Question about 2006 Chevy Cobalt - Sedan - Base Rack System
Chevrolet cobalt problems
Noise and vibration/shake in front end; replaced stabilizer end--didn't help; some say rac n pinion, some say axle. What gives?
    Champion:
    Habit-Forming:
  • 208 Answers
To me it sounds more like a lose bearing in the axle have it replaced you will thank me later. If it lockes up you will ether lose control are the wheel will fall off with the axle attached.
Posted on Feb 18, 2014
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
00Linc ls noise from front end sounds like tire road noise steering wheel shakes a little
Wheel bearing? If you turn left and it gets louder. It is the right wheel bearing. And vice versa.
Nov 07, 2015 | Cars & Trucks
Front end rotation noise
It should have been thoroughly checked. Noises like these on four wheel drives could several different things. A bearing, CV axle, or the differential, or bearings in the differential. A wheel bearing will make different sounds when making a turn. A CV axle is a constant sound. Differential bearings can come and go, depending on if it is a bearing for the axle or a pinion bearing. Axle side bearings usually make a constant noise. The differential can also come and go. Depends on acceleration or slowing down. All these sounds are also with a vibration. Slight to harsh.
Oct 26, 2014 | 2007 Jeep Patriot Sport
Vibration at 70 MPH.
Warped or out-of balance brake rotor? Also keep in mind that loose rear differential trailing arms that allow the rear differential to squirm around can also cause steering wheel shake.
May 19, 2012 | 1998 Jeep Cherokee
Can bad axel cause front end shake
yes. if the axle is bad and binding it can cause the front end to vibrate because it gets out of balance.
Aug 05, 2011 | Buick LeSabre Cars & Trucks
I have a 2007 Chevrolet Cobalt. Recently during a snow storm the vehicle went through a ditch. No damage was done to the car. It was the most minute accident ever. Anyways the next day i noticed some noise...
Based on your description, I'm thinking the problem is in the transmission casing. I was thinking it was a wheel bearing, based on your description, but that is contradicted by the fact that you say it doesn't sound like it's a wheel or hub bearing.
You say that the the rf cv axle is now leaking where it goes into the trans. I'd say that's a good place to start looking.
A damaged cv axle or half shaft might make more clicking noises on a tight turn. The cv axle is greased up and has balls inside some designs.
Have you checked the transmission fluid level to see how much fluid has been lost thorugh the place where the cv axle enters the trans.? If adding fluid makes the sound lessen or go away, then the trans. is at fault, vs. the cv axle.
Good luck on this repair.
Jan 16, 2011 | 2007 Chevrolet Cobalt Coupe
1998 Silverado 1500 Rear End Howl/Leak/Clunk/Vibration Pinion
A pinion seal leaks for one or boyh of these reasons. A worn pinion bearing or a driveshaft vibration, Sounds as though you have both. Do not confuse tire howl with gear howl, be sure.The rear end can run 3 to 500.00 if not more. Ck the gear oil in the rearend for metal content. That will tell you alot. The hard shifting is generally from a sticky spool in the trans valve body. Have the trans serviced w/new oil and filter. The new oil often cleans the moving parts of gum and varnish buildup.in the valve body. One more thing, the rear ends take a special oil and additive if it's a limited slip or posi lock. You will have a popping/binding noise when turning if the wrong lube is install. Have your driveshaft aligned and balanced at at driveshaft shop.or you will end up tearing up the tailshaft on the trans. Good Luck
Jul 07, 2009 | Chevrolet Silverado 1500 Cars & Trucks
Vibration in front end and popping noise
Check your u-joints in your front axles. It sounds like it is time to replace them.
May 23, 2009 | 2004 Chevrolet Avalanche
Front end shakes when accelerating
The desciption you gave is exactly how it feels when you have an axle with a bad inner CV joint. It won't make a "clicking" noise like when you have a bad outer CV joint, but will shake pretty bad on accel. If you crawl under the car while it's on the ground (don't lift it) and grab on to the axle close to the inner CV joint and wiggle it, there shouldn't be very much play in it. If there is play in it, replace that axle.
Apr 30, 2009 | 1997 Volkswagen Jetta
Vibration and noise from front end while driving
Jack up the front end and put stands under it and block rear wheels. Look at axle boots and see if they are cracked. Try turning wheel back and forth sharply and see if you can hear any clicking. Problem could be outer axle joints. If the boots are cracked or you hear a clicking noise you will have to replace the axle. The axle and boot come as a complete unit. Please let me know what you find out.
Apr 13, 2009 | 2002 Chevrolet Venture Passanger
It is likely both your track bar and the lack of a steering gear box stabilizer. The bushings on your stock track bar can be replaced with polyeurethane or metal bushings which will help curb the problem.
The steering stabilizer attaches to your steering gear box and your frame allowing the steering to be more stable. I have put both on my truck and it drives like a caddy now as a result. If I had to choose between the two items, my money would go to the steering stabilizer first. I believe I bought mine here:
http://www.xtremediesel.com/bd-powerperformancedodgesteeringstabilizer.aspx
Hope this helps
Apr 05, 2009 | 2006 Dodge Ram 2500
2006 Chevy Cobalt - Sedan - Base Rack System Logo
51 people viewed this question
Top Thule Vehicle Parts & Accessories Experts
randymanfive
Serge Joncas
Are you a Thule Vehicle Part and Accessory Expert? Answer questions, earn points and help others
