Question about Pyle PLDN74BTI Car Video Player
Pldn74bti car stereo
Wiring diagram
I have a 2000 oldsmobile alero and I can't get sound out of my rear speakers good speakers and connection just no sound
OLDSMOBILE ALERO 2000 speakers - Sonic Electronix
www.sonicelectronix.com/oldsmobile-alero-2000-car-speakers.html
OLDSMOBILE ALERO 2000 speakers - find speakers that fit your ... sound. This size is capable of delivering exceptional mid-bass that can't be found in smaller ...
2001 Oldsmobile Alero Car Radio Stereo Audio Wiring ...
www.modifiedlife.com/2001-oldsmobile-alero-car-radio-stereo-audio-wi...
Easy Plug and Play Wiring Adapter. ... 2001 Oldsmobile Alero Car Radio Stereo Audio Wiring Diagram ... If you can't find your car audio wire diagram, car stereo wire diagram or car radio ... Right Rear Speaker Positive Wire (+): Dark Blue ... olds alero and I have replace the stock stereo and have found that the sound out put ...
Request a Oldsmobile Car Radio Stereo Wiring Diagram
Jan 21, 2016 | Oldsmobile Cars & Trucks
No power Pyle PLDN74BTI
Is your power cord plugged in? Are you using a power strip extension cord, if so check it to see if the power surge button hasn't been tripped. If so reset it. See if your wall outlet is working by plugging something else into it. If not working reset your breaker.
Oct 06, 2012 | Pyle PLDN74BTI 7 Double DIN TFT Touch...
No picture on my a Pyle PLDN74BTI
bypass parking brake w/no switch codes
Oct 06, 2012 | Pyle PLDN74BTI Car Video Player
Help with seeing the video off my Pyle PLDN74BTI
bypass parking brake w/ no switch just codes for pyle pldn74bti car player
Jul 23, 2012 | Pyle PLDN74BTI Car Video Player
94' plymouth voyager care stereo wiring diagram needed
1994 Plymouth Voyager Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Red/Black
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Strap or Chassis
Car Radio Illumination Wire: Black/Yellow
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: Yellow
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Dark Green/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Violet/Yellow
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Yellow
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Jul 05, 2009 | Metra Chrysler/Dodge/Plymouth Speaker...
2005 Neon SXT Stereo Wiring Diagram
2005 Dodge Neon Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink/Light Blue
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Orange
Car Stereo Dimmer Wire: Black/Yellow
Car Stereo Antenna Trigger: N/A
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Negative Wire (-): Dark Blue/Red
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Jun 19, 2009 | 2005 Dodge Neon
Ford taurus
HERE IT IS. PLEASE RATE ME.
2004 Ford Taurus Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Green/Black
Car Radio Accessory Switched 12v+ Wire: Black/Pink
Car Radio Ground Wire: Black/Green
Car Radio Illumination Wire: N/A
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Blue/White
Right Front Speaker Positive Wire (+): Tan/Green
Right Front Speaker Negative Wire (-): Green/Orange
Left Rear Speaker Positive Wire (+): Gray/Blue
Left Rear Speaker Negative Wire (-): Brown/Yellow
Right Rear Speaker Positive Wire (+): Black/Violet
Right Rear Speaker Negative Wire (-): Orange/Violet
Nov 14, 2008 | 2000 Ford Taurus
Stereo wiring diagram
2006 Ford F150 Truck Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Light Green/Violet
Car Radio Accessory Switched 12v+ Wire: Light Green/Yellow
Car Radio Illumination Wire: Light Blue/Red
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
Jul 28, 2008 | 2006 Ford F-150
Pyle PLDN74BTI Car Video Player Logo
22 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
