Question about Pioneer VSX-D511 Receiver
My Pioneer d512, give a poping sound on the speaker before shutting down and showing Amp Error. It actually blew up one of my speakers.I opened it up, tested a few components and they seem ok. I put e
It actually blew up one of my speakers.I opened it up, tested a few components and they seem ok. I put everything back except the bolt hat bonds the speaker out put with the chasis. then the amps switches on and play for about 30 second and the popping sound again but no amp error. When I replace the screw tha binds the speaker output to the chasis ground the amp error appears immediately and the amp goes to standby. When I use my DMM to test if there's any shorting connection between the red and black and red and ground, everything looks clean. Any ideas? Lolo B
SOURCE: pioneer vsx-d511 amp error
I've had the same problem for over a month and have yet to find the time to get to it. However, I there may be a fuse on the circuit board that needs to be replace. That's just my guess.
Hope it's the solution.
Posted on Sep 17, 2008
  • 30 Answers
SOURCE: pioneer receiver vsx d814 amp error
The Pioneer VSX-D814 has a couple of Power Hybrid bricks that do all the power amplification. These are the infamous PAC011A. You should have 2 of those in your receiver.
If the amp detects some unusual activities, it may shut down the unit to prevent damage. “Amp Err” usually means some DC in the output.
Disconnect all the speakers and turn on the unit; if it acts normal, reconnect speakers one set at a time very carefully. If the unit still shows the error message you can try to reset it. If the reset works, again carefully reconnect the speakers connections. If the reset does not recover the normal operation of the unit, you may have one of the PAC011A damaged, and the unit will need repair.
The reset can be done by disconnecting the unit power cord for a few minutes, then plug it in and press “FRONT ENTER key + ADVANCED SURROUND key” continuously for 2sec.
Good luck
Posted on Apr 02, 2009
  • 233 Answers
SOURCE: Pioneer VSX-D511 Comes up with AMP ERROR and shuts down
I must agree that if the fuses are open and you replace them that your problem maybe fixed. If you can remove the fuse, I recommend taking it to a RadioShack and see if someone there can figure out what it is. I am going to assume that the fuse should be a 250 V. If you can find one that matches the same appearance, go with the smallest aperage rating you can find. Go with this route only if the person can not tell you exactly what it is you need. Be sure to match the type of fuse if you can see inside it like in the case of a glass fuse. Some are slow-blow fuses and some are fast-blow. If you are uncertain your safest bet is to use a fast-blow with a real low amp rating for the voltage you are using. If the amp rating is too low, it may run fine at lower volumes and pop when you turn it up. If I could physically see the fuse, I would probably be able to tell you what it was and what you needed to replace it with.
Posted on Jun 06, 2009
  • 30 Answers
SOURCE: PIONEER AMP ERROR
Most probably you have one of the power amplifier modules bad. They are the PAC010 and PAC011 type. You can remove one and power up the receiver. If it powers-up normaly it's that one.... (50% chance) Otherwise remove both and it should power up normally. Beware that these parts are expensive... Most times just with a new part the problem is solved. YMMV. Good luck
Posted on Aug 02, 2009
  • 16 Answers
SOURCE: Pioneer VSX-517 was turne up lou. Showe
THERMAL SHUTDOWN PROTECTORS MAY BE BLOWN
Posted on Nov 03, 2009
Amp shutting down when volume gets too high
Easy! You either have a surround speaker wired backwards or there is a break in the wire leading to a surround speaker that is allowing the +&- to arc together. your amp shutsvoff as a protection to keep the arc from reaching the mother board. replace your wires man!!
Nov 29, 2012 | Pioneer Audio Players & Recorders
I have a pioneer vsx 07 11 and it says amplifier error
You see, the error message is coming from the power protection circuit which is constantly monitoring current being drawn from the receiver power supply. When the current exceeds the trip level it shuts down and give the error message.
power amplifiers has been shorted and the output transistors (one or more) have gone into breakdown and causing the excessive current drain. This will happen even though the speakers may not be connected to the amp outputs.
Jun 05, 2012 | Pioneer Audio Players & Recorders
Pioneer amplifier vsx-d512 overload message
This indicates the audio output stage in the receiver is loading down and triggering the overload protection circuit to kick in. Check the speaker wires for shorts, if okay! you will need a professional to assess the cost for repair.
Mar 31, 2012 | Pioneer Audio Players & Recorders
My subwoofer keeps poping and then stops working
larryagross,
Sounds like you blew the speaker! The amp is sensing the voice coil is connecting to the speakers magnet or iron core and is going into a safe mode. It is possible to blow the coil even when the sub has a built in amp.
First make sure that you have the gains properly set ans not all set to their maximums. Second, disconnect signal to the sub then unplug the power for a few minutes. Third, plug the sub into a source of power on a different circuit using a surge protector.
Does the speaker make any popping at the time it powers up? If so you have a amp problem. If there is no sound produced, connect it back the the system using a different signal cable. Does the speaker now pop again when sound is produced. If so the speaker has failed. Contact a Velodyne repair facility.
-Chris
Aug 10, 2010 | Velodyne CT-80 Subwoofer
How to wire the Pioneer Premier 12in. dual 2 ohm voice coil. 1000 watt rms 3500 watt peak, and I have a 1000watt JL audio 2 channell amp, they are both stable at 1 ohm. I wired them parrallel, and it blew...
If you have two subs to connect, place the speakers next to each other face down, you will notice that the connection points run in sequence +- and +-. Now connect the - (negative) from the one speaker, to the + (positive) of the other speaker. Now connect the open + from the one speaker and the open - from the other speaker to your amp.
If you have only one speaker it should be bridgeson your amp.
Your amp should have a bridging indication. On the connection points of each channel on the the amp, you should see a mark pointing to the first - and the last +. That will be your bridge
May 09, 2010 | Pioneer TS-W3004SPL Premier 12" SPL...
Pioneer GM-7200M power problem
Check your GROUND wire might be touching something and making bad contact.
Jun 09, 2009 | Pioneer GM-7200M Car Audio Amplifier
Poping sound coming from pioneer amp
whitrashtruk,
Your M-91 has a 8 ohm rated amp. Your CV's are 4 ohm speakers. When your reduce the resistance the amp see's it requires the amp to work harder and will max out at much lower volume knob levels.
Simply put, you have big speakers that require big power. You receiver is not capable of providing the big power you need and will only cause damage to your speakers and receiver.
Buy a larger dedicated amp for your speakers as you will never hear the full potential of your CV's from any receiver. Both great components; just not a good match for each other.
-Chris
Dec 30, 2008 | Pioneer Elite VSX-91TXH
Pioneer receiver vsx d814 amp error
Good luck
Dec 18, 2008 | Pioneer VSX-D510 Receiver
Amp Err
please check all speakers cables for short circuit-disconnect all speaker-put volume low-wait and observe it if no shut down -go to next step-connect your speaker one by one until you find the bad one,start with speaker cable(try another good cable) and then speaker.if shut down happened again while you connect nothing to your system you will have inside problem and ask for service center to fix it.
Jul 07, 2008 | Audio Players & Recorders
No sound
You might have a bad speaker. The internal amp shuts itself off if a problem is detected with a speaker. disconnect all of them and then reattach one at a time to find the problem speaker. If you can't get sound out of ANY of them then you blew the output chip which will require a repair shop.
Sep 11, 2007 | Pioneer AVH-P6500DVD Car DVD Player
Pioneer VSX-D511 Receiver Logo
27 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
