Question about Atlas HYSTER Reconditioned Forklift - 3 Stage with Side Shift, 6000-lb
Spark plug firing order
Firering ordre
Wire diagram for the fuel injectors on a saturn sl1
firering order should be on in take manofold fuel injector are in harness should only fit on one way
Aug 31, 2012 | Saturn SL1 Cars & Trucks
I have a ford explorer that was running find but we chanced the plugs n wires n now it is miss firering
Retrace the plug wire`s you have the firing Order off Take your Time Recheck Firing Order And Plug Wirer Positions to Cylinder to firing order
Aug 28, 2011 | 1996 Ford Explorer
My 95 lumina shakes and misses while accelerating tried plugs,wires,oil chage,air filter,fuel filter,oil filter,1 coil pack,1 rear exhaust push rod and lifter
honestly, sounds like you should go to basics-check compression first, clean the throttle body , check fuel pump pressure at the rail on top of the engine-if you have any kind of check engine light, you need to get the code pulled, you have an OBDI system, so it is not as easy to diagnose-another basic is having good electrical power-battery and alternator in good condition.
Mar 09, 2011 | 1995 Chevrolet Lumina
I replaced all the spark plugs and cyld 2 that was maken miss firer and now it says muti misfirer
Spark plugs never fail to fire,nor are they, seldom your misfire problem
Individual Coils,Coil Packs,Ignition Modules and vacuum leaks are.
Nov 24, 2010 | 2002 Chevrolet TrailBlazer
What is the firing ordr 2002 toyota prius
1.5L Hybrid engine Firing order: 1-3-4-2 Distributorless ignition system
Nov 21, 2010 | Toyota Prius Cars & Trucks
How do i know my spark plugs are firering in the
The best way would be to obtain a firing order diagram and go by that. You can probably look at the diagram somewhere online for nothing. Crossed wires are a pain to guess at.
Jul 10, 2010 | 1995 Chevrolet Cavalier
Wont start has firering spark
hi
You said spark plug is firing that is fine have you check fuel system check your fuel pressure regulator,also check your spark plugs conditions.
It can be fuel pump but first check the pressure fuel.
Feb 21, 2010 | 1996 Dodge Caravan
1988 toyota camery firering order i need the diagram of the engine and how the spark plugs go on the engine
THE spark plugs are 4 and the firing order is from the front (thats were the fanbelts are )and they are 1342
so the distributor the timing mark on the bottom pully and the rotor button point to the No1 plug lead and points just about to open,and the next lead will point to No3 lead ,and if so then you have the correct timing,,but the points set at 0.012" and the plugs to 0.025" ..And when engine idleing adjust timing on the distributor to advance (thats the oppersite to the way it fires and do it with the vacuum pipe off ,,then when engine runs good ,then tighten calmp and refit the vac pipe and test run.
Nov 15, 2009 | Toyota Camry Cars & Trucks
Will not start
If the spark for the coil is not hot hot enough it wont fire plugs... I assume you have checked wires
Aug 23, 2008 | 1995 Jeep Grand Cherokee
Atlas HYSTER Reconditioned Forklift - 3 Stage with Side Shift, 6000-lb Logo
358 people viewed this question
Top Atlas Home Experts
Donni Steen
Tom Chichester
Are you an Atlas Home Expert? Answer questions, earn points and help others
