Question about Yamaha RX-V675
Powered down wont restart
Turned amp on . ran for a couple of minutes then turned off . restarted and turned itself off straight away . Now wont restart . Can only see red flashing light by mains switch but will not power up .
  • 66 Answers
Switch off from wall. this is a protection safety thing you need to have it repaired if the power from the wall does not fix it.
Posted on Apr 19, 2014
5 Suggested Answers
SOURCE: Amp powers off after switching on
the last click you hear before the amp turns on is the power relays for the amp circuit,these have 2 very small copper contacts inside them which after much time get corroded and cause high resistance when they try to power up the amplifier circuit.awkward to get to and desolder but can be opened up and serviced,done mine and a few friends with yamaha amps which use similar system,had no problem since,also worth checking for dry joints around amp chip i.c legs onto main board.
Posted on May 02, 2008
trainrick
  • 22 Answers
SOURCE: Cannot Power Up, Sometimes can
i had a real nice yamaha natural sound receiver and the relay that switched it on went bad a lot..... try the relay???
Posted on Apr 26, 2010
dunnbiker
  • 8546 Answers
SOURCE: tuner works fine, but occasionaly turns itself
Just the tuner stops working or the whole receiver?
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and
operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by
the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient
ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan
(if equipped) is running as designed (some only operate on demand). Clean dust and debris
from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection
cycles in their lives so continuously resetting or cycling their power without addressing the
cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections
and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not
come up the problem is internal and should be left to an experienced and competent hands-on
tech.
Check for loose speaker connections at the speaker as another possible root cause for
intermittent shutdown.
Posted on Jul 10, 2011
hattonhall
  • 349 Answers
SOURCE: you had a post that said you had fixed faulty power relays on DSP-a1 - how do you identify the relays that need cleaning?
That your amp does not go into the second stage of powering up indicates a fault which is causing it to sit in non-active mode. This could be due to blown output audio module or transistors or a fault in the safety circuit itself. It is not a fault the non-technician can repair and it would need to be sent to an authorized workshop.
I have seen situations where users unknowingly leave frayed ends of wire shorting across the speaker output terminals which can lead to this sort of fault. You could check this out also.
Posted on Oct 28, 2011
My ps3 starts as nprmal but after 2 or 3 minutes the red light flashes and it shuts down but will restart straight away but shuys down again
Sounds like an overheating problem. Keep it away from dust and try to clean the fan out. Happened to me a couple of times till I took care of the fan
Sep 07, 2011 | Sony Playstation 3 (PS3) Console
'Please wait every couple of minutes'
Have you tried to restart or shut down and turn it back on?
Apr 02, 2010 | Acer Windows Vista TL-562G Notebook
Horizontal lines across whole screen
Bad inverter, or a dirty one. Remove the power cable and battery, then take apart the screen bezel, or casing. Remove the LCD by unhooking it. Disconnect the inverter. Clean it. Reconnect it. Fixed.
Feb 01, 2010 | ASUS Eee 1000H Notebook
Samsung HL-S5086W Television. 3 yr old. Never serviced. Last evening the TV started turning off by itself. It would turn back on easily and run for a few minutes. I unplugged a new Wii game that was...
Dont worry, the problem is coincidental to you installing the Wii. You need a new lamp.
What you are seeing is the lamp ballast/power supply attempting to start and restart your lamp. The resistance of your lamp to it's power source has increased to the point that it is shutting down, but has not blown out yet. You can find these at justlamps.com
Good luck
Jan 04, 2010 | Samsung HL-S5086W 50" HDTV
Works good for 2 minutes, Then shuts down & light goes red. Remote wont restart , so turn power off then on, Works again for 1 minute then shuts down. Panasonic PT-AE900U... projector
change the Bulb if that does not work it could be a power supply or power supply regulator this should be done by a professional except the Bulb
how many hours of operation does the unit have ??
Sep 21, 2009 | Office Equipment & Supplies
Turns itself on and off
Hi. when a Mobile phone continues to power up and immediately powers down, this will most likely confirm a internal programming fault within the micro board. this is not common but, it is known. the internal micro board, once unstable, will try to reconfigure itself by restarting over and over until it can load in the correct manner. If its unsuccessful in this attempt, it will continue to restart over and over. The best solution here is to send this unit back to the provider or send it to Samsung for reprogramming. Im sure the circuit board is fine but, the software has become corrupt for some reason and , this is the reason for the erratic shutdowns.
Please rate and god bless:)
Apr 08, 2009 | Samsung SGH 600 Cellular Phone
Truck wont restart when it's ran for greater than 5 min.
Will it restart warm if you hold the accelerator to the floor?
Apr 02, 2009 | 2000 Ford Ranger SuperCab
Mt 1999 concorde lxi shuts down and after 1 to 4 seconds restarts
it sounds like your computer wont take your key. best thing you can do is take the car to the dealer.
Dec 19, 2008 | 1999 Chrysler Concorde
Laptop intermittently turns off
I think this the virus problem have youantivirus with you otherwise please download free avg and scan your system
Thanks
T.Boopathy
Sep 15, 2008 | Computers & Internet
Yamaha RX-V675 Logo
665 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
