Question about Jeep 2006 Commander Limited 4WD
Blowing cold air instead of heat - Jeep 2006 Commander Limited 4WD
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 10 Answers
I can think of two possible causes 1 very serious the other no cause for concern just uncomfortable in winter time. the first and most serious is that your radiator is out of water. your heater circulates engine coolant thru your engine and heater core from your cooling system for your engine. if no water there isnt anything to flow thru engine so no heat. simple enough if this is the case you probably have a good leak somewhere in your cooling system ie hose or water pump or radiator its self. the second possibility is that if car is used and or there has been work done on the car then probably the heayer core has been bypassed the reason for doing this is because the heater core is located deep inside the dashboard and in- side of fire wall. part is cheap but labor hours are long and expensive usually around 5 hours at $88.+ an hour it is just cheaper to undo the radiator hose that flows coolant from your engine into the heater core and bypass the hose to just flow straight back in to the engine. this will keep engine from overheating and make your heater blow straight outside or vent air. btw if you have a leak in cooling system get repaired asap obviously over heating will cause catastrophic engine failure. hope this help
Posted on Feb 17, 2014
My Honeywell thermostat isnt keeping my house cool even though the temp is set to 69. Currently 90 degrees in here
Its probably not the thermostat. The air conditioner may be stuck on heating mode. If its a reverse cycle, the reversing valve may be jammed so even when the thermostat is calling for cold air, it stays on heat. If the machine is on heating mode, it should be blowing cold air out of the outdoor unit of the air con. If its on cooling mode, the outdoor should be blowing hot air.
Apr 12, 2015 | Honeywell Heat/Cool Thermostat
Fan works but heat blows cold enough to make icecycles
Heater core is most likely plugged/restricted
Nov 30, 2013 | Saab 9 3 Cars & Trucks
2007 ford fusion, heater blows cold air most the time
its probably low antifreeze. or your heating core is going out or your thermostat is sticking and may need to be replaced
Jan 16, 2013 | Cars & Trucks
No heat from vents
As per your problem mentioned. There are few solved help links to troubleshoot these problems. Go through the list and Click the link below:----
2000 Toyota Avalon: No heat on Passenger Side?
http://whatisbyme.blogspot.in/2012/05/2000-toyota-avalon-no-heat-on-passenger.html
No heat on Oldsmobile Silhouette?
http://technoanswers.blogspot.in/2012/02/no-heat-on-oldsmobile-silhouette.html
Heater blows cold?
http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
Heat blows cold on drivers side and hot on passenger side?
http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html
Hot air on the driver's side vents only?
http://repairhelpcenter.blogspot.com/2012/01/hot-air-on-drivers-side-vents-only.html
Temperature gauge does not move and no heat when heater is ON?
http://technoanswers.blogspot.com/2012/01/temperature-gauge-does-not-move-and-no.html
1992 Toyota Camry: A/C Control light Flashing and A/C not Blowing Cold?
http://technoanswers.blogspot.in/2012/04/1992-toyota-camry-ac-control-light.html
No heat, blower blows only cold?
http://technoanswers.blogspot.in/2012/02/no-heatblower-blows-only-cold.html
Ford F150 Ac only blows through defrost vents?
http://technoanswers.blogspot.com/2012/01/forf-f150-ac-only-blows-through-defrost.html
Dodge A/C come out of defrost vents only?
http://technoanswers.blogspot.com/2012/01/dodge-ac-come-out-of-defrost-vents-only.html
Ac vacuum line on dodge cummins?
http://technoanswers.blogspot.com/2012/01/ac-vacuum-line-on-dodge-cummins.html
Ford ranger AC blows cold through defrost vents instead on cabin vents?
http://technoanswers.blogspot.com/2012/01/ford-ranger-ac-blows-cold-through.html
2005 Chrysler PT Cruiser: A/C Blows Warm?
http://whoisbyme.blogspot.in/2012/06/2005-chrysler-p8t-cruiser-ac-blows-warm.html
2009 Mercury Grand Marquis: A/C blows Cold From Defrost Vent Only?
http://whoisbyme.blogspot.in/2012/06/2009-mercury-grand-marquis-ac-blows.html
AC not blowing through Vents on 2007 Chevy Trailblazer?
http://schematicsdiagram.blogspot.in/2012/04/ac-not-blowing-through-vents-on-2007.html
Passenger side temperature is warm air out of dash vents?
http://schematicsdiagram.blogspot.in/2012/04/passenger-side-temperature-is-warm-air.html
These will help.
Thanks.
Nov 28, 2012 | 2006 Ford Taurus
My is heat is not work?My car is blowing cold air instead of hot air, I have a brand new heater core,the thermostat is not sticking,I got anti-freeze in it,It's getting cold in I need heat.Please help me
first feel the heater core hoses see if both are hot if so then your problem is in the blend air door must be stuck on cold. is your blower motor blowing cold air if not your blower motor might be the problem. the blend air door is down by the blower motor.
Nov 17, 2010 | 1995 Oldsmobile Cutlass Supreme
2004 mercury mountaineer.heat problem When turning ac knob to heat clicking sound like door opening and closing repeatedly sounds and air blows cold instead of hot.
Sep 13, 2010 | 2004 Mercury Mountaineer
Getting heat instead of cold
probably the evaporator is not good,and also there is no gas in the the circuit and when it blow air its only heat is coming out
Aug 22, 2009 | GE Zoneline AZ25E12D3B Air Conditioner
Jeep 2006 Commander Limited 4WD Logo
63 people viewed this question
Top Jeep Car Audio & Video Experts
xxxxxx xxx
Tom Chichester
Oloyede Monsuru
Are you a Jeep Car Audio and Video Expert? Answer questions, earn points and help others
