My hotpoint washer dryer is makin my electric trip
Was in the middle of a wash then my eletric tripped now when i put switch it on everything trips .even tried a different plug socket it still trips
  • 108 Answers
Hi if it is on washer side you could have a faulty heater you could follow wires from heater to top of mashine unplug it if dosent trip its heater or use multimeter check element for short one lead to eath outher to outher wires on heater
Posted on Feb 16, 2014
FitzOriginal
  • 842 Answers
SOURCE: beko wma 1510s keeps tripping eletric sockets
I once had a machine that would trip the power if it had an unbalanced load when it went to spin. Whirrr.... bang bang bang bang... click! Lights out.
HOWEVER, this is highly unusual. If the machine is tripping the power then you should take great care. either you have an electrical fault (The motor may be failing and burning out, or another component may be failing unsafe) or you may have a water leak from a defective hose somewhere that is getting electrical equipment wet. Just remember that water and electricity are a very un-funny mix and your trips are there for a good reason.
Does the machine trip the power as soon as it is powered on, even after standing for days (Probably an electrical fault)? Does it trip as a particular thing happens, such as moments after the water coming into the machine or as the drum starts to agitate or the spin cycle starts or as the water empties.
Here are a few suggestions. Having thought about when the fault trips the power, do the following:
TURN OFF THE POWER AND UNPLUG THE MACHINE FROM THE WALL. Isolate the water supply. Make sure that the machine is drained of water. Now it's safe, look for water leaks.
Take the top off the machine (Usually a couple of screws in the back and then the lid will tap forward or pull back depending on the model). Look for signs of water inside the chassis, where the water pipes run from the inlet valve to the soap tray. The rubber gasket around the door may also be cracked and leaking. A classic point for the start of a leak is the rear bearing of the drum (This is the centre of the big wheel of the drum), you may see water marks or limescale buildup that has dripped from the bearing if it is leaking.
If you are looking underneath for leaks, never tip the machine all the way onto its back, you may cause a water leak inside the machine. ALWAYS tip BACKWARDS, so the control panel for the machine is pointing up to avoid water getting to the control panel. I would recommend putting a chair behind the machine as you tip it, so the top back of the machine comes to rest on the seat and the machine is at about 45 degrees. this will give you access to underneath without a leak and make is a lot easier to tip it back on to its feet again afterwards.
While the machine is on its back, look at the motor, If you can, have a good sniff at it (Do you smell burned electrical equipment?) Look around for other components such as printed circuit boards, visually inspect and sniff them too.
The golden rule here is if you can see a leak and you can replace the part, then that's great, go ahead and Do It Yourself. BUT be sure that when you have finished everything is absolutely dry inside (Use a hairdryer if needs be). When you are absolutely sure it is all safe then prepare to test. With everything connected up turn on the mains and start the machine. ONLY TOUCH THE PLASTICS until you are sure it is working exactly as it should. Even then you should of course check to ensure that there is no electrical power leakage. If in doubt, it the power trips, if you have the slightest concern, get a professional in, Your family will prefer to pay for his visit rather than your funeral.
Posted on Feb 09, 2009
barkencoa
  • 3463 Answers
SOURCE: my aquairius hotpoint washer dryer wd62 keeps tripping electric why
Remove top cover, and unplug motor, try it, and if it does not trip, then motor is causing prob.
If it still trips, then heater is probably causing problem.
Please rate my advice.
Thanks.
Posted on Jun 01, 2009
barkencoa
  • 3463 Answers
SOURCE: Washing machine trips electric when fills with water
From the symptons described, I would suspect that the heating element is faulty, disconnect the heater, and try it again, if it does not trip, then replace heater.
Please rate my solution.
Thanks.
Posted on Aug 15, 2009
  • 166 Answers
SOURCE: hotpoint washing machine keeps tripping electric
First unplug your washer. Check the ground on the washer and make sure it isn't loose; this would be a good time to inspect the wiring harness for any problems. Next check the outlet (turn off the electric to that breaker first) make sure all the wires are tight and are making good contact; pay special attention to the neutral (white) wire. If that seems fine, and you are comfortable with going into you breaker panel, turn off that breaker and check the hot (the wire on the breaker) to make sure it isn't loose and then check the neutral wire. If either of these wires seem loose tighten them down....a loose wire will move when a load is put on it and cause the breaker to trip. If all seems normal and washer is still tripping the breaker you might want to replace the breaker.....they can go bad. Good luck!
