Question about Lite On LVW-5115GHC+ DVD Recorder
Won't read DVDs
I've owned this DVD recorder for over a year, and have recorded DVDs on this unit before, but now it won't even recognize blank discs or some DVDs I put into the machine.  It will say invalid disc, or with a blank disc it will begin preparing, but then stop abruptly and spit the blank disc back out.
What is happening?  Please help me, this is getting pretty annoying.  Thanks in advance.  :)
  • 4 more comments
  • Anonymous Nov 04, 2007
    same problem took apart cleaned everything it plays every kind of disk just work prepare and burn any thing...and it always worked
  • Hawkaida Dec 02, 2007
    I was able to fix it just by taking the case off and plugging in the DVD recorder and ejecting the tray. Then to keep it ejected while turning it off, I had to just pull the plug, while the case was sticking out. To clean the dust out, I use a can of compressed air, and cleaned it thoroughly. I also cleaned out the remaining dust within the rest of the container, and the first disc I loaded worked just great. So there was no need to open the DVD drive itself.
  • Anonymous Dec 27, 2007
    I have the same problem. I have tried re booting but it is still happening
  • pkjenkins Jan 17, 2008
    I have an LVW-5115GHC+ for about two years now. The unit WILL NOT prepare ANY Lightscribe DVD+R 16x disk, nor will it prepare a DVD+R 16x disk. It WILL, however, prepare and record DVD+R 8x disks. I HAVE installed firmware update LNMPU030.DA2.
    I have compressed air and lens cleaner and will clean sytem. Will let you know how it goes but seems to be a firmware issue at present witth the 16x vs. 8x disk speed. ???
    Phil Jenkins
  • renfred Feb 22, 2008
    I have a LVW-1105HC that up until today had the same problem. I was getting ready to throw it out until I read the post on here. I went out and bought a compressed air can today, removed the cover, and sprayed the lense. It is now working like new and I am burning a disc as I type this!
Absolutely brilliant! I am so thankful for you guys! You've saved me buying a new DVD recorder!
Exactly the same problem was happening with mine. I followed the advice on this forum, took the cover off the DVD recorder machine, blew as hard as i could (can't get compressed air in this neck of the woods at this hour!!) and applied a little light dusting to the lens with a duster cloth! I put it all back together, and hey presto....!! It works like new! It suddenly recognizes discs that it wouldn't recognize before!
Thank you all!
G
Posted on Nov 12, 2008
Taking off the case and using compressed air worked for me! :-)
Posted on Feb 04, 2008
I had the same problem, too. And I sent the DVD-Recorder back to Lito-on for exchange. But the new unit still had the same problem. So, I tried a solution posted here. It clearly worked with 1-2-3. Thanks all.
Posted on Dec 30, 2007
    Novelist:
  • 158 Answers
Hi, Ive just repaired several liteon's ( incidently they are identical inside to some philips models ). In most cases the non writing or non reading problem is caused by dust on the laser glass. You have to open the unit then remove the dvd drive then remove its covers and just give a wipe of the laser with a clean non fluffy cloth. If theres lots of dust in other parts of the drive then this will need to be removed also as it could easily get onto the laser when in use. Even almost new liteons can suffer the problem , it only needs a little bit of dust to top the laser shining onto the dvd , instead the dust just reflects the light back. Hope this helps.
Posted on Nov 02, 2007
Wont read discs
follow this steps, and use the common sense.God bless you
If the player skips, make sure that the DVD disc is not dirty or scratched..Use the cleaner disk buy it from R. Shack.
If the tray won't open or close properly, check the belt for dirt or wear. Then check the tray for misalignment. If needed, remove, clean, lubricate, and reinstall the tray following the instructions in the owner's manual.
Sep 19, 2012 | Panasonic DMR-EZ37VK DVD Recorder / VCR...
What do + and _ signs mean on blank dvds
- RecordNow! can record only to the same disc type
it records from. For example, you can record a
DVD only to a DVD+R or DVD+RW disc, and you
can record a CD only to a CD-R or a CD-RW disc.
you were using DVD-R, so it won't work.
hope this helps
Jun 18, 2012 | Verbatim Blank DVDR Discs/DVD R Media -...
Toshiba D-VR3SU DVD recorder VCR won't record
Checking recording side circuit is a very very skilled job. Get it repaired by the authorised service center for Toshiba at your town.
May 21, 2012 | Televison & Video
My DMR_E80H recorder does not read blank dvd-r disks
I don't have a solution but I am having the same problem (same model DMR-E80H). It will read finalized dvds but won't recognize or play blank or non-finalized dvds. About a year ago I had to replace the hard drive . . . I'm just assuming that the dvd recorder is just slowly breaking down and will need some kind of repair of certain components. (I think we bought it new in 2003/2004?)
Feb 13, 2011 | Panasonic DMR-E80H DVD Recorder
Disc error message when load DVD
Are you loading to play or to record?
Commercial DVDs should play.
DVDs for recording may not be recognized by your drive. First make sure that the disc is blank. You must insert a blank disc of the proper format: DVD-R or RW, DVD+R or RW. Even with the proper format, some brands may not behave the same way as other brands.
Dec 24, 2008 | JVC XV-N320 DVD Player
DVD-RW not recognising blank disk
Usually HPs are good with +R DVDs unless things have change over the last year or two.
Whats the model number on your computer?
Aug 09, 2008 | Tablets & eReaders
Can anybody help me, I purchased a Samsung dvd recorder model dvdvr350m, since purchasing the unit it will not recognize that it has recordable dvd's in it (dvd-rw),it tells me no disc inserted please...
Did the sales guy use the same DVD-RW that you did? Maybe the brand you are using is not of good quality and can not be recognized by the recorder. If he did not use the same disc did you notice if he used DVD-RW or DVD+RW? Some DVD-Recorders only recognize one or the other but this is kind of rare these days. I recommend verbatim brand discs. They should be available for sale at any shop. If you want the ultimate in quality DVDs then go with Taiyo Yuden. This Japanese brand invented recordable media and in addition to that they are obsessed with quality. www.supermediastore.com is always where I get my discs.
Thanks for reading!
Hope this was helpful
Apr 30, 2008 | Televison & Video
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Can't record DVDs
OK. Finally "solved" this problem. You must use the brand name "Maxell" DVD disks, 2x or 4x (maybe 8x). Do not use variable speed disks (e.g. 1x--4x) or 16x. Walmart carries these!
The DVR -RW 2x finally got mine to record. I didn't think this would work, but it did. I am still experimenting with it. Had to download (free) VLC player to get it to play on my computer. Works fine in other DVD players.
Credits to the Sears' repairman, the guy at F., and my patience!
Oct 24, 2006 | Sylvania SREC427 27 in. TV/VCR/DVD Combo
Lite On LVW-5115GHC+ DVD Recorder Logo
527 people viewed this question
Top Lite On Televison & Video Experts
Jaime Hernandez
jason
Are you a Lite On Televison and Video Expert? Answer questions, earn points and help others
