Question about Boating
Heater for 26' Make walk around
Heater makes breaker pop when you first turn on the heater, filters have been cleaned
    Top Expert:
  • 43,110 Answers
Sounds like you might need to replace the breaker . they do get weak with age .or perhaps the heater is too big wattage wish.
Posted on Apr 01, 2014
Circuit braker keep popping
Sounds like the heating element has gone out again. Once you reset the circuit breaker and the tub turns on it will start to circulate the water. This usually runs like this for about 2 mins and then the tub will recognize it is cold and send power to the heater. If the element is back at that point it will blow the circuit breaker.
If this circuit breaker pops as soon as you turn it on then you most likely have a bad circuit board.
Rod
www.uspartscenter.com
Jan 30, 2013 | Jacuzzi Home
I have a rheem 40 gal electric water heater. The GFI on the tank keeps popping do you know what could be causing this
10-23-12
Your tank has a GFCI circuit breaker?
Maybe you mean ECO reset button located on upper thermostat?
If GFCI circuit breaker is tripping, turn power off, open covers inspect for burned parts, and test elements. Copy following link for troubleshoot walk-thru:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#trip-breaker
If ECO reset button is tripping, then replace both thermostats, and test elements.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
http://waterheatertimer.org/How-to-test-water-heater-element.html
Oct 22, 2012 | Water Heaters
Cleaned filter now it wont run
If you soaked the filter it will not work make sure the filter is correctly inserted and all the surrounding parts to the filter are attached and appear normal reset your breaker bar you might of accidentaly caused the breaker to pop
Aug 05, 2012 | Frigidaire ATF6000ES Front Load Washer
My electric furnace smells like burning hair when it kicks on. what can I do? Is my house gonna catch on fire?
Hello
I would shut down the heater and have a look at the filter,sonds like it may need to be changed.
Next have a look at the heating elements and vacum them off once heater cools down.
Dec 02, 2010 | Heating & Cooling
Walk In Freezer won't start up
It sounds like your drain heater is the type that should be deadended. Power makes the circuit between the material it is made of. It is to just be warm, not hot. I've not seen this in some time but that's how they used to work.
Generally speaking, walk-in freezers have bunches of controls.
http://www.master-bilt.com/pdfs/io_manuals/condensing_unit_io.pdf
go to this web site as it will cover the M series unit. Do this first and if you are still having a problem, get back to me.
Jan 20, 2010 | Master Bilt Commercial Freezer 860808
My Hayward electric spa heater 11KW is coming on for thirty minutes, then throws the breaker. If I switch back on it will throw it again in another 30 mins or so. It appears to be heating then throws the...
Chances are that your element is drawing too much current. Check the manufacturer's website to make sure that you have the correct size breaker installed. Low water flow could also affect this, so make sure all of your baskets and filters are clean and clear.
Apr 05, 2009 | Hayward Comfort Zone Electric Spa Heater...
Swimming pool cleaning robot doesn't move
Sound like your filter is dirty. Try backwashing if you have a sand filter, or clean your cartridges if that's what you have. A dirty filter will reduce water flow, which in turn affects the Nav.
Dec 10, 2008 | Hayward Navigator Pool Cleaner
Curcuit breaker pops
hello elanalex,
When your heater shuts off it trips your main breaker and that is usually associated with the interupt capacity of the breaker ( which means that while your heater is drawing current, if the thermostat says stop.. you are interupting that current demand abruptly and your getting a surge back to your breaker, You may be able to add a surge arrestor to that power feed to suppress that problem. You may also be able to repsecify your main breaker with one that has a higher interupt capacity.. Check with a local electrical supply house..explain the problem and they should be able to provide a hardware solution. Make sure you provide details on your circuit breaker brand so they can provide the proper solution.. GoodLuck
Regards,
Rick
Dec 04, 2008 | Dayton G73 Utility Heater
Boating Logo
22 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
