Question about Konica Minolta Office Equipment & Supplies
Error 13e2 after flashing rom
After restart after flashing rom from exe file downloaded from KM website I have 13e2 error on screen. Reflash can not be done.
  • Konica Minolta Master
  • 6,696 Answers
Model number would help if you had access to KMBS then you should have access to service manual
Posted on Jan 16, 2016
3 Suggested Answers
IrishDruid
  • 2712 Answers
SOURCE: Setup.exe error message
Try downloading the driver again. Make sure that you download the correct driver for your OS. Download from here:
http://search.lexmark.com/printer/US/en/18K6500
Hope that helps!
If your issue isnot resolved, please do not assign a rating just yet. Please post back asto what steps you took, results, etc, and I will try to assist you further asbest I can.
P.S. - You can rate asolution with one of four ratings as explained under (remember that at times abit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem. (Positive Rating)
  • "Helpful" - The solution provides useful leads that helps solve the problem. (Positive Rating)
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated. (Negative Rating)
  • "Inappropriate" - The solution has absolutely nothing to do with the problem. (Negative Rating)
Thank you for using FIXYA!
IrishDruid
Posted on Sep 28, 2008
Mike Trivedi
  • 67 Answers
SOURCE: Able to download the exe file obtained online onto
Press "Ctrl + Alt + Del" To Open "Task Manager" .. >>> File >>> Hold "Ctrl" And Press New Task(Run..) >. This Will Open Command Prompt >> Then
CD\
%systemroot%\system32\restore\rstrui.exe
This Should open the System Restore and try to restore the system and then try it.....
Posted on Feb 26, 2010
Can't Uninstall W-XP
run msconfig and restor your computer to a date befor you moved the pc
good luck!
Dec 17, 2013 | HP ScanJet 5100C Flatbed Scanner
Where do I find a working BIOS file for my Gateway MX6453? The update zip-file being offered at Gateway seem to be missing the new BIOS file named 1208.ROM...
remove the battery get some isopropyl alcohol and qtips and clean the contacts where the battery actually connects to the pc, if that doesn't work it's possible that the IC inside the battery has gone to hell and if that's the case you'll need to purchase another battery.
Jul 01, 2012 | Gateway MX6453 Notebook
Will not start after reset
I came across this one time while flashing the rom. I got stuck in sort of a loop when I attempted to reflash (load the update file from the website or whatever ROM you want and holding power and volume up). I had no response from just the power button and I had to reset a bunch of times during the attempt to reflash but I stayed at it for about an hour and finally got it to reflash to the provided ROM.
After that I flashed to JGM and have stuck with that.
If you have no response to anything I would try pulling the back and then taking the battery cable out. This will give it a real hard reset. Give it like 30 seconds and plug it back in. Try to reflash after this and hopefully you'll get something. If not it is very likely bricked.
Dec 12, 2011 | Velocity Tablets & eReaders
Asus k8v-mx bios problem
This is the result of a bad flash. There is nothing that you can do unless you reflash the bios to another version. In some cases you have to order a new bios
Aug 03, 2017 | ASUS K8V-X SE Motherboard
Flashing the bios
1. Download the BIOS flash utility.
2. Download the BIOS rom file.
3. Format a floppy drive, with system files so that it is bootable.
4. Copy the utility and the rom file to the floppy drive.
5. Boot from the floppy drive.
6. At the c:/ prompt enter the name of the flash utility file followed by the name of the rom file. Example: awd816a.exe romfile.rom
7. Let the program run. Do not turn off your computer until prompted to do so.
Thanks and please take a moment to rate as fixya.
Dec 22, 2008 | Matsonic Computers & Internet
Bios update problems P4S800-MX
An .exe file isn't a .rom file. You downloaded the flash program (the program used to flash new data to the ROM), you didn't download the flash data. Look on the site again, or look to see if there's another file - P4S800MX.ROM - to extract.
Sep 10, 2008 | ASUS P4S800-MX Motherboard
I would like to change my language to french help htc kaiser
Reflash to the french HTC Kaiser/TYTN II ROM.
http://rapidshare.com/files/117059726/RUU_Kaiser_HTC_FRA_3.28.406.0_radio_sign_25.83.40.02_1.65.16.25_Ship.exe
Make sure you are connected via ActiveSync in Windows XP before running the RUU (Flash program) then follow the instructions.
Jul 04, 2008 | HTC TyTN II Smartphone
T830 flash rom
I to all, sorry for my english. I have resolved this problem, with the PocketLOOX8xxFlashTool.exe. The tool first try to connect to the T830, then it show you how to reset the PocketLoox to reflash it. The sequence is:
1) Reset by pressing Power Button + camera button + factory reset; 2) insert the usb cable in the T830 or insert it in the docking with the Power Button + camera button pressed. When you insert the usb cable, on the screen it show a new message "New USB download mode". Now PocketLOOX8xxFlashTool.exe can connect to your t830 and reflash it.
Good luck
Giancarlo
Sep 16, 2007 | Fujitsu Siemens Pocket LOOX T830...
Updates for the PCMCIA and Compact Flash Card controllers
Some MobilePro units have exhibited the following symptoms when using Compact Flash Cards or ATA PCMCIA Memory Cards: 1. Storage Card folder is not displayed when you insert a PCMCIA ATA card and/or a Compact Flash card. 2. Warning message "Unidentified PC Card Adapter". 3. Warning message "Storage Card Warning" displayed. To fix these issues: If you have a MobilePro 750C without a ROM upgrade, download the file MP75Pcm.exe from support.necsam.com. For a MobilePro 750C with upgraded ROM, use the file MP75RPcm.exe. After the files are extracted, follow the instructions in the Readme.txt file.
Sep 14, 2005 | NEC MobilePro 880
Sep 14, 2005 | NEC MobilePro 750
52 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
