Question about Dayton 2NRX6 Rigid Self Supported Dbl Cool Air Duct
Dayton 4z906A vacuum
When turn on, whining. think something caught near motor. Can't open unit, no manual. Thanks
Vacuum cleaner turns on but has no sucking power.
The belt might have broken if something has clogged the brush head.
Lay it down on the floor and you should see two screws either side of the brushes.
If that doesn't help, you need to tell us what vacuum cleaner you have cos you haven't said.
Mar 09, 2016 | Vacuums
Why is the roller brush spinning half heartedly and making a hesitant whining noise. It's not really picking up anything.
May have a faulty wire or there could be something rapped around the spook at the end jamming it enough to strain the motor and slow the spinning
Aug 27, 2014 | Fantom Vacums XT450K Upright Vacuum
The roller is not turning after i caught up a frayed carpet string.
This could be because of 2 things on this model.
1) the model MAY have a white reset button on the side of the unit that the hose does not go into. Sometimes to prevent a toothed belt from damaging the motor.
2) the belt may need to be changed on the unit usually noticed with a burning rubber smell when you caught something. this just requires a belt change.
Nov 03, 2010 | Eureka 3276AZ Pet Lover Bagless Upright...
Decreased suction and high pitch whine in motor
clean out suction tubes ther is something caught in them
Dec 13, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
I have a Toro Super Blower that I use to vacuum maple leaves; not easy when the leaves are wet. Its the beginning of the 3rd season and the plastic impeller has many vanes broken off and the motor...
You "might" be able to go to a Toro dealer and get a new impeller, or try to find a used one on E-bay or similar. Sometimes the whine is caused by something caught and obstructing the impeller.
Oct 24, 2009 | Toro Blowers Rake and Vac - Electric...
My Hoover Deluxe Rewind Elite will not pick up anything. My daughter got something caught in it last night and it made that noise when you get something hung. We turned it off but today it will not work....
When you are saying "today it will not work" do you mean the motor runs, but the unit will not vacuum, or are you saying nothing happens when you try to turn it on?
If the motor run's, the belt probably broke. You will need to remove the bottom of the vacuum part that rolls on the floor, get a replacement belt, and install. Check your owner manual for directions and belt part numbers.
Jan 15, 2009 | Vacuums
Less suction and high pitch whine while vacuuming
most any vacuum repair shop will be able to remove the obstruction causing the problem
Jul 29, 2017 | Dyson DC14 Animal Bagless Upright Cyclonic...
Burning smell and smoke
When you turn it on....is the belt turning the brushes? Something may be caught causing the brushes to stick and the belt to just grind the brush assembly.
Jan 03, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Dayton 2NRX6 Rigid Self Supported Dbl Cool Air Duct Logo
14 people viewed this question
Top Dayton Wire Wheels Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Dayton Wire Wheels Vehicle Part and Accessory Expert? Answer questions, earn points and help others
