Question about Brother SE-270D Computerized Sewing Machine
The pressor not coming down - Brother SE-270D Computerized Sewing Machine
    Novelist:
  • 268 Answers
Have you released the presser foot lift?
Posted on May 22, 2014
The pressure sewing foot comes up by itself won't stay down when sewing what's wrong or how to adjust.
Hello, Don -
Without knowing the particular make and model of your sewing machine, it is a challenge to provide information most relevant to the problem with your machine.
That being said, you may find helpful the answers to a similar question here:
https://www.justanswer.com/general/5ntaq-repair-pressor-foot-goes-down-slowly.html
If you wish, you can provide the make and model of your machine by using the Comment feature.
Jan 12, 2018 | Sewing Machines
Bar that sewng foot is attached to for raising & lowering suddenly will not drop sweing foot all the way down to plate. Any suggestions on how to fix?
Perhaps you accidently moved the switch that enables free hand embroidery? It's up and under next to the pressor foot lever. Slides forward and backward. Forward the pressor foot will go all the way down to the feed dogs. Slid back and it keeps the foot up off the feed dogs but allows the thread tension to work properly. It would be easy to accidently move it when operating the pressor foot raise/lower lever.
Aug 31, 2014 | PfaFF Sewing Machines
6020 off problem
Not sure, but am thinking perhaps the tension disk has gunk or threads stuck in it. Try soaking a length of perl cotton in rubbing alcohol, squeeze out the excess. Raise the presser foot and loosen the tension disk as far as possible and gently pull the perl cotton DOWN through the tension disk a few times.
If that doesn't help, then it's possible a spring in the tension mechanism or something in the presser foot lever is malfunctioning.
Dec 07, 2017 | Sewing Machines
Problem with striaght stitch pressor foot
it's possible that the needle bar is out of alignment and needs to be fixed at a sewing machine shop
Mar 18, 2014 | Kenmore Sewing Machines
Where to find a not snap-on 1/4" with edge pressor
Go to www.allbrands.com and you can buy a low shank screw on presser foot. I am assuming that it is a low shank. (I looked up your manual on www.singerco.com for free) It is $14.95, I think. Good luck
Nov 20, 2010 | Singer 4830
I can't get the pressor foot on the silver part came off and the actual pressor foot
Place the foot under the arm while arm is in up position. Put arm in down position and foot should snap into place (line it up where it is supposed to go together before lowering the arm).
May 11, 2010 | Brother XR-65t Mechanical Sewing Machine
Hi I have a Husqvarna 1+ when the pressor foot is in the down position a warning indicator states that the pressor foot is not down and the machine will not function.Any sugestions would be greatly...
The problem could be caused by a couple of issues. It is either with the switch that is located above the foot, that tells the circuit board when the foot is up or down, or with the circuit board itself. It could also be the lever you lift the foot up and down with. Inside the machine that lever has a plastic "fin" on it that touches the switch. It is possible that the lever is broken. Either way, you need to take it in for service.
Dec 29, 2009 | Husqvarna Sewing Machines
Pressor foot
Go to this link on the Brother website to order:
http://www.brother-usa.com/homesewing/modeldetail.aspx?PRODUCTID=LS2125&tab=optional
Jul 05, 2008 | Brother LS-2125 Mechanical Sewing Machine
Trying to us Creative Card
There is an in- between setting. It's not up, but not down either. Does that make sense? If you put the lever up, then bring it down slowly and kind of push it to the back. Hope this helps!
Feb 03, 2008 | PfaFF Creative 7570
Brother SE-270D Computerized Sewing Machine Logo
23 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
