Question about Frigidaire FAFW3511KW Affinity 3.5 Cu. Ft. Front Load Washer, Classic White, Stainless Steel, 7 Timer Offs/Different Cycle Selections, Advanced Rinse Technology, Automatic Temperature Control, Automatic Water Level Adjustments, UPC 012505379741 FAFW3511-KW FAFW
I have an Affninity front loader. Everything works find, it just doesnt spin. I took all the clothes out, and its like the drum is stuck. The belt is in tact, and the door sensor is fine. What else could it be?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 102 Answers
If it gives you Error ? if no, check some program or choice has feature that only drain out without spin, otherwise check the pressure switch
Posted on Feb 17, 2014
SOURCE: Doesn't spin the clothes dry on the final spin but spins at high revolutions without a load of clothes
I have read that if the pump is not draining the tub completely, there is an interlock that prevents the high speed spin from engagin. I have had debris caught in my pump several times (kids!!) with similar issues. There is a trap on the line leading from the tub to the pump which is "supposed" to capture debris, but it doesn't work all that well. Check your pump.....
Posted on Dec 23, 2007
aborcass
  • 2651 Answers
SOURCE: Noisy Spin Cycle
frigidaire frontloader infamous for rear bearings going bad,NOISY is probable an understatement. I wold open door and grab hold of inner tub, try to lift it up a bit, problably a bit of play in there, thats an indication of bearing failure, call authorized servicer possible warr parts
Posted on Feb 22, 2008
SOURCE: Frigidaire front loader washing machine won't spin...
just had my frigidaire fronter loader repaired,,try the door switch ...mines wouldnt spin clothes were soaked did everything else fine... what may have happen is when the spin cycle is ready to do its part it double checks to see if door is locked but with a bad switch it sends the wrong signal and computer this the door is open so it shuts off....well gl mines is running got lots of laundry to do,.,,,hope this helps
Posted on Sep 24, 2008
docjohn174
  • 943 Answers
SOURCE: drum makes loud noise when spinning
HI thanks for the question. Frigidaire has a life time warranty. on that part .call them. thanks the appliance doc. please rate my answer. thanks.
Posted on Oct 09, 2008
  • 572 Answers
SOURCE: front loader frigidaire wont spin or drain final
in the bottom panel theres a coin trap
Posted on Feb 06, 2010
May tag front loader is not draining all water from drum when washing clothes. What could cause that to happen?
Either the controller is not working properly or the spin cycle is not turning the drum fast enough to extract the water. Slipping belt?
Sep 20, 2017 | Washing Machines
Older Whirlpool front loader machine busted belt
it sounds like your bearings have seized and the reason that the drum is turning from the front but not from the pulley at the back is your "spider" or the y shaped metal support that connects the drum to the shaft that has the pulley on it is broken. this is a difficult repair which usually takes me about 3hrs. now you say that the machine is tripping your safety switch,i think that the steel drum, when it broke the support damaged the element .has it been noisy on spin? to repair this problem you need quite a few parts. now to verify that the drum has separated from the support is to turn the drum from the front and if the pulley at the back does not move; then the support is broken. hope this helps. please reply for further help if needed. good luck
May 26, 2010 | Washing Machines
Loud clanking noise during spin cycle. Will not
If it is a front loader, then remove the rear panel, remove the belt, and soin drum by hand, if it feels rough, or is noisy and rumbling, then the main drum bearings have failed.
This is a major repair.
Feb 01, 2010 | Whirlpool LHW0050PQ Front Load Washer
Front loader washer machine not rotating.
Fisrt, see if you can rotate it by hand, BOTH directions. It should have some resistance. If you can spin it and when you stop pushing it will turn a full turn, your drum belt is too loose. If the belt is good and tight, it will spin less than one half rotation, there is probably something blocking one of the wheels that the drum rides on.
Nov 16, 2009 | Frigidaire GLTF2940ES Front Load Washer
Front load GE Washer 3 years old. wont wash or spin but does everything else.
It gets clothes stuck between the drum,(I wish I could have my old top loader back!! This is a pain 2months and I had my first repairman out I bought brand new now we fix it atleast once a week ourselves!!!!!
Jul 10, 2009 | Bosch Exxcel WFO 2465 Front Load Washer
Whirlpool Duet Front Loader won't get up to spin speed
Careful of overloading the front-loading washers. Too much of this will result in the bearings in the drum to go bad. When this happens, the rpms on the drum slow down due to belt slack. You can only see this with the back off of the unit and in the middle of the cycle. They do not sell replacement bearings...you'll have to buy the whole drum (bearings pressed inside) and for 1/2 the cost of a new washer. I hate front-loaders. I'll never buy one again.
May 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Haier front loader 1400 spin
check to see that pump is not blocked stopping water getting away quick enough
Mar 16, 2008 | Haier XQ8M22-C PORTABLE TOP LOAD WASHER
Frigidaire FAFW3511KW Affinity 3.5 Cu. Ft. Front Load Washer, Classic White, Stainless Steel, 7 Timer Offs/Different Cycle Selections, Advanced Rinse Technology, Automatic Temperature Control, Automatic Water Level Adjustments, UPC 012505379741 FAFW3511-KW FAFW Logo
61 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
