Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Whirlpool cabrio top load washer noise during first rinse cycle
Makes a noise like loose change is banging around in the tub
4 Suggested Answers
Coldcut
  • 1554 Answers
SOURCE: Whirlpool LHW0050PQ Front Loading Washer VERY NOISY during spin cycle
remove the top access panel 3 screws in top rear.
now look around and push on the drum from top
it has suspension shocks and springs like your car they should resist any movements.
look/wiggle the concrete balance blocks , no cracks or loose.
inside the tub are the arm solid /not loose.
run it with the top open what do you see/hear and where
look under the rubber flap in front did anything get under the tub
Posted on Mar 04, 2008
  • 92 Answers
SOURCE: Whirlpool top load LSQ9549L stops working at rinse
sounds like your lid switch is bad or possible timer
Posted on Jan 11, 2010
  • 1382 Answers
SOURCE: loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Posted on Apr 08, 2010
Drum is loose during Spin and Rinse cycle and banging against side of washer
If it is under warranty, call Whirlpool at 1-866-698-2538. If it is out of warranty, try running the washer with no clothes in it in spin cycle. If it runs fine empty, it may be that when you had clothes in it they were not balanced evenly in the tub. If it runs off balance when empty, then a spring may have broken or come off. Contact an appliance repairman.
Oct 31, 2013 | Whirlpool WTW4880AW 3.4 cu. ft. Top Load...
Klunking noise and banging at spin cycle. balance ok
Check your suspension supports, when empty move the tub around it should re-center with force like it fights you to be in the center,
Sep 18, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio makes excessive noise during spin cycle
Your model has a bearing under the tub which is probably going bad and needs to be replaced. cabrio washer bearing replacement YouTube
Oct 28, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a whirlpool cabrio washer WTW6600SW2. The washer makes loud thumping noise during spin cycle and then uL code flashes and it stops until you open the door. After moving the clothes around and...
ON SOME CAPBRIO IF YOU HAVE SOME LIME ONTHE WATHER THE TUB IS A FREE FLODING AND WILL GET STUCK ON THE UP POSICHONAND WOND GO INTO SPIN. TRY TO RUN A CLEANER YOU CAN VUY AT ANY BIG WALL MART. IF NOT TRY TO LIFT TUB AND PUT BACK DOWN . IT SHOOD BE VERY EASY TO PULL UP IF NAT YOU BEST BET ID TU BUY A NEW WASHER. PARTS ARE PRICY.
Jun 30, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Cabrio washer makes a banging noise when in spin cycle
Might be a broken support rod. Use this manual as a guide:
Cabrio notes
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 09, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Once the washer gets to the drain or rinse cycle it makes a banging noise n stops
sounds like one of the tub supports are loose or broke. check stabilizer arms
Aug 01, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Loud banging noise during rinse
Apr 08, 2010 | Whirlpool GHW9100L Front Load Washer
Washer agitates off balance and makes a loud banging sound until movement stops at the beginning of rinse cycle, advice?
If it makes this noise in the agitate mode and not during the spin cycle, I would suspect that the transmission is going.
Jan 03, 2010 | Whirlpool Ultimate Care II GSW9650LW Top...
Dec 29, 2007 | Whirlpool LHW0050PQ Front Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
12 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
