Question about Maytag Dryers
Why my electric maytag dryer heats sometimes - Maytag Dryers
  • 27 Answers
SOURCE: Electric Dryer problem
the timer has a small motor to advance the timer. the motor is the likely problem. on some old maytags you can get just the motor, but you probably will have to replace the complete timer. hope this helps.
Posted on Nov 02, 2007
  • 623 Answers
SOURCE: MAYTAG ELECTRIC DRYER DOESNT HEAT. CAN YOU HELP ME?
Without seeing it, and very little info to go on, let me ask this, does the drum turn?
If there is no heat, go outside and check the exhaust, do you feel air blowing out?
If you do, then the heating element may be bad or the switch that sends power to the element may be bad. If no air blowing out, then I do not know any further. At any rate, a service man must come.
Posted on Nov 16, 2008
SOURCE: Maytag Atlantis dryer no heat
The heating element and thermostat are located behind the front panel of the dryer. you will need to remove the door, then the retaining screws. the heater / element is located on the left side as you are facing the front of the dryer and has to sheet meta screws (upper back top / and front bottom) which will need to be removed. the unit has several colored wires for the thermostat and switch. remove these (remember which goes where) and the enitre unit will come out easily.
Posted on Jan 08, 2009
  • 686 Answers
SOURCE: MAYTAG PYE2300AYW ELECTRIC DRYER running but no heating
you need to take it apart if you'd like call 417-926-0106 i'll walk you through it Jim
Posted on Feb 27, 2009
SOURCE: my maytag electric dryer will not heat up. it's a de107
Have someone check to be sure you have 240 volts to the plug. The dryer will run on 120 volts but must have 240 volts to the heating unit. If you 240 volts you probably need a heating element or control.
Posted on Apr 06, 2009
My maytag will not heat up, what should I do.
Hi,If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.if you dryer is gas check out this gas no heat tip....If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 24, 2011 | Maytag PYE2300AY Electric Dryer
I have a maytag electric dryer model number LDG8424AAE sometimes it does not heat up
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
Aug 11, 2011 | Maytag Dryers
Maytag PYET344AZW heating element not heating
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 10, 2011 | Maytag Neptune MDE7500AY Electric Dryer
Maytag mde2400azw takes forever to dry.
heatman101
Dec 27, 2010 | Maytag MDE2400AYW Neptune Electric Dryer
Maytag LSG 7806 Electric Dryer doesn't heat up how can I get a wiring diagram
heatman101
Nov 30, 2010 | Maytag LSG7806A Front Load Stacked Washer...
MAYTAG GAS DRYER MD5500 DOES NOT HEAT
heatman101
Nov 29, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Maytag neptune dryer will run, no heat I think the heating element is out, how do I replace it. Model MD5500
heatman101
Sep 12, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Why does my Maytag Atlantis dryer not heat up at all?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Aug 08, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer is not drying and does not have heat. Maytag #PYE2000AYW
heatman101
Jul 22, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Atlantic Gas Dryer - Will not heat
heatman101
Jun 07, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Dryers Logo
11 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
