Question about GE 106585 Upright Vacuum
Belt rotator heat
After changeling belt ,the belt heat up and broken
  • GE Master
  • 1,492 Answers
Something is probably restricting the brush roll from spinning freely. Make sure both end caps rotate free.
Posted on Mar 03, 2014
The turbo tool for pet hair on my Hoover power vac doesn't rotate. I removed the brush and cleaned but still doesn't work. Suction is fine without the tool attached.
Have you checked the drive belt on the pet head? Mine comes apart and a thin belt is driven by the propellers which in turn drive the brush head via the drive belt. To check turn propeller and see if brush head rotates if not belt missing broken / jammed
Oct 21, 2017 | Hoover Vacuums
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
Auger beater bar won't turn.
did you check the belt?
Nov 27, 2015 | Vacuums
My rotating brushes have stopped rotating
Almost certainly you have broken a drive belt. It is not a big deal though just turn it upside down and remove the base plate you should be able to access the belt from there. You should be able to get a belt pretty easy from an online retailer like vacuumspot
May 07, 2012 | VAX Appliances Vacuums
The carpet brush stopped rotating. Is there a quick fix? It rotates by hand and does not appear to be jammed in any way.
Make sure that all plug ins are correctly attached. Remove botton plate to determine if the rubber belt is broken. Replace belt if broken
Please vote if my information is helpful or not. Recommended. Thanks UAW Local974
Jun 26, 2011 | Vacuums
Beater bar not turning
The number one cause of the "beater bar" (or brush roller) not rotating is a broken belt.
The number two cause of brushes not rotating is that something is jammed & wound around the roller, preventing it from rotating.
For the belt: If you remove the screws holding the bottom plate, you should see one (or maybe two) short, wide rubber belt(s) that goes around the roller.
If this is broken, it's easy to replace. They do break because of age and wear. One of the leading causes of breakage is when the roller gets something - a curtain cord, for example - wrapped around it. If you don't immediately shut off the vacuum & remove the cord, the belt will continue to try to turn the roller (which can't turn), and this generates a lot of heat in just a few seconds.
You can find belts at places like Sears, Home Depot, or your local vacuum shop.
For just the roller: Turn the vacuum over on its side and inspect the roller. Will it turn? Can you see something wound around it that's jamming it? While you here, take a minute and clean the roller... including using scissors or a knife to snip & remove wound hairs & threads. A clean and healthy roller will help to keep your belt happy!
Mar 03, 2011 | Cirrus CR99 Bagged Upright Vacuum
Our brush doesn't rotate anymore on our U5402-900 vacuum cleaner. What are common causes of this?
The number one cause of brushes not rotating is a broken belt. If you remove the four screws holding the bottom plate, you'll see a short, wide rubber belt that goes around the roller.
The number two cause of brushes not rotating is, as suggested above, something jammed & wound around the roller. It's always a good idea to turn the vacuum over periodically and clean the roller... including using scissors or a knife to snip & remove wound hairs & threads. A clean and healthy roller will help to keep your belt happy!
Mar 03, 2011 | Hoover Vacuums
Belt not broken.... brushes will not rotate.
most have two belts, brush roll rotates only when head is level with the floor....
Feb 19, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
My brus on my Dyson won't turn after some fringe got stuck in it.
You sound like you've broken your belt! If the roller gets stuck the pulley that rotates the belt will have burnt a hole in your belt and broken it. You'll need to contact your local Dyson to obtain parts,
Mar 09, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Bosch vacuum
check the belt, it might be stretched or broken
or carpet fibers and hairs may have clogged up the brushes to keep them from rotating
let me know if this isn't the problem
Mar 22, 2008 | Bosch Turbo Jet Bagged Upright Vacuum
GE 106585 Upright Vacuum Logo
Top GE Vacuums Experts
Gerry Harvey
Gerry Harvey
T bone 1963
Are you a GE Vacuum Expert? Answer questions, earn points and help others
