tail
Then make sure the top thread has a 3-5 inch tail
Then hold the top thread tail with your fingers (away from the needle)
& use the hand wheel on the right hand side of the machine to slowly
Lower the needle in the bobbin area & see if the bobbin thread will pick
Up that way
Posted on Sep 27, 2010
Reverse switch not working anymore?
the reverse gear could be damaged or come loose,, it would be a good idea to have the machine checked
Oct 15, 2013 | Brother LS 2160 Sewing Machine
My brother ce8080prw machine will not stitch in reverse and is stuck in abasting stitch. how do I reset?
My machine was also not sewing in reverse and stuck in a basting stitch. It was a simple fix. Unscrew the plate and remove any pins stuck in there. All fixed
Nov 04, 2012 | Brother SE-270D Computerized Sewing...
I have a Brother LS-2250PRW and I can't get the machine to start stitching. Sounds like it is stuck in neutral.
Sounds like you have the bobbin winder pushed to the right, push it back to the left and your machine will go.
Feb 19, 2011 | Brother LS-2220 Mechanical Sewing Machine
My Brother LS-2125 does not stitch forward - only in reverse.
What stitch selection have you made, anything to do with the buttonhole? If, so make sure that you let it go through the cycle then, pick a straight stitch pattern with a longer stitch length. You can also go online to brother-usa.com and see if there are any other suggestions
Sep 16, 2010 | Brother LS-2125 Mechanical Sewing Machine
Lever is stuck in reverse
If the stitch length bar, which is located on the right side of the machine, is in the up position move it down to where the numbers are. Those numbers are referring to how many stitches the machine will sew in an inch. Therefore, if you put it on 10, your machine will sew 10 stitches per inch. It being up will cause your machine to go in reverse.
Jul 26, 2009 | Brother LS-1217 Mechanical Sewing Machine
Brother LS-2125 presser foot stuck
i bought a new brother stiching machine ls2125. when i started to stich the same no stiching is coming only the mark is coming. why?
Sep 24, 2008 | Brother LS-2125 Mechanical Sewing Machine
Reverse lever
lever must be locked in. if possible, you must open it and try to look for something blocking it. maybe a faulty spring or something.
Nov 24, 2007 | Brother LS-1217 Mechanical Sewing Machine
Brother LS590 Sewing Machine Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
