Dell inspiron problems
Computer will start(fan and power light)then shut off and restart this will repeat over and over
  • Debi Noel
    Debi Noel Feb 18, 2014
    Thank you for all your great ideas:) Unfortunately my warranty has expired. I have tried to start it in safe mode and the computer just doesn't want to co-operate. I can't get it that far. I'm thinking either reformat or take it to someone..sigh
    Guru:
  • 377 Answers
This problem can mean many things, odds are the problem is with the operating system itself. I'm going to give you some instruction of some things I would do if I was working on this computer.
Questions you should consider:
Do you get any error messages? If so contact Microsoft with the error message.
Is you computer under warranty? If so, it's best to let a technician handle the problem. Note: Sometimes they will reformat or replace your hard drive. You could loose all data so it would be a good idea to backup first.
Re-pare Steps:
1) Restart Windows in Safe Mode. As you computer is restarting, hold down F8 and once the menu appears, select Safe Mode using the arrow key and selecting by pressing enter. Note: If windows does not boot in safe mode then seek help from a train technician, the problem may be too complex to go into decision in the message.
2) Consider a system restore. You will loose all data and changes you have made to your computer after the restore date. Open system restore by clicking on the start menu and selecting help and support. System restore should be one of the options assuming you have system restore turned on. (It's windows default so you should.) Select a restore date prior to the problem occurrence. Restore your PC. If you do not want to do a system restore then skip this step.
3) Run a virus scan, then spy-ware scan, followed by ad-ware.
4) Your problem should be resolved by now. Restart your computer and see if it works, if not then restart in safe mode again (step 1).
5) If all else fells you can reformat your hard drive by reinstalling windows. You can do this by inserting the windows disk or system restore disk that came with your computer. Follow the instructions given by the manufacturer. WARNING: This will wipe the hard drive of all data, it will be like you just got your computer. You will loose all software and everything.
I hope this help.
Posted on Feb 16, 2014
Testimonial: "Thank you for all your great ideas:) Unfortunately my warranty has expired. I have tried to start it in safe mode and the computer just doesn't want to co-operate. I can't get it that far. I'm thinking either reformat or take it to someone..sigh"
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 56 Answers
You should open the desktop and clean it all the fans the graphic card etc i am sure it will help you out .
Testimonial: "Thank you for your reply. I am a cleanliness nut when it comes to my computers, so its spic-and-span atm. First time I haven't been able to fix a problem myself"
ODCaloney
  • 260 Answers
SOURCE: dell dimension 4700 computer keeps shutting down at start up
That's pointing to the memory. Try re-seating the RAM.
Posted on Mar 19, 2009
gurutim
  • 68 Answers
SOURCE: Dell Inspiron 530 randomly shuts down and restarts
Sounds like it could be a virus. Or, a heat buildup problem - are all fans inside machine working? Is the fan inside the power supply operating? Was there any work done inside the computer recently?
If the hdw is all ok, go out and buy yourself a copy of Norton Internet Security 2009 - 1 user lic - $49.99 @ Staples. Do *not* buy any earlier vers. of this software! Install, update it, run computer computer scan - probably will find/remove some/many viruses.
If this helps, please take the time to rate my response to you.
Thanks and good luck.
gurutim
Posted on Mar 22, 2009
  • 561 Answers
SOURCE: solid amber light ON Dell Inspiron 530 desktop.The
Hi
Please try the following
1) Remove ALL wires from thw back of the PC
2) Press and hold the power button on for approx 15 seconds
3) Replug only the mains power wire and the monitor cable and then retest
Please advise of outcome
I hope this has been useful
Posted on Mar 05, 2010
  • 3940 Answers
SOURCE: Dell Inspiron 530 won't start up - is motherboard dead?
From your description, I agree with you assessment of a likely Motherboard failure.
Posted on Mar 09, 2010
  • 3 Answers
SOURCE: Dell Inspiron 531 keeps shutting itself off.
if it's overheating, then u should try to put it in a cooler place. : )
Posted on May 15, 2010
My Dell Inspiron 530 used to freeze up ever so often. I would have to manually shut it down and restart.After a while I found out that running the AVG scan it wont shut down so often.One day while booting...
This is a system fault error condition, including the power supply. Only the +5VSB rail on the power supply is working correctly.
ports to see if anyare damaged and then try powering on the system to see if you get a green power button.
Feb 23, 2011 | Dell Inspiron 530 Desktop Computer
Dell Inspiron 531 keeps shutting itself off. After a few moments, tries to restart. and shuts down, almost like it's hibernating, or overheating. New PSU and re-thermal'd the processor/fan
Try removing every single thing in the box you are comfortable with removing - reinstalling.
Take each piece starting with one stick of ram - clean the connectors -[ shiny copper or gold looking area] with a clean pencil eraser.
Install each one - one at a time.
First one stick of ram.
Then another - then a removed card - one at a time.
If this problem continues after reinstalling only the first stick of ram - you may have to re-seat the processor - jell- fan. It takes some doing sometimes to hunt this down - so do not eliminate the power supply either - think about removing it and trying another if all of the above fails to fix the problem.
One last thing - if you have Windows 7 and didn't buy it retail - Windows 7 is shutting down because it is not a legit copy.
Best of it
Gary
May 04, 2010 | Dell Inspiron 531s Desktop Computer
Push Button and Computer fan starts then immediately shuts off (1 Second) .Yellow light on front does the same comes on 1 second then off .Nothing else happens . It is a Dell Dual Core 2 fans.
chek your power unit or the cpu fan working or not if the cpu fan is not working computer will turnoff immediate to save it you better show you computer for technician soon
please rate this solution.....
Apr 11, 2010 | Dell Inspiron 531s Desktop Computer
I have a Dell Inspiron E1705 that seizes up.
sounds like your hard drive is about to take a dump or cpu is not cooling good and she is over heating mite get a can of air and blow your fan area out mite be stopped up by some dust try this and see if it helps....
Dec 10, 2009 | Dell Inspiron E1705 Notebook
gurutim
Mar 22, 2009 | Dell Inspiron 530 Desktop Computer
Dell inspiron 5160 wont start
It sounds to me like your Laptop over heated... I cannot be for sure But I would get your Motherboard check because it sounds like its shot.
Mar 18, 2009 | Dell Inspiron 5160 Notebook
My Dell Inspiron6400/E1505 restarts automatically after shutting
It looks like the traces of the Virus infections are causing the trouble. u still some dlls related to the virus infection.
Feb 23, 2009 | Dell Inspiron 6400 Notebook
Dell inspiron 530s is giving me major trouble. When ever I turn it on, the power button lights up and the fan turns on but then thats it. There is no activity on the monitor, just the loud noise of the...
my inspiron 530 giving me trouble. Blue light is on, but the computer goes no where. Try to start by shutting down and restarting but the start sound keeps coming fora long time and nothing happens. So to say having trouble starting and sometimes it shuts down but the blue light stays on. Sometimes I cann't even turn off the computer by pressing blue light - trouble trouble trouble
Feb 22, 2009 | Dell Inspiron 530s Desktop Computer...
Dell Inspiron 8600 - overheating and shutting down
Start by cleaning the fan and heat sink. Dirt or dust build up can cause them not to work as efficiently as they should. If cleaning doesn't fix it, you might consider replacing the fan and heat sink or purchasing a cooling pad.
Jul 22, 2008 | Computers & Internet
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
