Question about Panasonic Lumix DMC-FZ7 Digital Camera
If i try to delete an image my camera tells me 'editing operation cannot proceed as information processing is ongoing'?
How can I restore photos that I edited?
If you didn't keep a copy, you may well be out of luck. If your camera hasn't been used much, you may be able to "undelete" the original picture from the camera using software like this:
Freeware to undelete files from sd card with iCare Data Recovery Free
Jan 30, 2015 | Cameras
How can I delete photos
If you want to delet from your camera or your computer. On the computer, find your Photo files from your computer. Right click on the photo, it should show up blue highlighted, then right click "delete." There should also be a "delete" button your camera settings. Check your manual.
Oct 02, 2014 | Panasonic Lumix DMC-FZ10 Digital Camera
ImageBrowserEX won't load past 80%
It is important, that you ALLOW in the InternetOption of IE the ActiveX
- Run ActiveX controls and plugins
Nov 28, 2012 | Canon Powershot Sx240 Hs 12.1 Mp 20x...
How do I remove the Corrupt-EP virus?
1.CTRL+ALT+DELETE --> Processes right-click Corrupt-EP, “End Process”
2. Start-->Run.Type “regedit” OK.
4.Delete “HKEY_LOCAL_MACHINE\Software\Corrupt-EP
5.Navigate to directory %PROGRAM_FILES%\Corrupt-EP\Corrupt-EP.exe and delete Corrupt-EP.exe
Please comment if the information provided has been helpful for the improvement of my support assistance. Thank you and regards.
Aug 14, 2010 | Microsoft Windows XP Home Edition
I just bought this camera today and cannot access the "read me" information so am in the dark on how to operate camera properly. I have taken some pictures but now it says, "Memory full" what does that...
You can download the manual from
http://www.polaroid.com/support_detail?p=4317
The instructions will guide you through deleting/editing pictures or you can print or download to a PC using a USB connector.
Please rate this solution. Thanks.
Jun 23, 2010 | Polaroid i1236 Digital Camera
I selected open folder to view pictures. The f: file display DCIM. I clicked it and it display Olympus displaying pics. I name a couple of pics in the slide. I wanted to change the folder name I...
it sounds like you deleted the images. If you are downloading images from your camera or card....you should open the folder to view images. hold control key down and select all images that you want to download. right click on them on click save.
it sounds like you are trying to rename a folder before downloading anything. I know that when I try to edit or rotate any of my images on my card, i first need to download the images to a folder before doing any edits. it does sound like you were trying to rename your folder. normally, you would right click on folder, and click rename. hope this helps. if you need anything else, feel free to ask!!!
Mar 21, 2010 | Olympus D-595 Zoom Digital Camera
Re booth system
To resolve this problem, select the Delete restoration data and proceed to system boot menu option which enables the computer to perform a normal restart, instead of performing the restoration process while the computer is in Hibernate mode
source:http://support.microsoft.com/kb/q294427/
Jul 03, 2008 | Microsoft Windows XP Home Edition
Uploading files back to the camera
Why would you want to load images back the camera? Once images are loaded to computer for editing- then camera will no longer recognise them. This is because the image type taken by the camera is properly called an EXIF image- which is a JPEG with Extra information such a camera make and exposure detail. Editing images in an image editor will remove this EXIF information and it becomes a plain vanilla JPEG. Cameras do not recognize JPEGS. The Exif can be replaced with some software by a fudge that kids the camera- Try Photo shop or Paint-Shop- but it is a long shot.
Jun 01, 2007 | Canon PowerShot A710 IS Digital Camera
Panasonic Lumix DMC-FZ7 Digital Camera Logo
46 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