Posted on Aug 26, 2009
SOURCE: my indesit WDC6125 washer dryer trips the
10 month old Indesit WIXL143 washing machine lights up for 2 seconds then trips mains off in flat.Have changed fuse in plug. I squeezed machine into small space and drainage tube gives off foul smelling problem cos it wasn`t long enough at back. But why now is it tripping? Where do I turn? Am on benefits
Posted on Mar 11, 2010
Hotpoint WD440 Washer Dryer machine is tripping the electricity, anyone know what could cause this?
check that your skin pipe is not blocked....happend to me with different make washer.....kept tripping when it came to spin.....skin pipes were clogged with hard oil/grease soon as a clean the pipe it was fine
Mar 12, 2013 | Hotpoint Aquarius WD640 Front Load...
My zanussi washer dryer keeps tripping the electrics
check ground wire for tightness on plug in and on breaker box.
Mar 31, 2012 | Zanussi ZWD12270 Front Load Washer / Dryer
My hotpoint washing machine wdf740 washer/dryer keeps tripping the electrics when it starts a program? If there is no program running, its fine but as soon as i hit start and water fills up the drum, the...
Could be a faulty motor or heater element, you need to isolate the heater and try it again, if it still trips, then I would suspect the motor is faulty, try unplugging the motor at the rear of the washer, and try it again, I'm afraid it is a process of elmination.
Jan 24, 2011 | Hotpoint Aquarius WD640 Front Load...
Hotpoint tcl 770 aquarius tripping electrics
REMOVE TOP OF WASHER AND CHECK WIRING ON FRONT RIGHT SIDE AS IT IS PRONE TO CHAFFING CAUSING AN INSTANT TRIP.
Jul 27, 2010 | Hotpoint Aquarius WMA56 Front Load Washer
Hi, my hotpoint wd860g washer dryer keeps tripping the fuse box. sometimes 20 mins in to a wash and sometimes up to 40 mins and then will keep tripping over and over. then it will run for a bit again and...
The most common reason for this is a Short circuit dryer element.
the best way to find out is to isolate the dryer and try it.
UNPLUG FROM MAINS FIRST... remove lid, you will then see the dryer box. on there is a fan (2 wires) thermistor (little wire plug goes in there) possibly a thermostat with a red or yellow dot in the middle or it could be a thermal fuse which looks like a long yellow thick wire, and finally the element, There are 2 different types of element, what you need to do is disconnect the wires to the element, put insulation tape around the ends of the wires and tuck them out of the way of the metal dryer box.
Put it on a wash cycle, if it does not trip then it is the dryer element.
Please note, with these wires disconnected, you will not be able to do a dry cycle as lights will flash.
Hope this helps..
Please rate my help.
Regards
Sussex engineer
Oct 22, 2009 | Hotpoint Ultima WF840 Front Load Washer /...
Hotpoint washing machine keeps tripping electric
Aug 26, 2009 | Hotpoint Washing Machines
Hotpoint aquarious wd 440 two years old tripping main board
A faulty heater in both a washing machine and dishwasher will trip swithes because they both cause an earth........the chances are you heater needs replacing......the reason its tripping after a short period is probably beacause the cycle doesnt start heating the water until after approx 15-20 mins depending on the cycle chosen
Mar 28, 2009 | Hotpoint Aquarius WD63 Front Load...
Washing machine tripping everything in the house
Washing machines take out ring main fuses if there are faults in the machine:
washers heater unit
motor
or suppressor.
Also water may have breached a seal somewhere and cause a short inside the electrical compartments.
To fix a fusing washing machine you have to use a diagnostic electrical meter that puts high voltage across the appliance - Not something I can offer more info on. So whatever has happened (and in the interest of safety) you would probably want a qualified proffessional to take a look or as a last resort a hotpoint engineer!
Feb 25, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD64 - Tripping the electric?!
something is going down to earth, start by unplugging the motor and retesting, if it doesn't trip them check the motor carbons etc, if it trips then check the heater element for contact down to earth, replace if needed etc, then check the outlet pump the same way if i have helped rate me please ps when working on machine remove from power supply
Oct 03, 2007 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
59 people viewed this question
Top Washing Machines Experts
