Question about Globe Union Home
Hwo to replace the cartridge in a global union shower faucet
  • 10865 Answers
SOURCE: Sterling shower faucet
The problem is that the supply lines feeding that faucet are reversed. That is the cold supply line is feeding the hot side of the faucet and the hot supply line is feeding the cold side.
The fix is to reverse the supply lines where ever they can be most easliy accessed.
Posted on Apr 14, 2009
  • 659 Answers
SOURCE: Parts for sterling shower faucet
http://www.sterlingplumbing.com/contact.strl
The above link is the contact info for Sterling Plumbing Company. You can contact them and they will either be able to mail the parts out to you directly or tell you where you will be able to find repair parts.
Posted on Apr 17, 2009
SOURCE: single knob for shower and tub wont stop running
I had the same problem, you need to shut off your valves and remove the handle that turns the water on and off. You need to turn the chrome front piece counter clockwise to remove it from the front of the unit. Pull the ball out and you should see 2 rubber o-rings with springs inside. My guess is that you have a bad o-ring that should be replaced. After you buy the kit from your local Home Depot, Lowes etc, you install the pieces the same way you removed them!
Posted on Jul 01, 2009
  • 297 Answers
SOURCE: Moen Single Handle Shower Faucet leak...
the cartridge if defective,replace it and your leak will stop.
Posted on Jul 24, 2009
  • 81 Answers
SOURCE: need an instruction sheet for
This link will get you to the Danze illustrated parts list for the Sheridan single control tub and shower valve.
http://www.danze.com/products/pdfs/D510055_ip.pdf
Posted on Aug 08, 2010
Why is my Moen universal shower faucet leaking at the union
It sounds like you know what you're doing, but if it has O'rings, try replacing those. If there is a snug fix with the valve then the leak is a problem with the inner workings of the cartridge.
Nov 23, 2015 | Moen & One Handle Tub & Shower Faucet
My shower head comes on all the time
two possible causes. 1- make sure the valve body is installed with with shower mark on the valve body facing up. 2 - if you used pex pipe and fittings to stub out for the tub spout this will restrict the flow sending water to the shower, '' change out pex pipe and replace with copper or galvanized pipe
Apr 06, 2014 | Globe Union Glacier Bay 8 In Double Handle...
Need an instruction sheet for cartridge replacement for Danze Sheridan tub and shower faucet
Aug 08, 2010 | Danze Sheridan Tub & Shower Faucet
I need to replace diverter. Please halp me. Shower faucet Danze mod.D113000BT. Thanks. A problem is a leaking woter from shower had and body .
Better to replace complete spout. Shut off taps, look up under spout close to end closest to wall for an allen screw or phillips (usually) and loosen it off and slide spout off. Or if it's a threaded on one, turn spout counter clockwise. If it's slip on, clean copper pipe good before re-installing, and add a little vaseline or similar lubricant to help slide on better and won't damage "O" ring.
Jun 08, 2010 | Globe Union Lavatory Faucet
& Replacement Cartridge : tub faucet leaks when shower is on...
Sounds like a bad diverter. Depending on what faucet you have some are on the tub spout and some are built on the valve. Both types can be repaired or replaced. I hope this helps.
May 18, 2010 | Moen & Replacement Cartridge
Faucet is leaking. Can you tell me if this is a
yes it is a cartridge replacement,the cartridge is,should be all that you need to replace.you did not list what kind of faucet. so here is a few number's. some bath/shower valves' take#1225-(plastic) this is also use'd in some kitchen,lav, model's.two handle faucet's#1224,the "posi-temp"#1222 is a tub shower only,there are cartridge puller's available,and recomened them,one is made by moen,another by brass craft,i have pulled cartridge's with out,so it is up to you.hope this help's.
Nov 03, 2009 | Moen & Replacement Cartridge
How to remove the cartridge from my pegasus shower/bath faucet. the instructions are not very good.
remove handle , unthread collar , same with chrome body base . make sure water is turned off from valve
Oct 18, 2009 | Union Pegasus F1228100PBV Series 5000...
Jul 22, 2009 | Moen & One Handle Tub & Shower Faucet
Home Logo
57 people viewed this question
Top Globe Union Home Experts
Donni Steen
Tom Chichester
Are you a Globe Union Home Expert? Answer questions, earn points and help others
