Question about Onkyo TX-DS797 Receiver
Front speakers no sound tx-ds898 - Onkyo TX-DS797 Receiver
4 Suggested Answers
  • 137 Answers
SOURCE: Onkyo TX-DS898 Memory Loss
THEY USE A MEMORY CAP.ITS LOCATED ON THE MAIN PCB ASSEMBLY, REF. C7701 ONKYO PART NUMBER IS 3000078/ WITH THE UNIT TURNED OFF MEASURE THE VOLTAGE YOU SHOULD HAVE APPROX 5V IF NOT THE CAP IS BAD. ALSO MEASURE WITH UNIT ON AND YOU SHOULD ALSO MEASURE 5 V IF NOT THEN THE SUPPLY VOLTAGE GOING TO THE CAP IS BAD.
Posted on Apr 19, 2010
  • 52 Answers
SOURCE: Need Assistance: I connected
You likely need a separate audio cable for the DVD player, depending on what inputs your are plugging into on the receiver.
If you are using the component video connections (3 VIDEO connectors usually Red, Blue, Green) this is just for the video. You likely need 2 for audio. Look for L and R connections near the other three connectors on both the receiver and the DVD player.
If you are using an HDMI cable, this will carry both audio and vido but you may need to go into a setup menu on the Onkyo and set it to AUTO input or choose a HDMI for the DVD input.
Posted on Dec 04, 2010
  • 34725 Answers
SOURCE: i have onkyo reciever tx-ds898 no sound
Some receivers shut down automatically if a thermal overload is detected or more commonly if speaker impedance is less than specified, i.e, driving a 2 ohm impedance speaker with an output rated for 8 ohms. If you can get the receiver operating long enough, you may see a message indicating why it is shutting down
Posted on Oct 03, 2012
I have onkyo reciever tx-ds898 no sound
Oct 03, 2012 | Onkyo TX-SR606 Receiver
Apr 18, 2010 | Onkyo TX-DS898 Receiver
Will not power up it just ckicks the red power
You should disconnect all speaker connections. If the problem persists, you have a faulty receiver in need of repair. Not easy for the DIY. If the removal of the speakers allow normal operation, reconnect one at a time making sure not to short-circuit any output. By the description, I will mostly assume a bad receiver. Local repair shops can help.
Oct 09, 2009 | Onkyo TX-DS898 Receiver
No picture from monitor out on Onkyo TX-DS898
I realize you may have already doubled checked but make sure you follow this from the manual:
If the satellite tuner / cable box is equipped with an S video output
terminal, connect it to the S VIDEO 3 (or 4) IN terminal with an S
video cable. If it does not have an S video output terminal, connect
its video output terminal to the VIDEO 3 (or 4) IN terminal using an
RCA-type video connection cable. You do not need to connect to
both the S VIDEO 3 (or 4) IN and VIDEO 3 (or 4) IN terminals. If
the satellite tuner or television has component video outputs,
connect them to one of the COMPONENT VIDEO INPUT jacks.
With the initial settings of the TX-DS898, the VIDEO 3 and
VIDEO 4 input sources are set for the COMPONENT VIDEO
INPUT 2 jack.
If the video connection is made at COMPONENT VIDEO INPUT
1, this must be changed at the Setup menu: Input Setup → Video
Setup → Component Video (see page 35).
Using an RCA-type audio connection cable, connect the audio
output terminal on the satellite tuner or television to the same
VIDEO 3 (or 4) IN audio jacks on the TX-DS898. Make sure that
you properly connect the left channel to the L jack and the right
channel to the R jack.
If the device has a digital output jack as well, be sure to also connect
it to either a DIGITAL INPUT (COAXIAL) or DIGITAL INPUT
(OPTICAL) jack on the TX-DS898 depending on the device.
With the initial settings of the TX-DS898, the VIDEO 3 input source
is set for digital input at the OPTICAL 3 jack, and the VIDEO 4
input source is set for digital input at the OPTICAL 4 jack.
If the digital connection is made at a different jack, this must be changed
at the Setup menu: Input Setup → Digital Setup (see page 33).
Apr 15, 2009 | Onkyo TX-DS898 Receiver
No sound from rear speakers
Hello, the setting must be "Not Activated" That is for zone 2 setup. If you are setting up 5 speakers the rear speakers should be connected to surround not surround back. Thank you Onkyo USA.
Mar 25, 2017 | Onkyo TX-DS898 Receiver
My Onkyo TX SV 535 Surround Sound wont work
when the stereo or mono listening mode is selected only front speaker and subwoofer produce sound--------make sure that speakers are configured correctly.
and you select surround sound in listening mode.
Aug 17, 2008 | Onkyo TX-SV535 Receiver
Righ & Left Front speakers not functioning
SOUNDS LIKE HE HIT YOUR SPEAKER CHANELS 1 OR 2,,, PUSH 1
Mar 15, 2008 | Onkyo TX-SV545 Receiver
Onkyo TX-SR500 Dolby Digital problem
I just read over the problem you were having with your Onkyo TX-SR500 receiver. It sound like the unit needs to be setup for all five channels.Sence your symptom says the diplay shows Dolby D3/2.1. According to the owners manual with the remote control look for speaker setup whin the button is pressed the current speaker setup will be shown in the display. Press the preset/adjustment<> to change the current setting to five speakers. the listening mode will automatically change according to the number of channels you selected. Hope this helps. Radiotech
Aug 14, 2007 | Onkyo TX-SR500 Receiver
NO surround sound coming from our harmon/kardon speakers when set up to our onkyo tx-sr601 receiver. wires connected in correct areas, front left, right and center speakers work, subwoofer works. setup for...
So your saying that you have no rear channel. Some recivers use a single stereo output ic for both sides on the rear speakers. you could have a defect with this IC . Anther thing Im sure you check3ed the obvious ie : the switch is on suround sound? If there is a front to rear fader is it in the middle? Good Luck
Jun 04, 2006 | Onkyo TX-SR601 Receiver
Open Questions:
See all Onkyo TX-DS797 Receiver Questions
Onkyo TX-DS797 Receiver Logo
26 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
