Question about Frigidaire FPHB2899LF
Frigidare model # FPHB2899PFO temp is too high. 46 degrees and rising
Try to set temp at 33F., but keeps rising wont set
4 Suggested Answers
woodchuck789
  • 4066 Answers
SOURCE: frigidaire side by sid model
DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
You can post your model number into one of several appliance parts sites on the internet and search for defrost components to find your parts.
Posted on Sep 03, 2010
heatman101
  • 43501 Answers
SOURCE: freezer side cold, other side not cold, temp
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Dec 27, 2010
tpaliganof
SOURCE: the temperature keeps rising for the freezer and refrigerator -
freezer is set for zero but continues to go to 20 below. how do I stop it
Posted on Oct 15, 2013
My Viking professional refrigerator is stuck on 46 degrees refrigerator/ 6 degrees freezer. None of the buttons work. Is there a reset button?
press display on or (activate control) button first you should then be able to choose fridge or freezer and change set temp
after set will read actual temp 46 is a little high sounds like you have service issue
Jun 27, 2017 | Viking Refrigerators
Have a new ac system installed thermostat is set at 76 shows room and setting the same all the time shouldn't the room temp rise before unit comes on.
Yes the temp should rise 2 to 3 degrees before the unit comes on, This is called the temp swing, try lowering the temp setting and wait for the temp to drop, then set it back when you want it.
Aug 21, 2010 | Computers & Internet
Hi samsung fridge runs fine gets to desired temp then wont kick in again until it warms up.
the fridge will run until it reaches the temp. there should be a differential of 2 degrees so when the temp rises by 2 degrees the fridge should restart so you will need to make sure the differential is set to 2 degrees celcius on controller
May 21, 2010 | Refrigerators
Freezing problem in maytag frig
the probe from the temp panel is not sensing correct temp or the panel itself is bad...call a tech to check it out
Feb 04, 2010 | Refrigerators
I keep my frigidare in garage even during winter time. When temperature drops to 3 degrees Celsius my frigidare stops working. Does anybody know what can I do to make frigidare to work and keep it in...
I know the minimum operating temp for many refrigerators is around 33 F (about a degree above freezing or so). This is due to the refrigerant gas within the compressor and the fact that it is not stable at low temps. Typically, a refrigerator's minimum ambient temp should be 50 degrees F (10 degrees C).
I don't know if there is a whole lot you can do. The refrigerator really wasn't built to work in such cold weather. You may either have to relocate it, put a heat source near it or look into a special freezer that is *supposedly* able to operate in much colder ambient temps.
Dec 07, 2009 | Kenmore Refrigerators
Thermal cut-off blows and high limit thermostat is working with vent clean.Replaced thermal cut-off, high limit thermostat and heating element. Still blows thermal cut-off.
Any time a thermal cut off blows, it's because the cycling thermostat is bad. When it's bad, the machine cycles off of the thermal cut off rather than the cycling thermostat allowing the dryer to over heat. The thermal cut off is a re-setting safety and is not made to cycle off of. The thermostat you are looking for looks like a high limit thermostat but it cuts power to the element at a lower temp. Around 158 degrees + or - 25 degrees. It's located close to the high limit. It's a normally closed switch that opens on the rise and it will show closed now but the problem with it is that will not open. Replace it and your problem will be solved. Good luck.
Oct 16, 2009 | Kenmore Dryers
Model ED20PKXAN01 side by side. Defrost timer
The timer could be set for accumulative instead of continuous . The one wire on the timer , set on the wrong terminal .
Jul 20, 2009 | Whirlpool Refrigerators
Cannot set heat setting by using "hold" feature
make sure it is not telling you room temp, some of the Honeywells, will display room temp over desired temp. check that, if it wont let you switch temp than buy a new one, if you dont have a heat pump a new cheap stat is around 20.00.
Dec 31, 2008 | Honeywell Programmable Thermostat Heater
Frigidaire FPHB2899LF Logo
113 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
