Question about Sony HD Radio and Dock Docking Station, Remote Control for iPod XDR-S10HDiP
Sony XDR-DS16iPN wont connect iphone5
2 Suggested Answers
susielangley
SOURCE: why wont my sony xdr-ds12ip play music from my
Hi, did you find a solution to this problem? I am having the exact same issue! So annoying.
Posted on Feb 25, 2012
My iPhone 6 will not accept calls/messages when docked with my Sony XDR-DS16IPN. All other functions between the phone and the dock work fine. Would anybody have a fix? Thanks.
Try restarting the phone, and check for any updates. If that doesn't work, your best bet would be to contact Apple support. It very well could be a defect.
Jan 18, 2015 | Apple iPhone 6
The time does not automatically set on my sony alarm clock XDRC706DBP
Afraid I have the same problem and I have to manually set.
good luck !
Jul 07, 2014 | Sony Xdr-c706dbp Dab / Dab Digital Alarm...
Xdr-c706dbp time settings changes all the time
Yes - I'm in Sydney and the clock intermittently changes time to -11 hours which is GMT - it has always had this problem and I have never found a fix. HELP
Jan 08, 2014 | Sony Xdr-c706dbp Dab / Dab Digital Alarm...
My Sony radio XDR-S55DAB has completely stopped working. Initially all that showed on the display unit was the symbol for a dead battery but this also appeared when it was mains connected. I have pressed...
I have noticed exactly the same issue with my Sony XDR-S55DAB
Even if it has batteries installed but only working off mains electricity, after several months it will not start when the power button is pressed and I have to replace the batteries.
The radio will work again if you just replace the batteries with fresh ones
Try this next time the batteries go flat; disconnect the radio from the mains, replace the batteries with fresh ones, and leave for a couple of minutes (you do not have to switch on!).
You can remove the batteries if you like then reconnect the mains cable and press ON
If your radio behaves exactly the same as mine, it will spring into life so how come?
In the "olden days" ie pre-2000, small portable radios often had a physical switch which connected and disconnected the power supply be it battery or mains.
Nowadays, many radios don't have a "proper" switch, but a "function" button - press it on, and the radio operates, press it again and the radio stops - to enable this, a very small amount of charge is required to keep the central "brain" alive in order to notice this, and in the case of the Sony XDR-S55DAB, this only seems to be supplied by the battery, not the mains adapter.
My advice is simply keep a spare set of batteries handy and replace them whenever your radio wont turn on. Using the mains adapter allows the batteries to lastfar longer than using the batteries on their own.
It is completely counter-intuitive that a "battery/mains" radio needs batteries to work off the mains, but this is the only design fault can find in an otherwise excellent radio.
Aug 15, 2013 | Audio Players & Recorders
Why wont my sony xdr-ds12ip play music from my iPhone/iPod
Feb 04, 2012 | Sony Audio Players & Recorders
Iphone4 will not playing music through docking station Sony XDR-DS12IP... Iphone was working with system perfectly until sunday? still manages to charge iphone ? Iphone message iphone not configured...
first return sony and get ihome because sony is bad at docky station(not affending ps) or you can do is take it where you got it and bring the ios deviece and get it checked if it works congrauts if it doesn`t BUY IHOME.
Aug 23, 2011 | Sony HD Radio and Dock Docking Station,...
I need remote code for sony xdr-ds12ip i pod docking station
call sony and request or check amazon. usually you can download an app for your iphone for remotes or you can try a universal remote. program it to your dock radio station
May 06, 2011 | Sony HD Radio and Dock Docking Station,...
Sony mains DC lead for XDR-S7
ask in Local Electronics shop. Probably they have
Nov 29, 2009 | Electronics - Others
SONY XDR-S55DAB Stack at display : DAB WAIT
Solution seems to be do not buy small Sony DABs, or any small ones. I have the XDR-S56DBP and have same problem. Was also cursed with 'no ensemble' error. Even worse than the Pure one I had before which lost all of the DAB facility and now only functions as an FM radio. I had a good medium sized Roberts one, but power cable split and I can't find a suitable replacement.
Apr 28, 2009 | Sony Audio Players & Recorders
Sony HD Radio and Dock Docking Station, Remote Control for iPod XDR-S10HDiP Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
