Question about Things Remembered Personalized High Gloss Mahogany Spinning Clock Gift
Replace battery in things remembered high gloss mahogony clock
How to install the battery on the high gloss mahogony clock
How to reset danbury clock chime
There are so many different battery clock movements, with entirely different setting mechanisms, that I will have to answer generally. If your clock has three batteries, it is probably an older movement and may be worn out (just a possibility).
First, check the movement for a chime shut-off switch or a night-off switch. Some of these clocks have lots of switches and controls and it's hard to notice them all.
Make sure that all batteries are new and fresh, and installed in the correct direction. Use ONLY alkaline batteries. Sometimes batteries marked "heavy duty" are really old fashioned acid batteries. Never use rechargeable batteries of any kind!
Many battery clocks, especially the older ones, have setting mechanisms that are extremely complicated. It is almost impossible to get them set up without an instruction manual. Sometimes every step must be followed in order to get the clock chiming. If you don't have one, I would attempt to get one from the manufacturer (not always an easy thing).
If all else fails, you can replace the whole movement. The replacement will not be identical to the original one. You try to get one that is compatible, then some modifications to the mounting system in the case may be necessary. You can get these from clock materials houses.
Mar 26, 2015 | Danbury at Things Remembered Home
Danbury clock 'things remembered'. How do I access the battery? I cannot figure out how to find the battery. The battery is dead after two years and I need to replace it. It is not obvious how to...
The things remembered clock is just tension fit in the housing. Easiest way to get it out is to get a plastic suction cup. Press the suction cup onto the face of the clock and pull and jiggle till the clock comes out. This way you wont gouge up the wood trying to pry the clock out with a screwdriver. It takes an N cell battery: https://en.wikipedia.org/wiki/N_battery
Jan 31, 2014 | Watches
We changed the paper type in tray 3 to high gloss and need to change it back to regular paper but we can't remember how.
Open and close the paper tray 3.The tray information screen will be displayed.Select CHANGE SETTING on the touch screen.You should now be able to change your setting.
Oct 20, 2011 | Xerox WorkCentre 7328 Multifunction laser...
One of my speakers is not charging. How do i replace the battery.
the batterys are not replaceable because they are rechargeable please contact the manufacturer i hope this helps
Jul 26, 2011 | Griffin Technology Griffin Evolve Wireless...
I replaced battery and how i can get my clock
hmmm....well my question to you would be did you install the battery corectly....remember the neg cable comes off first and goes on last if you reverse the installation procedure you can blow fuses or worse....i would check the fuses and keep my fingers crossed
Nov 27, 2009 | 2001 BMW 325
Replaced battery - need to reset clock / radio won't play
My manual said the same thing. Although I have never had the radio stop working on me even after I changed the battery. To set the clock you hold the mode button, like your changing the bass/ treble. Hold it down then it will show clock flashing. From there I cant remember i think i used the arrows by the number pad to change the time. Hope this works for you.
Oct 30, 2008 | 2003 Jaguar X-Type
RCA RP5420 auto set is not working
mine was doing the same thing, it had bad batteries!
Jul 02, 2008 | RCA RP5420 Clock Radio
Audio system failure after service station installs new battery in EX,4cyl,4dr
No, i don't think its a code issue, maybe the player is not fit with the car, that things happening, i recommend on sony's players, they are strong and high quality players.
Jun 18, 2008 | 2005 Honda Accord
Things Remembered Personalized High Gloss Mahogany Spinning Clock Gift Logo
144 people viewed this question
Top Things Remembered Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Things Remembered Audio Player and Recorder Expert? Answer questions, earn points and help others
