Infocus litepro 550
I conect my Infocus LitePro 550, to my HP Laptop computer, but the Infocus can't project the computer image. What can I do to make it work?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 729 Answers
1, the VGA cable or your laptop is something wrong
2,the interface boar (on the mother board) of the projector is broken
any questions, feel free to ask me
have a nice day!
Jerry Lampdeng Limited
Posted on Mar 04, 2014
3 Suggested Answers
  • 6 Answers
SOURCE: Need Drivers
Specifications Display Type Active Matrix LCD Brightness Lumens 300 Contrast Ratio 100:1 Native Resolution Compatible Resolutions VGA (640 x 480), SVGA (800 x 600), Computer Inputs 26pin (Y cable for HD15), HD15, 2 x RCA (L,R stereo audio), RS-232, Video Inputs 2 x Composite video (RCA), 2 x S-Video (4-pin mini din), 2 x Video Audio RCA (L,R stereo), Other Inputs Microphone XLR-type Outputs Stereo audio (RCA L,R), Video Compatibility NTSC, PAL, SECAM, HDTV Support none Audio 2 x 5-watt stereo Lamp Type 400W Halogen Part Number SP-LAMP-LP Life 40 hours
Make sure that your PC/Laptop source resolution is set to VGA (640x480) or SVGA (800x600)
Posted on Nov 19, 2008
SOURCE: looking for parts for infocus litepro 730
i have an infocus prolite 730. the image projected is not sync'd. so there are 'shadows'. does anyone know if this can be corrected?
Posted on Dec 30, 2009
I own an InFocus Litepro 570LS. The projector light bulb blinks on and off.....I do not know how many hours are on the buld and the spare buld is burned out....what is a possible fix.
Given that the bulb actually lights up and then goes out you need to check the contacts at the base of the socket to ensure proper contact is consistently made at the base of the bulb. Be sure to unplug the projector prior to inspecting and adjusting.
May 17, 2011 | InFocus LitePro 570 LCD Projector....
Infocus projected image is distorted
check the screen resolution settings in visa it maybe different than the desktop settings.infocus can execpt many resolutions but not all. try 1280x1024
Jan 29, 2008 | InFocus ScreenPlay 4805 Multimedia...
Have an infocus litepro 580, lamp and speakers works fine. Projector will only show the "infocus systems" opening display without changing to my video source. All cables are correctly in,...
Go into the settings menu of the projector and turn off the auto source function, then select the input that you are using.
if using a laptop you may have to simultaneously press your FN and relevant 'F' key to send the signal out to the projector. The 'F' key usually has an image of two side by side monitors or it says LCD/CRT. Wait a few seconds each time for the signal to be sent to the projector. Sometimes you may have to repeat this action 3 times to get the image on both your laptop and your projector.
good luck
Mar 08, 2011 | Office Equipment & Supplies
Do they make brighter bulbs for the LitePro 580 projector
Nope. You can NOT increase brightness of a projector by installing a brighter lamp. Sorry. The only option is replacing the projector with a brighter model.
Oct 20, 2010 | InFocus Litepro 580 Replacement Projector...
Can project tv screen on litepro
Check the "Default Source" using the remote or buttons on top of the projector.
Default Source toggles among Computer 1 analog, Computer 1 digital, Computer 2, and Video. This determines which source the projector checks first for active video during power-up. Highlight Default Source and click the left or right mouse button to toggle among the options.
Jan 24, 2009 | InFocus LP70+ Multimedia Projector
Hello we have a Infocus Scren play 5000. We just replaced the lamp and now we can not get it to project. It also will not turn off unless we unplug it from the power source.
Have you reset the lamp timer by pressing both of the brightness buttons at the same time it worked on our infocus litepro 720
Jan 05, 2009 | Office Equipment & Supplies
Looking for parts for infocus litepro 730
Dec 03, 2008 | Office Equipment & Supplies
Need Drivers
Hi Jess
Is your PC's image splitt ?
Right click on your desktop and go to properties - then click on settings and then advanced settings.
You'll see a block with two screens on it. If only one is activated - activate the secondary screen as well.
If you are using a Notebook also try holding in the Fn ( Function ) button - just left of your spacebar and in your F-row buttons at the top there should be one with two screens on it - Differs from brand to brand of PC's.
Hope this helps you !
Mar 26, 2008 | ASK Proxima Proxima DP2000S Data Video...
Discoloration
Please contact Swati@justlamps.com.sg for all your projector lamps needs. We provide orignal projector lamps with casing. We stock all Brands & Models avaialble in the market today.
Jan 21, 2008 | InFocus Litepro 580 Replacement Projector...
Multi-media projection without image
A great deal of the time DVD players are very restrictive on outputting to multiple sources due to copyright protection. In my experience, if you use your laptops function keys to toggle output (For example, on my laptop, I hit FUNCTION + F4 to cycle between LCD,LCD+VGA,VGA), you should be able to disable the laptop's LCD display, only outputting via the VGA cable. It's worked for me with my HP VP6111 and Windows XP in the past. Hope this helps!
Jun 19, 2007 | InFocus X1 Multimedia Projector
56 people viewed this question
jasbo
jasbo
