Question about KitchenAid Microwave Convection Oven
Kitchen aid kemms308sss04 plastic insert on turn table broke how do you replaace
Plastic insert for turn table broke how do you replace
  • KitchenAid Master
  • 9,047 Answers
That may be called the turntable coupler or turntable support or roller ring assembly.
You can find helpful exploded views and part numbers at the link below, by replacing XXX with the full model number found on the tag on your microwave (not on the service manual).
XXX&siteCd=WHRCOM&userType=Consumer">http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=XXX&siteCd=WHRCOM&userType=Consumer
My preferred place to order Whirlpool parts is from the Pro here.
Posted on Feb 17, 2014
3 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: kitchen aid khms147hss0 microwave - handle broke
Door parts are available separately on this model.
The parts manual is here. And you can order parts here.
You have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Posted on Dec 05, 2009
kardon802
SOURCE: I have kitchen aid model KHHC2090SSS0 microwave.
you can buy that part online kitchen aid.
Posted on Nov 15, 2011
I have a kitchen aid microwave and when turning on sounds like the bird chirping around the bottom of the unit.
Does it have the option to turn the turn table off if so turn it off and see if noise goes away if so turn table motor very common over time it will default back to on on next cycle
Feb 20, 2015 | Microwave Ovens
Kitchen aid micro wave change fuse
Unplug, remove top, look under keypad, follow wires to circuit board, look for a silver rectangular capacitor, "may be under a plastic flap" discharge capacitor with a screwdriver across the 2 points, look for a small fuse near by in clips, remove and replace with same current rating, assemble before test because lethal voltages present when powered.
Mar 11, 2012 | KitchenAid KHMS2050SSS Microwave Oven
Kitchen aid khms147hss0 microwave - handle broke and gray plastic ( has 3 screws) on perimeter of door itself cracked - was going to replace complete door - how do you replace the complete door - remove...
Dec 05, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
The turn table no longer turns. Everything else works fine. How to see what's broke?
Remove bottom panel,< screws along front and tips down > the turntable motor is in the middle. Unplug motor and use multi-meter< insert probes into plug end > run short cycle with something inside of unit," glass of water ", if you have voltage here then the motor is bad and needs replaced. If not then mother board most likely problem.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jul 12, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Little plastic ring with wheels broke in several places
the purpose of the turntable is to more evenly cook the food. it shouldnt effect the mics ability to cook, just might take a little longer to thoroughly cook food
Apr 21, 2009 | Emerson MW8625W Microwave Oven
Need to plastic coupler that holds turn table in place
If you need a replacement turntable coupler, you can find this part listed as item number 942560 at repairclinic.com. Just type in your model number.
To replace, all you need to do is carefully slide something under the existing coupler (if you can) and pry up. The coupler will pull off the motor shaft.
If you cannot access the coupler due to the way it was broken, simply remove the bottom panel UNDER the oven. With the panel removed, locate the small turntable motor and loosen the mounting screws to remove. The coupler should be easily accessible with the motor out of the unit. Make sure you reinstall the turntable motor and bottom panel BEFORE you try to install the new coupler. The coupler needs to be installed from inside the oven cavity by placing it in the opening in the oven floor and pushing straight down onto the motor shaft.
If you have questions, or require additional assistanc, please let me know. I hope this helps you.
Jan 14, 2009 | Hotpoint RVM1435 Microwave Oven
The door of my Kitchen Aid Microwave YKCMS1555RSS wouldn't open because the plastic prods that push open the latch had worn down. The oven was otherwise functional. I inserted some plastic knobs to extend...
The door latch heads (prods) are not making proper contact with the door switches, so it will not work right.
The latch heads need to be replaced.
You can order parts for this Canadian model here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 02, 2008 | Microwave Ovens
Turn table stopped spinning
If everything on the microwave works, except the turntable, this could be a simple turntable drive motor failure. It does happen from time to time. This motor gets a workout as it runs each and every time you use the oven. I just want to reassure you that these DO wear out and should not be an indication of the quality of the oven. I've had to replace them before. The motor costs about $34 at searspartsdirect.com. That is...if your model number is correct. You will need to go to the web site and type in your COMPLETE model number. There are several Kitchen-Aid models listed with the number you provided. I managed to scroll through several of the part listings and they all seem to be consistent with identfying the motor you need as item #11 under the "Oven Cavity" heading. The part number is W10159107. This is a fairly simple repair job. You shouldn't have to uninstall the oven if it is cabinet mounted. All have to do is unplug the power source and remove the panel covering the underside of the microwave. The plastic spindle just pulls off the motor shaft. Let me know if you need further assistance. I hope this helps you.
Apr 03, 2008 | KitchenAid KCMS145J Microwave Oven
KitchenAid Microwave Convection Oven Logo
69 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Stu Ungar
Darial Jr Lasaria
Darial Jr Lasaria
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
