Pioneer vsx 9500s
No sound
renosean
  • 492 Answers
SOURCE: hello all;;;;;; i have a
You CAN NOT plug the cable from your cable provider into your reciever.  You must buy or use the supplied antenna.  Your cable providers signal comes across the line at about 70volts.  Leaving it plugged into your reciever will damage the tuner unit.
Posted on Jan 04, 2009
SOURCE: pioneer-vsx-9500s radio won't work with cable
I have this reciever and have never had a problem hooking up cable direct
You can purchace a filter that will filter out tv stations and leave you with just fm
I do find however by hooking up to cable direct that station tuning is is not on its alocated slot and some stations are doubled
OTA is better but only if you have an outside antenna
Not sure how you have made the connection to the receiver is there an in line amplifier installed somwhere also its a good idea to make make sure the cable is properly grounded to avoid any potential standing wave problems which in that case could damage the tuning section of your reciever
Posted on Feb 12, 2009
Gurudristi
  • 98 Answers
SOURCE: Pioneer VSX-D209 receiver shuts off when too loud
Dear Tabasco,
Your receiver is basically going into protect mode.
Just check your speaker cabling again. Make sure that all of them are seated properly, none is touching each other or the body of receiver. Take out all the wire and put them back again if necessary..
Some times even a little tiny frayed wire touching the receiver could trigger the protect mode. Be careful, since protect mode is sometimes not fast enough and it could blown a few trasistors in the power circuit.
Just check your speaker as well....whether they play all right thru another receiver or amplifier. its posiible they might be shorting inside. A little frayed wire could also trigger the protect circuit in your receiver.
I hope this should solve your problem.
If everything else seems all right and still your receiver shut down when you raise the volume then it possible that there are bad connections on the main board that are set in.
This would generally happen if the system is slighly old or have dry solder and when you raise up the volume. This should be a simple repair that will not require parts. If you can solder, you will be able to repair this yourself. If not, then a local service center will change the local labor rate.
Hope you can sort out your problem with the above trouble shooting. Let me know if I can guide you further.
Best of luck! Thanks for using FixYa!
Posted on Apr 21, 2009
SOURCE: I have pioneer vsx 1000,its turn on but dont have sound
maybe the audio amplifier IC are damaged
Posted on Jul 13, 2009
mlapres
  • 757 Answers
SOURCE: Pioneer audio receiver pre-amp output
It is possible then that the root cause may not be electrical, but acoustic if you're noticing the issue from your listening position.
If you can run a channel test signal identically one channel at a time by positioning your meter less than a foot away and exactly the same distance with each speaker and the level differs by more than 1/2dB, then it's not the acoustics.
Posted on Dec 24, 2009
Where can i find diagram for bad soldering for pioneer elite VSX-27TX stereo receiver?
You really should be an expert to do repairs on these recivers but if that is the case, you can get the maintenance manual here:
http://www.kallhovde.com/pioneer/tricomp/Audio/VSX/VSX-24_26_27_29_D908S_RRV2133.pdf
Jan 02, 2016 | Pioneer Audio Players & Recorders
Dec 24, 2009 | Audio Players & Recorders
Need a manual to download for pioneer VSX-43TX
pioneer is really good about providing pdf manuals just google pioneer electronics ltd
Feb 10, 2009 | Pioneer VSX-43TX 7.1 Channels Receiver
No audio output from Pioneer VSX-D608 Receiver
If it's under warranty..get a new one.
It's an internal breakdown ...tech service only.
Feb 05, 2009 | Pioneer VSX-D608 Receiver
Pioneer-vsx-9500s radio won't work with cable
You cannot plug cable from the wall into a receiver, you will blow the tuner card.  Use the supplied antenna or go to radio shack and ask them for an fm antenna.
Jan 04, 2009 | Pioneer VSX-D509S Receiver
Hello all;;;;;; i have a pioneer vsx-9500s,,,,the problem is i ran cable to my reciever so my fm radio will work but it doesn't,,,,,,,,i checked the cable on a tv and it worked ,,,,so i know the line is...
Nonsense. FM is included in MOST tv cable subscriptions- make sure your subscription includes this service. Do you have another receiver/tuner to test with?
Check all the connections between the cable entrance and your tuner; eliminate all splitters for testing. If you can get another tuner to work on your cable, it may be time to check into your tuner-
There is no difference in signal level between tv and fm- your receiver is not gonna burn up! If it has a 75-ohm cable input, use it!
Pioneer vsx d512
All you have to do is connect the coaxial out from pc to any audio i/p at the back of vsx d512.but ensure you select the right channel to play the audio ( eg. tape i/p select tape at front control, aux i/p select the aux at front control )
Aug 03, 2007 | Pioneer VSX-D511 Receiver
20 people viewed this question
 Grubhead
Grubhead
