Question about Maytag Neptune MAH5500B Front Load Washer
How many cu. ft is a maytag LA390 series 11 washer?
I want to buy a new washer that is at least the same size that I have
5 Suggested Answers
SOURCE: What is the capacity (cu ft) of Kenmore washer
3.2 cubic feet
Posted on May 12, 2009
SOURCE: maytag neptune mah3000aww tub size
The answer is:
CAPACITY 3.1 Cubic Feet
The reference for this answer can be found here:
http://www.servicematters.com/maytag_library/docs/16010061.pdf
Seach in this document for "capacity".
SECTION 1. GENERAL INFORMATION Page 1-4
Posted on May 25, 2009
supernova278
  • 1932 Answers
SOURCE: I have a Maytag washer
Check the drain pump.The pump might be clogged or pump is not working at all.First check for clogging if no clog is there then you need to replace the pump.
thank You
Posted on Oct 29, 2010
woodchuck789
  • 4070 Answers
SOURCE: Maytag centennial 3.2 cu ft
Your pressure switch stops the water and allows it to start the next cycle. It's a switch either in the control panel or at the top of the tub with a small tube connected to it which goes down between the inner and outer tub. As the water level increases the air in the tube is compressed until there is enough pressure to "make the switch" stopping the water from filling. This tube can get clogged and the switch won't work. Remove the tube and clean it out. Blowing on the tube when it's still connected to the switch will make the switch if it's working and clear.
On some the water may not fill if the lid isn't shut. If the lid switch isn't working may also cause this. You can bypass the lid switch to see if it's the problem by connecting the two wires plugged into the switch.
Make sure there is water at the water inlet valve where the water supply connects. Try the load level at all levels and all water temp.
Posted on Feb 09, 2011
What size washing machine is this
Your Maytag Neptune MAH6500A Front Load Washer has dimensions:
Width : 27"
Depth : 29"
Height : 42 1/2"
Capacity : 3.34 cu. ft.
http://www.ajmadison.com/cgi-bin/ajmadison/MAH6500AWW.html
May 22, 2014 | Maytag Neptune MAH6500A Front Load Washer
MAytag Bravos Quiet Series 300 washing machine starts to fill, stops and shows code F51
F-51 RPS senses rotation when basket ought to be stopped.
It is probably loose or worn out.
Video How To
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 22, 2011 | Maytag Bravos 3.8 Cu. Ft. Washer
My Maytag Quite Series washer is making noise on the spin cycle.
Perhaps a wire from a garment has got between. Remove the tub and look.
Bravos service manual
Aug 23, 2011 | Maytag Bravos 3.8 Cu. Ft. Washer
WHEN MACHINE IS SPINNING IT SOUNDS LIKE A JET PLANE
Buy a new washer - NOT A MAYTAG - Parts are $80-120 and it takes special tools and a lot of time.
Ours ran for greater than the average time - about 7 years and that was God's blessing! Time for a new unit - NOT A MAYTAG.
Jul 11, 2010 | Maytag SAV365ZAWW 3.3 cu.ft.
Overfilling maytag centennial - brand new?
Sounds like a hose off pressure switch or faulty switch/ however make sure drain connected ok 1st....
Oct 02, 2009 | Maytag Centennial 3.2 cu. ft. SuperSize...
I have the kenmore 90 series top load electric washer. Model #110.92291100. I am trying to find out if it's a 3cubic or a 4cubic size. I am replacing it and I want the exact same size. It says Heavy Duty...
I couldn't find the exact size using the model number provided... i would bet that it's a 3.5 - 4 cu.ft. model... My suggestion is to get something other than a GE washing machine... Go with a Kenmore, Whirlpool or Maytag
Sep 24, 2009 | Kenmore 24032\24036 Top Load Washer
We just bought a Frigidaire 3.5 Cu. Ft. 10-Cycle King-Size Washer
call a repair service to get it tested .if new it should have warranty
Dec 24, 2017 | Frigidaire 3.5 Cu. Ft. 10-Cycle King-Size...
Maytag Neptune MAH5500B Front Load Washer Logo
35 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
