Question about Fisher and Paykel GWL11 Top Load Washer
Fisher and paykel mw511 3rd, 5th, 7th and 8th lights on and beeping
SOURCE: fisher paykel codes
There is a code book inside the top of the washer where the electronics are.
Posted on Apr 06, 2009
tunde007
  • 2382 Answers
SOURCE: fisher & paykel eccosmart washer after
Hi, the third and fourth lights from the left indicate a failed motor controller (error code 48) If this is the correct fault code you will have to replace the motor controller. However before that is done all the electrical components which can effect the controller must be checked as well while the seventh light means that the hot water valve is faulty and needs to be replaced.
Posted on Jan 30, 2011
richroth
  • 9472 Answers
SOURCE: why does my fisherpaykel washing machine beep and
(00101011) Phase 1 to 6 - OOB Switch Fault The Motor Controller module has found that the signal returning from the out of balance switch indicates that the switch is permanently on or the harness to it is disconnected. Primary Source: Mechanical. Action: 1) Check that the out of balance switch is free to move. 2) Check that no harnesses are blocking switch movement. 3) Check that the switch operates correctly when activated. Replace the switch if suspect. 4) If the out of balance micro switch shows signs of corrosion, replace the switch and switch harness, and fit a condensation kit to the console area if not incorporated in the top deck. 5) Check the level of the machine and also the bias spring. Secondary Source: Wiring. Action: Check the harness to the switch is connected correctly. The terminals should be connected to the normally closed position. If the harness terminals show signs of corrosion, then fit a new harness. Tertiary Source: Motor Controller module.(Display Module Phase1 ) Action: Replace Motor Controller module.(Display Module Phase 1)
Posted on Feb 06, 2011
  • 251 Answers
SOURCE: Hi hav the Fisher &
Hi - open the lid - poke your hand under the right corner - locate the lever hanging down & wiggle gently back/forth - this may release the out of balance switch - try it out.
Otherwise you need to remove the 2 screws on the back top corners - disconnect the power & cables under the display panels to remove the switch located on the right side with 2 wires attached to it - usually wh & yellow.
this is whats causing the machine to behave as you described...
Have a nice weekend..
Posted on Jul 01, 2011
caroldon
  • 17130 Answers
SOURCE: problem with the fisher and
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Thank you for using fixya.
Posted on Sep 02, 2011
Fisher & Paykel Pride 5.5 won't wash. It fills with water then starts to beep. I can advance it to the rinse stage so it drains the water, once the water is drained, it starts to beep again. The...
Hi - the out of balance switch has activated this will be found under the lid right side if you bend lw enough you can see it hanging by a lever - it may have activated from the previous cycle - it needs to be freed - put it outside of the bowl and be sure its free to operate - if not it needs to be removed and replaced.
Jul 12, 2011 | Washing Machines
Hi hav the Fisher & Pakyll Excellence top loader 7.5kg. It starts and stops on each cycle as if it hasn't enough power to get going. It beeps and lights up the 3rd, 5th, 7th and 8th lights across...
Jul 01, 2011 | Fisher and Paykel (IWL12)
My GW609AU, stops when filling and beeps with lights no.s 1,3,7,8 on.
Hi Kim just read your posting.Could you please confirm the lights that are lit when it beeps.From the information in your posting ,starting from left to right in the row of 8 lights it is the 1st,3rd,7th and 8th lights that are lit,Is this correct?If so then it is your MOTOR CONTROLLER that is faulty.Please reply back with conformation on the lights that are lit and I will help you further.
Aug 09, 2010 | Fisher and Paykel Washing Machines
The washing machine fills with water but then appears like it struggles to spin and then it stops attempting to spin, then starts to beep and flash lights. the lights that flash are the middle green...
Hi just read your posting.Now the lights that are flashing are an ERROR CODE .On the row of 8 lights that these lights are flashing which ones are flashing,starting from the left to right of the row is it the 2nd and 3rd and 8th or the 1st and 4th and 7th ---etc---?Please reply with additional information and I can help you rectify this fault.Looking forward to your reply.
Jul 30, 2010 | Fisher and Paykel Washing Machines
Washing machine stopped during spin cycle. now when i turn it on it beeps and has 3 lights on, 2 wash lights and the spin light. model number is GW611 excellence. fisher & paykel top loader
Hi just read your posting.Now on the wash progress line of lights ,there will be 8 in this row.Starting from the left to the right which lights are lit.Is it the 2nd ,3rd and 7th or the 1st, 4th and 8th ---etc---?Please reply with additional information and I can help you rectify this fault on your machine.Looking forward to your reply
Jul 27, 2010 | Fisher and Paykel Washing Machines
Fisher/Paykel WA37TG1 washer. goes through the wash cycle and the rinse cycle. stops at spin cycle and beeps. lots of suds left on clothes. have unplugged and let sit and start again. this got me through a...
Hi just read your posting.Now when the cycle beeps a series of lights will light up indicating an error code.The lights will be in a row of 8 lights.Starting from the left to the right which lights are lit?Is it the 2nd and 5th or the 3rd and 7th ---etc----?Or do you have the display model and an error code is on the screen?Please reply with the additional information on the questions and I can help you further.
Jul 20, 2010 | Fisher and Paykel WA37TG1 Top Load Stacked...
I have a Fisher Paykel Model GWL 11 washing machine. A couple of days ago the machine was operating, but when it came to the spin cycle it would not enter the cycle. It kept trying, but eventually let out...
Yes I can help.Starting from left to right on the line that the lights are lit the fault code values of each are , Starting from the far left they go 1st=128 2nd=64 3rd=32 4th=16 5th=8 6th=4 7th=2 and 8th=1.Add up the lights that are lit on your machine and reply back and I will let you know what part is faulty.
Jun 04, 2010 | Fisher and Paykel GWL11 Top Load Washer
Have kelvinator smart drive 503, water won't run
I have exactly the same issue, which first appeared yesterday. Following your advice, the lights that are lit are 3rd, 5th, 7th and 8th. The SLOW & HOLD spin speed lights are lit, along with constant beeping :)
Jun 16, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
29 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
