Question about Kitchen Ranges
Jenn-air sce30600 locked door
Door is stuck locked, restarting it does nothing, the panel works normally but it will not bake broil and selecting self clean causes it to fail (but it still tries to) what do I need to do to get my oven back?
  • 1314 Answers
SOURCE: GE Profile XL44 Spectra gas oven
try to hold down the light switch on the door set it up for another cleaning hit start when oven clean door lock showes hit cancel if that doesnt work try unplugging it for three min fyi the doors can take up to an hour to un lock after cleaning its so it dont burn your face off from the intense heat after cleaning some take 2
Posted on Feb 14, 2008
SOURCE: jenn air s136 stove won,t self clean
You've probably already read pages 34 through 37 of the owners manual for this oven. We had this stove in the house we bought and the owner wrote in his own directions, which seem to work fine:
1. Turn knob selector to clean.
2. Turn temp knob to clean.
3. Close and lock door.
4. Push enter button and turn dial clockwise to desired time.
5. Push enter button again.
You've probably already tried this, but just in case I figured I'd pass it along.
Posted on Mar 21, 2008
IB4G2008
  • 3587 Answers
SOURCE: Jenn-Aire locked tight!
that relay/solenoid can get stuck quite easily..
you have a service contract on this?
Posted on Mar 28, 2008
FixFree
  • 12 Answers
SOURCE: After canceling self cleaning on
You will need to allow oven to cool, the temperature is one thousand degrees plus while the oven is cleaning. Until the oven cools it will not open, this is a safety caution. If it will not open after it is totally cooled, it may be stuck, try pushing on the door or pulling it out a bit while trying to move the lever.
Always consult the owners manual when using the cleaning mode on your oven. Be sure it is fully cooled before cleaning any residue out of oven area.
Posted on Jan 28, 2009
  • 11 Answers
SOURCE: cleaning secession, door stuck jennair oven
Unplug the power source and leave it unplugged for about an hour. This should reset the computer n it. Good luck
Posted on Apr 07, 2009
I have a whirlpool Super Capacity 465 self cleaning oven with accubake. About a month ago after using the oven to bake dinner the keypad button(s) became stuck (i figured this out after researching the...
Hello Michelle!
Crazy to hear, but this is actually a touchpad failure.
Luckily, we at FixYourboard.com have a solution.
Read more about the cause and fix in our blog! F5 E1 Error Code Whirlpool Built In Double Wall Oven
Feel free to contact us if you have any questions. info@fixyourboard.com
Mar 20, 2017 | Whirlpool 30" Self-Cleaning Freestanding...
Mar 28, 2008 | Jenn-Air SVE47100 Slide-In Electric...
The oven is stuck at LOC.
The locking motor has gone bad on the range. Common for this to happen after self clean. You will have to replace or have the lock assembly replaced for the stove to work again
Mar 06, 2010 | GE JKP45 Electric Double Oven
Jenn-air sce30600 - replace door lock switch
Hi Don, the part you need is 71001129 and is #13 in the attached breakdown. Hope this helps you get it apart.
Nov 08, 2009 | Jenn-Air SCE30600 Slide-In Electric...
Jenn-Air stove locked
After the lock indicator light goes out, move the door lock lever to the left. The oven door can now be opened. Turn the selector and temperature knobs from clean to off AFTER THE DOOR IS UNLOCKED. If the temperature knob is turned to off BEFORE the door is unlocked, the door will not open. Forcing the lock will damage the lock mechanism. If this should happen, return the temperature knob back to CLEAN, unlock the door, THEN turn the temperature knob off. Source(s): Jenn-Air Grill Range with Self Cleaning Radiant Bake and Convection Oven models S136, S156, S161
Dec 10, 2008 | Ovens
OVEN NOT WORKING
You have probably damaged the latch and other sensors around the door. Make sure that the is not bent or out of alignment.
more asst.
eboukater@gmail.com
Jul 01, 2008 | Jenn-Air JJW8530C Expressions Collection...
Jenn air oven stuck closed after attempt to activate self-cleaning
The lock motor may have failed. Most often, bending a coat hanger into a hook and sliding from the right side as you move the door to the right,will allow you to release the lock and open the door.
Jun 09, 2008 | Jenn-Air JJW8130D Electric Single Oven
Feb 14, 2008 | GE Profile JGS968 Gas Kitchen Range
Jenn Air Range SCE30600
i would pull unit out adn look for a bad thermostat on back wall wired inline from bake and broil elemnts, probably tripped during a clean cycle or something got to hot, common for oven to shut down because of bad safety thermo, yet stovetop function without interuption
Nov 26, 2007 | Jenn-Air SCE30600 Slide-In Electric...
Jennair range
f-5 means the clock/oven control is bad. the only way to fix this is to replace the oven control
Kitchen Ranges Logo
15 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
