Question about Magic Bullet Nutribullet Blender
Cup will not go down far enough
Beaker is attached to blade. When trying to inset into Nutribullet base, it won't engage with motor/won't go down far enough for the cup to engage with the base.
Why doesn't blade spin?
Either the coupling from the motor with the fingers on it is not really attached to the motor shaft or the drive on the blade that engages with it is not attached to the blade shaft. One other thing is that on some models if the rubber jar seal between the beaker and the blade carrier is in the wrong place it can raise the blade drive to not engaging properly with the motor coupling. The gasket goes between the jar and the blade carrier, not under the blade carrier.
Sep 04, 2015 | KitchenAid KSB3 Classic Work Top Blender
I can manually turn the blades inside the glass pitcher and I can turn the piece on the top of the motor base into which the pitcher blade attachment fits.
One of the parts is not being driven properly. Either the clutch on the top of the motor is not really attached to the motor shaft OR the clutch on the bottom of the blade is not engaging with the motor clutch OR the blade clutch is not properly attached to the blade shaft. On some models if you put the rubber sealing ring in the wrong place between the beaker and the blade housing it is enough to lift the clutches apart. The rubber wing goes between the beaker and the blade housing, not between the blade housing and the blade retaining ring.
Jul 14, 2015 | Blenders
I don't know if the base foundation is too high in the base.
Hard to have an opinion when you have told us practically nothing. Make and model may help but I would suspect that if you are using the correct beaker and blade assembly on the correct motor base then the only thing I can think you could have done wrong is to put the rubber seal in the wrong place. Failing that is there some other way you can have assembled the blades to the beaker in the wrong order?
Jun 18, 2015 | Blenders
In the base, when I put the food in the cup, and the blade cup in doesn't fit the base. it appears the the blade doesn't go down in the base. I need help, I don't know if the base
Lots of questions, not a lot of information. Is the rubber sealing washer in the wrong place. I have no idea what model/brand you have but on most blenders the rubber seal will go between the beaker and blade assembly, not the blade assembly and the collar.
Why won't the blades turn?
One or both of the drivers are broken, check the clutch on the top of the motor and the other one on the bottom of the beaker. You will find something there worn out or broken.
May 24, 2015 | Blenders
Cup wont press down onto motor grips
Have you got something caught in it? Is it still under warranty? I am guessing but the mechanism inside the base should drop when you push to twist. Check is this is happening. If not then that may be the problem
Apr 21, 2015 | Magic Bullet Nutribullet Blender
Get the cup off the base, was making hummus, and now it still works, but wont let me remove the cup
put the cup area under some hot water near boiling and then undo the top with a cloth should come undone then, make sure its hot water.
Sep 11, 2014 | Magic Bullet Nutribullet Blender
How to open nutribullet jar stuck on blade base?
try heating the jar with hot water before removing it
Jun 30, 2014 | Magic Bullet Nutribullet Blender
Nutribullet manual
www.nutriliving.com/forums/were-listening/nutribullet-support
Jun 15, 2014 | Blenders
Pitcher stuck on base
You will likely need to replace the beaker anyway, the drive which is now melted to the motor coupling is only supplied as part of the beaker/blade assembly. You will also need a motor coupling.
Aug 01, 2012 | KitchenAid Blenders
Magic Bullet Nutribullet Blender Logo
162 people viewed this question
Top Magic Bullet Blenders Experts
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
R.A. Ellis
R.A. Ellis
Are you a Magic Bullet Blender Expert? Answer questions, earn points and help others
