Question about Krups Toaster Ovens
There is no button for setting the clock on this Krups toaster oven, so how do I use the other buttons to set it?
This toaster oven has buttons for Bake, broil, conv. bake, defrost and toast but no button for setting the clock.
SOURCE: krups fbc2 toaster oven cuts off while toasting
returned it to vendor and asked for exchange.  decided no way I should fix it after less than 5 days of use.  Curious if others have encountered a similar problem.
Posted on Sep 28, 2008
SOURCE: I have a DeLonghi AD 679 Turbo Convection toaster
I am having the same issue with my AD 699 Turbo Convection over. Were you able to repair it or find out what was wrong?
Posted on Nov 14, 2009
  • 949 Answers
SOURCE: The broil element and bake element both come on set for Bake.
You are correct in your diagnosis. The selection switch has 2 sets of contacts that should only make one when on bake. The contacts internal to that fuse are most likely fused together, the other thing that could be going on is a short circuit in the wires to the selection switch causing the same problem. Typically a repair unless under warranty would be costly unless you are up for the challenge of replacing the switch and checking the wiring yourself.
Posted on Apr 20, 2010
SOURCE: setting clock on krups toaster oven
When the oven is first plugged in "12:00" appears on the display.
• Press the "Timer" button twice. The display will begin to blink "12:00".
• Adjust the time in steps of one minute by pressing the "+" or "-"
buttons.
• If you hold the button pressed down for more than 6 seconds, the
time will change quicker.
• Press the "Timer" button to enter the time in the system.
If you do not press the "Timer" button, the time will be
entered automatically after 30 seconds.
Posted on Jan 11, 2011
tbreeze47
  • 3083 Answers
SOURCE: My Krups toaster oven bakes,
It might be abe to be fixed, but you should contact Krupps for support, since they have the parts. Here is their support site:
http://www.krups.com/Consumer+Services/Product+Support/Manuals/Use+Intructions.htm
They might be able to refer you to a nearby authorized service center, or offer a swap out, but see what they say.
Good luck, and hope this helps.
Posted on Jan 26, 2011
Why are the control buttons operate intermittently?
Sounds like there is a loose wire connection. Have you contacted the manufacturer?
Aug 11, 2014 | Krups FBC212 1600 Watts Toaster Oven with...
How to set the clock on classic 110 oven
Push the clock button. Either use the timer up down to set a time. Push the clock button again. Should lock in the new time..
Oct 30, 2011 | Toaster Ovens
How do i set clock
You can get the manual on the link below page 9
http://www.krupsusa.com/NR/rdonlyres/932350FD-628D-4959-879A-AC006C96E9B9/7106/FBC4FBC5.pdf
• When the oven is first plugged in "12:00" appears on the display.
buttons.
Feb 20, 2011 | Krups FBC5 1600 Watts Toaster Oven with...
How do you set the clock on the delonghi DO400 toaster oven
  1. Press for 5 seconds the TEMP./SELECT/CLOCK but- ton (7) (the hours flash on the display).
  2. Press the TIME/TOAST COLOR buttons (8) to the desired time (hours). The time set will begin blinking on the display.
  3. Press the TEMP./SELECT/CLOCK but- ton (7) (the minutes flash on the display).
  4. Press the TIME/TOAST COLOR buttons (8) to the desired time (minutes). The time set will begin blinking on the display.
  5. Press the TEMP./SELECT/CLOCK but- ton (7) to confirm. It is pos- sible to press the button at any time during cooking to display the current time (the display shows the time set).
  • If you wish to change the hour on the display once it has been set, press the TEMP./SELECT/CLOCK but- ton (7) before proceeding to set the new time as described above.
  • It is possible to display the current time even after starting a function, by pressing the TEMP./SELECT/CLOCK button (7) (the time is displayed for 2 seconds).
Oct 14, 2010 | DeLonghi DO400 Toaster Oven with...
On off button usually fais to respond to on
It could be a problem with the board as that on/off button is one complete unit with the board, digital display and buttons attached. If you want to fix it yourself get your model number (FBC212) and head over to 1800Parts.com to see if they have the board in stock. You can also call Krups directly and they will tell you a service station in your area. We are one of their national service stations but we are in New York.
Sep 15, 2010 | Krups FBC212 1600 Watts Toaster Oven with...
Setting clock on krups toaster oven
buttons.
May 28, 2010 | Krups FBC5 1600 Watts Toaster Oven with...
Setting time
I own the exact same toaster oven. Can't locate the manual. Also,
tried to set the time,which was off by 2 hours,and no luck,either.
Try to Google the instruction manual pdf. Good luck.
Mar 31, 2010 | Krups FBC412 1600 Watts Toaster Oven with...
I have a new toaster oven and the clock won't set properly
I would call Cuisinart - this one has a 3-year warranty, and all they would need is a serial number, not the receipt. Do any of the lights turn on? When you pressed clock, did you hold in the hours button?
-Tha Mp3 Doctor
Jan 07, 2009 | Cuisinart TOB-175 1500 Watts Toaster Oven...
How can I turn off the annoying "beep" on my Krups Toaster Oven?
Check out this link; might or might not help you:
http://applianceguru.com/forum1/15129.html
Please post whether this works for you.
Good luck, Sam
Dec 20, 2008 | Krups FBC112 1600 Watts Toaster Oven with...
Krups fbc2 toaster oven cuts off while toasting
Sep 27, 2008 | Krups FBC112 1600 Watts Toaster Oven with...
Toaster Ovens Logo
49 people viewed this question
Top Krups Toaster Ovens Experts
Tom Chichester
Are you a Krups Toaster Oven Expert? Answer questions, earn points and help others
