Question about General Electric DVM1950SRSS 505 Adora series by GE Spacemaker 1.9 Over-the-Range Microwave Scratch and Dent
GE Adora microwave worked 20 minutes ago. Now, totally dead. The lights, fans, turntable motor, microwave cooking elements, nothing.. works. AC power to the outlet is just fine.
Totally dead. Nothing works. AC power source is ok.
    Habit-Forming:
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
Sometimes if a lot of steam has been produced while cooking, water may collect under the turntable plate and run down the spindle into the turntable motor. This can short circuit the motor and it will take the fuse out with it.
The fuse is usually housed in a plastic tubular case about 2inches long. Split the tube apart and replace the fuse if necessary (it's something silly like about 7000 volts). Switch on and check to see if anything else is not working like the turntable, lights, or fan etc and replace as necessary.
Posted on Feb 19, 2014
Environizer doesn't work
Is it dead? does the motor run? Fan blow? No freshened smell from unit, only stale odor? You haven't given any usable info here but I'll address a dead unit condition for you: power cord stretched/damaged, on/off switch bad, fuse/cicuit breaker(if any are used).
Jun 15, 2014 | Air Purifiers
I have an ecoquest flair that the fan won't run.
bad capacitor in the control head..if you run it at full speed, you may be able to run it hardwired(but it becomes a safety issue) may need it replaced..
Jan 18, 2014 | Ecoquest Fresh Air Air Purifier
Fan wont turn
I have taken one apart. reassembled and the fan would not turn, although there was power to the motor and it wanted to turn.
Sorry this is long...only this is about taking the motor itself apart..and I have yet to find a replacement motor.
1. Tried a little WD 40...(only on iron motor Housing!) nothing.
2. Took apart inside of motor. some rust inside..
3. carefully rubbed clean with WD 40..
4. leaned off WD 40 with contact cleaner...
5. Then worked little bearing loose on back side.
-Kind of turned upon reassembly..
6. Found some silicone High temp lubricant and took motor inside part again.
7. a very thin coat of lubricant inside rotor.
-Re assembled yet again..began to turn at high speed, kept running..24 hrs..
- It .finally turned at silent mode. and continues to work
This may be ar beyond what you want to do, however if all else fails...what else can you do? buy another one?
Tips:
1. mark rotor holders with housing. (do not reverse.)
2. make sure you remove all lint, dust, etc inside.
3. the rotor bearing I had to work by hand again and again repeatedly syringing a little WD 40 at a time to until it turned easily.
Jun 04, 2012 | Oreck XL Professional Air Purifier
Id like some instruction on how to use ? curently trying to remove odours from a vehicle ? some instructions on how to use the unit would be a great help
Odors from a vehicle takes 2-14 hours on "high". Depends on the odors. Run the AC & heater fan for 20 minutes also when the car is full of ozone and have the unit aimed up on the floor toward the firewall on high. You should not stay in the car while doing this. Mild new odors can be neutralized in 20 minutes to 2 hours. Bigger and older problems take longer.
May 23, 2011 | Ecoquest Breeze AT Living Air Purifier
I cleaned my Flair air purifier, The motor turns on but not the fan even after lubricating the fan shaft and giving the fan blades a little push. Any suggestions on how to get this going?
The Flair is no longer manufactured nor serviced by EcoQuest, and the company is now Vollara. If what you're hearing is the fan motor (there is no other motor associated with this machine), it might mean that either it's totally seized up, or that the oil just has not penetrated deeply enough.
1) Turn the machine over and remove the large screw in the bottom. The chassis will then slide out (I assume you've already done this in order to reach the fan shaft.)
2) Firmly pull on the fan blades near the center in order to pull them free of the shaft.
3) Turn the chassis on its back, so the fan shaft points up. Drip a small amount of lightweight oil (sewing machine, hair clipper, 3-in-1) on the shaft and turn it manually to work the oil down the shaft. Continue doing this if you feel the shaft loosening up.
4) Set the chassis upright, tilt it forward, and drip a small amount of oil on the rear opening to the fan shaft. Continue manually turning the shaft and tilting the machine to work the oil in.
5) Replace the fan blades and turn on the machine, depressing the safety switch manually, to see if the fan will begin to turn.
If it won't turn, it might mean that the fan motor is entirely seized up. You may be able to find a local small appliance repair person who could replace that motor.
Your other option is to call Vollara customer service at 800-989-2299 and ask them to explain your options. Use #16618 if you need a dealer referral number.
Feb 11, 2011 | Ecoquest Flair Air Purifier
Evcon Model EB15B Elements glow red for 3 minutes then cycles off. Fan stays off during the cycles. Manual fan switch will turn on the fan. Assistance requested, cls
the fan has to be on while the strips are on. knowing that the fan comes on when you switch it to on at the thermostat but not when your just calling for heat indicates that you have somting wrong with the heating relay or the fan isnt wired properly to the heating relay (posssibly a new motor during the summer) or just a bad relay. when the first stage heat comes on it should also energize the motor the first to come on is also the last to shut off which will make sure the fan runs during the whole heating cycle. until you remedy this you can run the heat just keep the fan switch set to on so its running, this will not hurt anything
Nov 24, 2009 | Air Purifiers
Fan motor is dead I think...is it okay to run ionizer still??
no , it is not advisable to run the machine while there is an exsisting problem , it would be best not to run it untill the motor has been replaced
electech
Nov 07, 2008 | Ecoquest Flair Air Purifier
Alpine XL-15 fan has stopped working
Hello night light,
How you proceed is going to depend on how comfortable you are taking it apart.
Given it's age and purchase condition, warranty isn't an issue. You will either be able to dis-assemble the purifier and try taking the motor apart and reassembling, or you can find a replacement motor (I've seen some on the web, they start at ~$50).
Another possibility is that the fan pot (the rotary switch that the knob turns to adjust the fan speed) may be out. If you have a multi-meter, see if you can get a signal through (when it's all the way open). If not, try replacing that first. Parts are available onthe web, I can't advertise per FixYa's terms of use.
Hope this helps.
Sep 28, 2008 | Alpine Air XL-15 Air Purifier
PROBLEM WITH BREEZE AT
It sounds like the fan motor may need to be oiled, front and rear. That has been my experience with stopping and starting at that length of interval.
Jul 26, 2008 | Ecoquest Breeze AT Living Air Purifier
General Electric DVM1950SRSS 505 Adora series by GE Spacemaker 1.9 Over-the-Range Microwave Scratch and Dent Logo
166 people viewed this question
Top General Electric Air Purifiers Experts
Michael Youngman
Michael Youngman
Are you a General Electric Air Purifier Expert? Answer questions, earn points and help others
