SOURCE: WIFI PHONE NOT RECOGNISING BELKIN WIRELSS ROUTER
the router is not configured by default as an access point.
to use the phone the router must be configured as an access point, which is more than disabling security, nat and dhcp must be removed..
page 53 of the user manual describes the proceedure.
online the manual is here
http://belkin.httpsvc.vitalstreamcdn.com/belkin_vitalstream_com/support/dl/p75170-d_f5d8231-4_man.pdf
SOURCE: on belkin surf router clicked on set as access
the only thing you need to do is reset your router to go the IP address original 192.168.2.1
because when you setup it as a access point the router change the Ip Address.
restore the router to factory default settings, please do the following:
1. Unplug the router's power supply
2. Press and hold the reset button on theback of the router
3. Keep the reset button depressed and, at the same time, plug the power supply back in
4. Keep the reset button depressed for another 10 seconds
5. Release the reset button
do this for 3 times and you will acces your router.
Good luck
Please rate me techbelkin
SOURCE: I have Belkin N150 Rouer.
f the modem light keeps blinking, it means that the router hasn't been configured yet. Also, rarely, it can be an issue with WAN port/modem port on the router or the ethernet cable connecting the modem to router or finally, modem may not be working as its not applicable in this case(as you said).
1.Connect comp.--(gray port) router (yellow port)--modem
2.On the computer, open the router page by typing 192.168.2.1 in the address bar of browser
NOTE : IF YOUR INTERNET SERVICE PROVIDER IS CABLE FOLLOW THE BELOW STEPS
3.Under Internet WAN , SELECT the connection type as Dynamic.->NEXT
4.On the far left column, click on "MAC address" under Internet WAN.
5.Click on clone and apply changes and finally check Internet status
6.If internet status > Not connected, we need to do a network power cycle
7.For this, unplug the power from router, then from modem, then unplug the coaxial cable from cable modem.
8. Wait for 60 sec, then connect the coaxial cable, then connect power to modem, wait for lights on modem to get steady, then finally, plug in the power to router.
Now, you may see proper lights lit on the router.
All my best wishes for a fast internet service through the router.
FOR PPPOE OR DSL CONNECTIONS
1.Under Internet WAN , SELECT the connection type as PPPOE ->NEXT
2.ENTER THE USERNAME & PASSWORD PROVIDED BY YOUR IN INTERNET SERVICE PROVIDER
3.CLICK ON APPLY CHANGES
For any advanced help, revert asap!
Thanks and regards,
MILAN
SOURCE: I am trying to connect
You will need a crossover cable to connect the two routers. They are different than standard LAN CAT cables and are available here:
ONLY THE ORANGE ONES ARE CROSSOVER CABLES
http://goo.gl/tRvLI
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
