Question about KitchenAid KSB560 5 Speed Blender
The control went crazy - KitchenAid KSB560 5 Speed Blender
  • KitchenAid Master
  • 1,238 Answers
Motor is probably open circuit, that is the main cause of the flashing lights. New motor OR replace the thermal fuse on one of the field windings if you are up to the task.
Posted on Jul 26, 2014
I went to plug in my bullet and it won't turn on.
There's 3 tabs on the inside of the base that get pushed down when you push the cup in. Two of them have switches on them, sometimes they can break. Make sure they are being pushed down. If not, it could be one of the switches inside.
Apr 09, 2015 | Magic Bullet Nutribullet Blender
I bought a new interlocking collar for my Kitchenaid blender, and now it doesn't seem to be fitting on the base properly. It's resting on the base rather than going all the way down, if that makes sense....
Remove the collar from the jug and have a good look inside, there is a circular ring inside the collar that needs to engage correctly with a glass finger on the jug. The glass finger goes between 2 plastic fingers. I think there are two of them. It was a silly idea that's been given the flick on later models.
Mar 02, 2015 | KitchenAid KSB560 5 Speed Blender
Drive socket
you can check this out, maybe what you're looking for?
Amazon com vitamix wrench assembly Home Kitchen
Feb 19, 2014 | Vitamix Blenders
The motor went on my 1750 handheld blender the first time I used it. Where could I find the motor? How much is the motor
if you have the part number off the motor you took out then try http://www.a1service.com/toastmaster/toastmastermotor.htm
Jun 15, 2010 | Toastmaster 1750 Handheld Blender
How to make a smoothie with my bamix handheld blender
That wonderful little stick is all you need, I sure love mine! Make sure your Mixing cup is larger than the one supplied and remember to pump up and down vigorously as you blend. Keep swirling the bottom to make sure everything got picked up and blended. You can also make powdered salt,(great for french fries) powdered sugar, Dried garlic can be made into your own freshest garlic powder (great for spaghetti and pizza). peanut butter, apple butter and Whipped cream. I also use mine to make a crazy Jello only treat that tastes like sherbet, ice cream and Jello just by blending Jello and Ice cubes. Then I chill right away after pouring it into small 3 inch glasses.
Mar 13, 2010 | Bamix Mono Single-Speed Handheld Blender
Black and Decker BL3900 stopped working
I had the same problem with BL6000 model. After using the blender few times it went dead, though on occasions it ran for a couple of seconds or so. I opened the base and saw the red light come on and off in response to pressing the buttons, but the blender would not run. I checked the connections and resistances across various points, and then decided to bypass the digital control panel by joining the blue (AC) and black (motor) wire terminals, as the control panel must be altering the frequency or voltage going across this connection into the field coils (and also to rotor). The motor is rated at 120V. The motor ran perfectly, though i let it run only briefly, confirming that it itself is all right. I think one must check a step further by studying the current and voltage characteristics to ensure that the motor does not consume more than rated 550 watts if you do not wish to buy the digital control panel ( part number BL5000-01-01, available through partstore.com or black and decker partner site. It should fit BL6000 as per partstore.com). The motor seems like an univeral motor. If anyone knows more about motors and has the same problem, then pl let me know if bypassing the digital control panel and using an external switch to shut the motor on and off is a good idea (digital panel and shipping will buy an equivalent blender in stores, about $18). I am afraid that if digital control panel does not let unregulated power be delivered to the field (and rotor) coils, then one may be putting too much power into the motor and it may burn out prematurely.
Oct 15, 2008 | Black & Decker BL5000 ProBlend Work Top...
Blender blinks
need to resolder the triac located on the Printed circuit board this part is on an aluminum heat sink, and the third leg is most of the times the one with a broken or poor soldering joint due to the vibration of blender
Dec 27, 2007 | KitchenAid KSB5 Professional Stainless...
KitchenAid KSB560 5 Speed Blender Logo
91 people viewed this question
Top KitchenAid Blenders Experts
Appliance engineer
eyecam
Are you a KitchenAid Blender Expert? Answer questions, earn points and help others
