I have a Coby Tv model LED 3217, My unit only operates from the remote. I cant turn it on or off using the television its self. has else had this problem. Some one please help me out.
SOURCE: hitachi model cu4601b/k
I had this problem in a 46UX50B (I think that's the model), and it turned out to be some capacitors in the power circuit(?). After the service guy replaced those, it hasn't failed to come on since.
Posted on Apr 17, 2007
SOURCE: Power comes on then goes back off.
A tech wants to charge $89 just to troubleshoot. So how much will convergence cost?
Posted on Dec 15, 2007
Luvlee
  • 59 Answers
SOURCE: television hlp5063wx/xaa model No
This is very common in Samsung DLPs. The DMD board may be going bad or it could be one of the fans that cool the engine while it is running is going bad (even though the fan looks like it is running, it is not running fast enough to cool the engine). Just before it shuts down your picture should read at the bottom of your screen which fan is bad. But I have found that does not alway happen.
Posted on Mar 23, 2008
Slinteriors
  • 8617 Answers
SOURCE: television wont power on
Is the led blinking? If so please let me know how many blinks its making before pausing for a second.
Posted on Apr 13, 2008
leethedeuce
  • 4472 Answers
SOURCE: I am trying to feed
First try cycling through all the channels. Or on the remote it should say something like input or something else like that. What does it say near the jack on the tv that you plugged the camera into. Maybe say video 1 or something.
Keep me posted,
Lee
Posted on Jun 17, 2008
Model #3217. Why doesn't remote work?
Try removing batteries and pressing all buttons in case one is stuck. Reinstall batteries and try again.
Apr 09, 2016 | Televison & Video
Tip
ERROR CODE AND SERVICE MODE
Service tool modeHow to access
1. Select [SRV-TOOL] in Service Mode.
2. Press [OK] button on the remote control.
Display of SOS History
SOS History (Number of LED blinking) indication. From left side; Last SOS, before Last, three occurrence before, 2nd occurrence after shipment, 1st occurrence after shipment.
This indication except 2nd and 1st occurrence after shipment will be cleared by [Self-check indication and forced to factory shipment setting].POWER ON TIME/COUNT
Note : To display TIME/COUNT menu, highlight position, then press MUTE for (3sec).
Time : Cumulative power on time, indicated hour : minute by decimal
Count : Number of ON times by decimal
Note : This indication will not be cleared by either of the self-checks or any other command.Exit
1. Disconnect the AC cord from wall outlet.
Hotel mode
1. Purpose
Restrict a function for hotels.
2. Access command to the Hotel mode setup menu In order to display the Hotel mode setup menu, please enter the following command(within 2 second).
[TV] : Vol. [Down] + [REMOTE] : INPUT (3 times)
Then, the Hotel mode setup menu is displayed.
3. To exit the Hotel mode setup menu Disconnect AC power cord from wall outlet.
Troubleshooting Guide
Use the self-check function to test the unit.
1. Checking the IIC bus lines
2. Power LED Blinking timingCheck of the IIC bus linesHow to access
Self-check indication only:
Produce TV reception screen, and while pressing [VOLUME ( - )] button on the main unit, press [OK] button on the remote control for more than 3 seconds.
Self-check indication and forced to factory shipment setting:
Produce TV reception screen, and while pressing [VOLUME ( - )] button on the main unit, press [MENU] button on the remote control for more than 3 seconds.
Exit
Power LED Blinking timing chart
1. Subject
Information of LED Flashing timing chart.
2. Contents
When an abnormality has occurred the unit, the protection circuit operates and reset to the stand by mode. At this time, the defective block can be identified by the number of blinks of the Power LED on the front panel of the unit.
FOR MODE DETAILS CHECK THE FOLLOWING LINK
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
USE SEARCH TAB TO FIND MODELS OR USE DROP DOWN MENU
on Jun 30, 2015 | Panasonic Tc-50ps14 Tv Power Supply Board...
How do you remove "Key Lock" in Coby TV model LEDTV2928T?
Control It All With Universal Remote Codes ยป Digital Landing
www.digitallanding.com/control-it-all-with-universal-remote-codes/
Oct 22, 2012 - Why not set the universal remote codes and make life easier? ... Here are some GE codes for some of the more popular TV brands: ... Aiwa-0414; Coby-0926, 0946, 0947, 0916, 0445, 0928, 0894; Denon-0400, 0421 ...
Aug 12, 2015 | Coby Televison & Video
Tv and remote problems
Hi, in order to try and narrow down the search for the specific code you need, would require more info about the TV your looking to control. IE Size of the TV 19", 22" etc. Also, it may be useful if you can find any model number on the TV which can be used to minimize positive results on the codes that operate that specific model of TV, as codes for the same brands of TV's will vary according to the Size or Model Number. - Once this information is known, it will then make it easier to find the Remote Controls user guide, which features the code to use with the TV your looking to program the remote for :-).
If you do find the info required, you could try searching for the remote control user manual your self using google, or just provide the info if your struggling, and I'll use what tools I have to see if I can dig it up for you :-).
Cheers
Apr 29, 2013 | Televison & Video
Coby led tv code for chunghop universal remote
pls. help me to find code using universal remot for my coby ty model LED 3226T
Aug 08, 2012 | Televison & Video
I need the TV remote code for a coby tv
Here are the codes for your Coby TV: 500, 503, or 00.
I have provided instructions on how you can program the remote to your TV:
  • Remotes: Basic (Television Only)
    1. Turn the Television On.
    2. Press and hold the clear TV button for three seconds until the LED flashes.
    3. Enter the three-digit code using the buttons on the number pad.
    4. Press #. Note: The LED will flash three times.
    5. Test functionality with the TV.
    6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Aug 17, 2011 | DISH Network 721 DVR Remote Control
The remote code for Dishnetwork to work a coby tftv 3217 tv?
U have tp call the company for the code then program your remote
Aug 09, 2010 | Televison & Video
I neees codes for this remote
Coby is not listed. You need to do a search as follows:
On the remote control pressTV on
Press set and hold until LED blinks twice, then release SET
Enter 9 - 9 - 1. The LED will blink twice
Aim remote control at the TV& slowly alternate between pressing POWER and TV. Stop when the TV turns off.
Note: Om search mode the remote will send IR codes from its library to selected device, starting with the most popular codes first.
To lock in the code, press & hold SET until LED blincks twice, then release SET.
To search for codes for your other devices repeat above steps for approperate device.
Feb 15, 2009 | One For All URC-4330 Remote Control
Remote code for Coby TV/DVD
If you are a DirecTV or Cox subscriber, you may sync a universal remote to your television using code 1548 or 11548.
These codes are for use with the following Coby television models:
TFTV1022, TFTV1212, TFTV1513, TFTV1514, TFTV1524, TFTV1913, TFTV1923, TFTV2214, TFTV2224, TFTV2617, TFTV3217, TFTV3717, TFTV4717
If the codes do not work, or if you are not a DirecTV or Cox customer, the universal remote control manufacturer is responsible for creating and embedding a Coby-compatible code in the remote control. Please contact your cable carrier or the universal remote control manufacturer for assistance.
Mar 25, 2008 | Televison & Video
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
Electro Med Services...
