Question about Dell Dimension 3000® Pentium® 4 2.8GHz, 256MB, 80GB, 48x CD-RW PC Desktop
Unlock to computer - Dell Dimension 3000® Pentium® 4 2.8GHz, 256MB, 80GB, 48x CD-RW PC Desktop
How to system unlock a gateway desktop computer
Press the "Ctrl," "Alt" and "Delete" keys on your keyboard simultaneously to unlock your Gateway computer.
Type the last logged-on user's login information and click "OK" if you see a locked computer message along with "Only domain/username or an administrator can unlock this computer."
Press the "Ctrl," "Alt" and "Delete" keys once again when you see the Unlock Computer window disappear. Log on as usual.
hope this helps
Jul 23, 2012 | Gateway Computers & Internet
Can not unlock ipod
How to Unlock an iPod
Your later generation Apple iPod can be locked to protect your personal data from anyone else's eyes. There are a variety of ways to unlock it depending on your access to the combination, the primary computer linked with the iPod, or neither.
Difficulty: Easy
Instructions
Unlock with the Combination
Remember the 4-digit combination you used to set the screen lock.
Enter the exact combination. If the combination is correct, the iPod unlocks and displays the screen you were on before you locked it.
The numbers on the screen flash red if you enter the code incorrectly.
Unlock with the Primary Computer
Plug the iPod into the primary computer linked to that iPod, the first computer you synchronized it with unless you have designated another computer as the primary computer.
Open iTunes and sync the iPod as normal.
Remove the iPod, following the normal removal procedure. The iPod unlocks automatically as you remove it.
Unlock by Restoring
Restore the iPod to factory settings if you do not have access to your primary computer. This erases all of the data you have stored on the iPod.
Plug your iPod into the new computer you want to be the primary computer. Open iTunes and click on the "Restore" button.
Reload your data, if it is available and sync your iPod. Remove it following normal procedures.
Have a nice day..
Feb 16, 2011 | Apple iPod touch
My ipod 30gb is locked and i want to unlock it please give me the codes to use
there are to options by which you can unlock the ipod. Follow any of the procedures tomorrow.
  1. Plug the iPod into the primary computer linked to that iPod, the first computer you synchronized it with unless you have designated another computer as the primary computer.
  2. Open itunes and sync the iPod as normal.
  3. Remove the iPod, following the normal removal procedure. The iPod unlocks automatically as you remove it.
Unlock by Restoring
  1. Restore the iPod to factory settings if you do not have access to your primary computer. This erases all of the data you have stored on the iPod.
  2. Plug your iPod into the new computer you want to be the primary computer. Open iTunes and click on the "Restore" button.
  3. Reload your data, if it is available and sync your iPod. Remove it following normal procedures.
Take care.
Aug 01, 2010 | Computers & Internet
When powered on the sandisk appears. Then appears a locked lock. I'm unable to perform any other task. How do I unlock the lock?
There are two options by which you can unlock the code on your ipod. Follow any of the procedures below to unlock your ipod.
Unlock by Restoring
Take care
Jul 07, 2010 | Audio Players & Recorders
Need to unlock the screen
Unlock by Restoring
Take care
Jul 19, 2010 | Apple iPod MA446LL/A MP3 Player
I need a passcode for my Ipod
Unlock by Restoring
Take care
Jul 17, 2010 | Apple iPod touch 3rd Generation MC086LL/A...
How do i unlock ipod touch 32gb....
there are two options by which you can unblock the code on your ipod. Follow any of the procedures tomorrow.
Unlock by Restoring
Good luck.
Jun 25, 2010 | Apple iPod touch
My gradson forgot the code to unlock nano
Unlock by Restoring
Taker care.
Jun 04, 2010 | Apple iPod nano
My son has put a code on his ipod touch that he cannot remember I have tried going into the computer drive picking up the ipod and changing the lock to unlock but it is also a new computer and i don't...
    you can unlock the ipod by following the steps below. Also make sure you have installed I-tunes on your computer. Firstly, you can unlock your ipod with your computer through the following means:
  1. Plug the iPod into your computer, I mean the computer you synchronized the i-pod.
  2. Open i-tunes and sync the iPod as normal.
  3. Remove the iPod, by following the normal removal procedure. The iPod should unlocks automatically as you remove it from your computer.
  4. Secondly, you can unlock the i-pod by resetting it:
  5. You can restore your iPod to factory settings if you do not have access to your computer. This process erases all the data you have stored on your iPod.
  6. Plug your iPod into a computer distinct from you used in sync it and also make sure you have i-tuns installed on the computer. Open iTunes and click on the "Restore" button.
  7. Reload your data, if it is available and sync your iPod. Remove it following normal procedures and it will be unlocked.
You can also get more instructions on how to unlock your i-pop from the below link:
http://www.everymac.com/systems/apple/consumer_electronics/ipod_faq/ipod-reset-code-to-unlock-screen.html
I wish you the best of luck.
Take care.
Feb 21, 2010 | Apple iPod touch
I4 got my code 2my ipod how do i unlock it
  2. Open iTunes and sync the iPod as normal.
  4. Unlock by Restoring
  5. Restore the iPod to factory settings if you do not have access to your primary computer. This erases all of the data you have stored on the iPod.
  6. Plug your iPod into the new computer you want to be the primary computer. Open iTunes and click on the "Restore" button.
  7. Reload your data, if it is available and sync your iPod. Remove it following normal procedures.
Sep 25, 2009 | Apple Audio Players & Recorders
Dell Dimension 3000® Pentium® 4 2.8GHz, 256MB, 80GB, 48x CD-RW PC Desktop Logo
24 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
