Question about Life Fitness T5-0 Treadmill
Displays motor comm error - Life Fitness T5-0 Treadmill
How to correct Tread climber TC5500 error code NIPP COMM (Belt Shut Down).
If you wiah to get some details about treadmill error codes and solutions then check the following link
http://electro-medical.blogspot.com/
Oct 02, 2016 | Bowflex TreadClimber TC5500
Error code 105
Info for Error code 105
105. (01101001) Phase 2 to 6 - Comms Error Time Out
These faults are reported when the Display Module detects an error in
the communications between the Display Module and the Motor
Control Module.
Note: If the product is an IW, the wrong Motor Control Module may
have been fitted. Replace with a compatible part.
Phase 2 to 4 and Phase 6
Primary Source: Display Module.
Action: Replace Display Module.
Secondary Source: Motor Control Module.
Action: Replace Motor Control Module.
Tertiary Source: Rotor Position Sensor (Phase 5 and 6).
Action: Replace Rotor Position Sensor. If this corrects
the fault, refit the original Display Module or
Phase 5
Primary Source: Pump
Action: Measure resistance of pump. If resistance is
less than 33 ohms, replace pump.
Secondary Source: Display Module.
Tertiary Source: Motor Control Module.
Quaternary Source: Rotor Position Sensor.
Sep 26, 2013 | Fisher and Paykel Washing Machines
F&P GW709 top loader filling water intervally
Error Code 105
105. (01101001) Phase 2 to 5 - Comms. Error Time-out
These faults are reported when the Display module detects an error in the communications
between the Display module and the Motor Controller.
NB. If the product is an IW, check that the motor controller is not 426520. If it is replace with a
compatible part. This is incompatible and will give a fault code 105 at the start of agitate. Not
before! If it is a 426520 replace motor controller with a compatible part.
Primary Source - Display module
Action - Replace Display module.
Secondary Source - Motor Controller
Action - Replace Motor Controller
Tertiary Source - Rotor Position Sensor (Phase 5 Only)
Action - Replace Rotor Position Sensor. If the new Rotor Position Sensor corrects the fault refit
the original display module and motor controller.
Aug 02, 2013 | Fisher and Paykel Fisher & Paykel Washer
Error 105
Try to get a Rotor position sensor as they are cheaper.
105. (01101001) Comms Error Time Out
These faults are reported when the Display Module detects an error in the communications
between the Display Module and the Motor Control Module.
Action: Replace Rotor position Sensor. If this corrects the fault refit the
original Display Module and/or Motor Control Module.
Feb 21, 2013 | Fisher and Paykel Aquasmart wl80t65c
I have a Bowflex TC5500 When I tried to use today, I got a error message on display that says: ERROR Belt Shutdown error code: NIPP COMM Error
LUBE THE DECK BELT, INMEDIATELY THIS HAPPEN BECAUSE THE LACK OF MAINTENANCE, ACCORDING THE SCHEDULE MAINTENANCE, READ YOUR OWNER MANUAL OR DOWNLOAD FROM WWW.ICONSERVICE.COM
GOD BLESS YOU
Sep 21, 2012 | Bowflex Treadclimber Walking Belt Tc5500
Aquqsmart Error 105
Jan 26, 2012 | Fisher and Paykel Washing Machines
My dodge journeys cd player say
My cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix this
Jan 03, 2012 | 2010 Dodge Journey
I have error codes flashing on my thermostat..it is an american standard model the manual for the therm. has ACOT900AC43UA on front..says to find addedum 18-HD32D2-1/69-2009 for codes i cannot find it...
Error codes from American Standard Pub 18-HD32D2-8, which is a one-sheet document that came with my American Standard air-conditioner:
29 = not listed
129 = not listed
80 = HPCO Fault - problem is in outdoor unit - Desscription: High Pressure Monitor Fault (hard lock out, cycle power to reset)
91 = Communication Inactive Fault - problem is in air handler - Descriptions - COMM Bit Master Clock Error, COMM Heat/Cool Demand Error, Serial Motor Communication Inactive Error
91 = Communication Fault - problem is in furnace - Descriptions: Blower motor no COMM response, Inducer motor no COMM response, Loss of heat/cool demand, Loss of clock signal
91 = Communication Fault - problem is in outdoor unit - Descriptions: Loss of Heat/Cool Demand Message (COMM), Loss of Bit Master (Clock Signal)
91 = Communication Fault - Description: Comm line is dead and no bits have been received.
By the way, I do not recommend American Standard. I've had mine 14 months and it just blew up - the entire control panel blew. My advice to you - think about a different brand.
Nancy
Scottsdale, Arizona
Aug 22, 2010 | American Standard Heating & Cooling
When I turn the machine on it says I need service error 105
Hi just read your posting.Now error code 105 is called COMMS. ERROR TIME-OUT.This means the display module has detected an error in the communications between the display module and the motor controller.There are 3 reasons why this error code appears, the 1st is a faulty display module, the 2nd is a faulty motor controller and the 3rd is a faulty rotor sensor.The way this fault is tracked down is to 1st change the display module and if that does not rectify the fault then change the motor controller and if the fault is still present then change the rotor sensor.Sorry for the bad news on this fault and unfortunately you need the components to find the fault.I have double checked to see if there is a way to check the components easily and I have not been able to find one.Please reply on how you would like to proceed and I can help you as much as I can.
Aug 08, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
What is code 105
Error code 105 means you have a Comms. Error Time out. This means there is a communications error between the display module and the motor controller.Now have you replaced a part in the machine recently?Just looked in my manual and it also says, to rectify this fault you might need to replace the rotor sensor on the motor.Please reply and tell me if the machine became faulty or a part was changed for another fault and then Error 105 started appearing in the display.Hope to hear from you soon.
Jun 04, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Life Fitness T5-0 Treadmill Logo
46 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Howard
Howard
Glenn Mayer
Glenn Mayer
Craig Butler
Craig Butler
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
