Question about MSI K9a Platinum Crossfire Socket Am2 Motherboard
Pc won't restart automatically after power outage
Have set bios to reboot after power outage but it does not work. I have ups which shuts it down properly and then cuts power. When power is restored pc should reboot but does not
  • MSI Master
  • 27,725 Answers
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty
http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm
Testing & replacing the PC's power supply
http://www.youtube.com/watch?v=hbNxhvm0czs
One bad lead can cause a computer to continue on a cycle of restarting or to shutdown or fail to detect/ boot up a computer hard drive
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards
Remove the memory modules from their slots.
Take the opportunity to clean the slots on the motherboards and the memory module connectors.
Use compressed air to blow dust away and clean contacts with a soft cloth.
Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components.
Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol (Methylated Spirits) on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r
Allow the pins to dry.
They will air dry in a matter of minutes.
If reseating the memory did not resolve the issue try swapping the location of the memory.
If you have only one stick of memory in the computer try moving it to another slot and then boot the computer.
Check the memory module and memory slot contacts.
They are either copper tin or gold.
The colour will tell you which they are.
Mixing tin and gold can result in corrosion that prevents proper contact.
Look for any sign of physical damage to the memory module, memory slots or the motherboard.
Reseat the memory modules.
You should hear an audible click when they are in place.
Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard.
The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible.
Could be a problem with the Hard Drive or the Hard drives PCB
http://www.onepcbsolution.com/
http://www.youtube.com/watch?v=du0Qd_3wFWM
There is a connection problem such as a bad cable
for internal hard drives
Test all power and data leads that attach to your hard drive SATA
the leads from yourMOTHERBOARD TO THE HARD DRIVEmake sure they have a
secure dust free connections and are not faulty although very rare for sata lead to fail
Make sure all leads that are attached to your drives dvd\cd and floppy (If Applicable) have secure connections and are not faulty.
or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
You might have a virus or malware.
Download at least one of these of course it will depend on your operating system.
http://www.majorgeeks.com/Microsoft_Security_Essentials_for_Windows_d6242.html
microsoft security essentials your operating system must be registered
Win7/Vista/XP 64 bit
http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62 anti malware free edition Win XP/2003/Vista/Windows7
http://windows.microsoft.com/en-US/windows/products/security-essentials/product-information
malware protection
http://100-downloads.com/download.php?p=615
windows xp microsoft security essentials
http://100-downloads.com/download.php?p=614
windows 7 microsoft security essentials
Posted on Feb 17, 2014
  • 1 more comment
  • Mark Webb
    Mark Webb Feb 18, 2014
    Thank you for your replies but it is evident from them that you do not understand my issue. The pc is working perfectly in every way. However when there is a power failure it does not restart automatically.
  • Mark Webb
    The bios has setting to automatically restart after a power failure but this option does not work either after a power fail or after shutting down the pc. disconnecting and reconnecting the power.
  • Brian Sullivan
    Brian Sullivan Feb 18, 2014
    Which operating system ?The BIOS information is typically found at or near the top of the POST screen for a very short time ALR PC non / PCI = CTRL+ALT+ESC ,AMD advanced micro devices=BIOS = DEL, Award BIOS = DEL ,Dtk Datatech Enterprises Co. BIOS = ESC , Phoenix BIOS = CTRL+ALT+S , Phoenix BIOS = CTRL+ALT+INS ,Restart your computer during the boot process you will see on the screen to press a certain key usually Delete or F2 to enter setup this will differ depending on which bios you have Press and hold that key during the boot up process to enter BIOS if you have changed any of the BIOS settings by mistake you can load failsafe or optimised defaults using the arrow keys you can after you make any changes in BIOS press Esc then press the F10 button save to cmos to restart CMOS is an on-board semiconductor chip powered by a CMOS battery inside computers that stores information such as the system time and date and the system hardware settings for your computer..this will reset your cmos
Gateway MT6840 unexpectedly shut down and wouldn't
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Feb 12, 2013 | Computers & Internet
Computer freezes after bios screen on every restart.
One thing you could check is what order your computer is booting from. CD drive hard drive then other. Should be hard drive first. Go into the bios to do that. If you hold the power button down for 5 to 10 seconds the machine should physically shut down rather than unplugg. The unplug thing sounds like its in the power settings. But I've never heard of power settings being connected to bootup except for a password. Anyway a wild guess is check the bios bootup order.
Dec 31, 2009 | Toshiba Satellite® A215-S4807 PC Notebook
Dell Dimension 5100 shuts down then reboots automatically, This is one bugger of a problem. Had continual problem with unit shutting down no rhyme or reason, cant see BSOD message off too fast. Did change...
Try rebooting to Safe Mode. Right-click on My Computer and hit Properties. In the System Properties window, click on Advanced. Then click on Startup/Recovery Settings. Uncheck Automatic Restart. Then post the BSOD Stop Code here.
Nov 18, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Automatically rebooting computer after power failure
The bios settings turn the computer on automatically. I actually have mine set to turn on automatically in the morning before I get out of bed so it's already on when I get up. Watch what you see on your screen as you boot up the computer and do whatever it tells you to do to boot up in bios (typically by hitting the F2 or Del key). Once in bios, go to the power section. In the power setting you should see something pertaining to the modem. If you do NOT want it to power up automatically, choose the Disable option. If you DO want to power it up automatically, it will also ask for a time (day of month, hour, minute). If you set the day as 1, for example, it will power up on the 1st of the month at the time that is set. If you set the day of the month to zero (0), it will power up every day at that time.
Oct 02, 2008 | Compaq Presario SR1000T (568657) PC...
Poweredge 1800 trouble shooting support
Upgrade your bios or set temperture high on the management software
Jun 16, 2008 | Dell PowerEdge 1800 Server
Medion MD96420 notebook : Windows explorer keeps shutting down and restarting
Check Ur power settings in the control panel. U may also check the power settings in the bios on reboot (F2). Either one can put the system in shut down or hibernate. Need more information as to what is going on if this is not the problem.
Jun 11, 2008 | Medion Computers & Internet
Automatically retarting when I shut down computer
2000 Is Windows 2000. Why did you put that disk in? Did you start loading Windows 2000 or XP Pro, XP-Home?
It sounds like your switch is wired to the reset jumper on the motherboard or you are hitting reset.
Tell me what the computer screen has on it before it shuts down please.
I will wait on you answer. Do not rate until we are done.
Jun 10, 2008 | Computers & Internet
Processor
be more specific. Is the PSU powers on, Do you have any LED's on, any fans spinning, any sounds out.
Feb 11, 2008 | EliteGroup P4M800PRO-M478 Motherboard
Shut down
The best thing you can do is to reinstall windows. This will surely fix the problem.
Jul 26, 2007 | Acer Veriton 5600G PC Desktop
Can not save to bios
windows and the bios needs to know that the operating system can be shut down through windows, so when you go into the F2 or Del on boot up, go into advanced cmos setings and look for ACPI and make sure it is enabled. This sets the motherboard to support shutdown. Save and exit settings and reboot. Now go to control panel>performance and maintanance>power options and set the correct instruction for shutdown to shut the pc down. Remember evertime you remove the cmos battery or reset with jumpers you have to reset date and time and anything else you have changed to suit your set up
May 06, 2007 | Abit KN8 SLi Motherboard
MSI K9a Platinum Crossfire Socket Am2 Motherboard Logo
117 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
