Question about Indesit Washing Machines
Hi. I have an Indisit Washing Machine IWDC6125 The fault is that the power light does not illuminate. Power to the machine. Thought it was the door latch switch, replace it but. Still have the. Same fault. Help please or can someone send my a wiring drawing
  • Steve Brown
    Steve Brown Nov 04, 2015
    I have same fault 0 did you get a resolution?
    New Friend:
  • 11 Answers
Good probability the carbon brushes in the motor will be very low .before initiating a cycle the on board diagnostic runs a quick test on the appliance components .if it detects no circuit over the com ie brushes low it immediately goes into fault mode and won't start
Posted on Feb 16, 2014
IB4G2008
  • 3587 Answers
SOURCE: Bosch Washing machine WFB 4001
well, seems to me that you are using too much juice for the circuit, which implies a SERIOUS issue with the machine. perhaps the motor is locked, or something in control panel is shorted out?
Posted on Feb 27, 2008
jsrock516
  • 5911 Answers
SOURCE: Washing Machine door latch replacement
Go to searspartsdirect.com and type in your model number. The door latch assembly can be found under the "Door and Latch Parts" heading as item number 7 (part #8181700). If you need instructions on how to replace, just follow this link:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
If you do not wish to purchase parts online, use the part number provided and go to your nearest appliance parts retailer. I hope this helps you.
Posted on Jun 19, 2008
SOURCE: washing machine fault
hi mine flashes when you are aloud to open the door so i cant see this as been part of you problem sorry cant help more
Posted on Jan 08, 2009
barkencoa
  • 3463 Answers
SOURCE: fault code h20 flashing on indisit wie127 washing
H20 is indicating a problem with the incoming water supply to washer.
Check the inlet hose/s for kinks or other restriction, ensure that you have a good pressure to the washer, make sure tap/s are fully turned on.
If all o/k,then could be a problem with the inlet valve/s
Please rate my solution.
Thankyou.
Posted on Jan 21, 2010
SOURCE: Gallery washing machine door latch stuck in lock p...
I have the same problem with my Gallery. I can not open it at all. I have tried unpluging it and putting it through another cycle to see if it will open. No such luck. Any suggestions?
Posted on Nov 08, 2010
The lock on the door has broken how much is a replacement
Hi Janine, door locks don't cost a lot I have had to buy one a year ago it only cost me £8-00 i fitted it it was easy,but again it depends on the washing machine type mine was an Indisit and it again depends on if you are fitting it or you are getting a washing technician in.
good luck
Mar 01, 2015 | Washing Machines
Indesit iwdc6125. All 5 top lights flashing and rinse and door lock lights are on. Does this mean the module needs programming?
The door lock is faulty. I removed the top cover and removed the red control box from its nylon casing on the lock. I then broke the locking mechanism. Leave the control box connected or it won't work. My machine works but no longer locks so could be a problem if you have small children.
Mar 29, 2012 | Indesit Washing Machines
Hi there - I have an Indisit IDL 705 model and it will not start. There are no warning lights and I have checked all of the suggested potential reasons for this including, power, water and door. Thank you
If there is power , the door switch is good and the water pressure is fine then the possible fault can only be the program controller unit.
You will need to check the voltage on the board, check the panel settings and see if the program is executed. If not this seems the prime suspect.
Jun 14, 2011 | Indesit Dishwashers
Door light no working so machine will not start
check power is getting to machine with suitable electrical screw driver.to do this remove top from machine and check live wire just inside rear of machine. fault could be door lock if you have power in machine
Feb 05, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Replace brushes in an indisit washing machine
Remove the rear panel of washer.
Remove belt from motor, unplug lead to motor, remove earth wire.
Undo screws securing motor, and remove motor.
The brushes are located at the opposite end to the motor pulley, you will see a wire going to each brush.
Thankyou
Feb 02, 2010 | Washing Machines
My hotpoint wf540 will not start a cycle it very quicly steps to wash light showing but nothing happens door locked light is not illuminated.Just prior to this fault the fuse in the mains plug had blown.I...
1st you need to know if power is getting to machine, Next could be door interlock switch faulty the fact the fuse blew indicates possible short circuit/ excess current draw occured also check motor brushes assuming machine fills with water 1st
Nov 05, 2009 | Washing Machines
Washing Machine door locked with flashing red light above on/off button, the model is a Indisit WD12X, there no water in machine and pump is cleaned with no obstuction. can anyone help with this problem
Try turning off the machine at the plug for about 10 minutes or until the light on the machine disappears, then try to open the door.
Usually works for me.
Regards jonno
Apr 04, 2009 | Washing Machines
Fault with Ariston Washer/Dryer
Make sure the filter is clean, its behind the front bottom panel which just pull off, then unscrew the filter thumb wheel until it comes out. Check it is clean and replace, Now unplug the machine and set the programme to your normal start setting leaving the door open. Remove the screws retaining the back panel and unplug all the connectors to the circuit board found in the bottom left hand corner. Turn the power back on ensuring the red LED illuminates and leave for 2 or 3 minutes before unplugging the power again and reconnecting the circuit boards and replacing the back panel. Reconnect the power and turn the machine on, close the door and with luck it will work. If this does not clear the fault repeat the process again or look on ebay for a new machine!
Oct 13, 2007 | Washing Machines
Washing Machines Logo
70 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
